Make your powerstroke better - Ford Powerstroke Diesel Forum
post #1 of 5 Old 07-29-2014, 09:21 AM Thread Starter
#1PowerstrokerIH88's Avatar
Got an 01 7.3, lookin to do some stuff to it to give it more power and reliability. Basically what all can be cleaned, replaced, deleted to help the truck run better and maybe add a few horses.
#1PowerstrokerIH88 is offline
post #2 of 5 Old 07-29-2014, 09:40 AM
McKinneyMike's Avatar
4" turbo back exhaust w/o muffler
PHP Hydra with tunes of your choice
Wicked Wheel II(or similar billet compressor wheel) for your turbo
2000 F250 SD 2WD 7.3L
RiffRaff billet compressor wheel
PHP Hydra
4" Diamond Eye, turbo back w/5" tip
ISSPRO EV2 Pyro, Trans Temp, Boost and Fuel Press
Kenwood Exelon/Focal/Image Dynamics/PPI
McKinneyMike is offline
post #3 of 5 Old 07-29-2014, 12:39 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
6637 intake, cat delete (if applicable), gauges, bellowed up pipes, ebpv delete
Clean the ebps tube, clean filters and fluids
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #4 of 5 Old 07-31-2014, 01:24 PM
Quoted: 858 Post(s)
Feedback Score: 3 reviews
OP, I've got all the stuuf in stock for ya to do what you would like.
:thumbup:
Corey@CNCFAB is offline
post #5 of 5 Old 08-11-2014, 01:48 PM
Clean and lube the brake caliper slide pins. Those buggers are just sucking fuel and power.
Verify proper operation or just replace the locking front hubs with real hubs from warn or milemarker so your front axle isn't spinning all the time.
I really like the ford AIS intake system for quiet, dependable air filtration at a much higher performance level than OEM.
2000 F350 4wd CC SB PSD
Normal mods plus gauges and PHP chip
Lowered to F250 height
Stock tire size, looks stock.
18' 10k# equipment trailer
30' Travel Trailer 7500#
Kioti CK30 tractor
Kawasaki KLX250s Dual Sport
Highbeam is offline
