Looking for a new tuner - Ford Powerstroke Diesel Forum
 6Likes
post #1 of 47 Old 07-26-2014, 06:34 AM Thread Starter
Prew32's Avatar
Quoted: 11 Post(s)
Send a message via AIM to Prew32
so right now my truck has a custom tuned DP tuner and Im looking to possibly change it up and run something different. My truck is a 6 speed with 160cc single shots so its a little laggy and I get alot of smoke and heat. all my mods are in my sig
Anyone have any suggestons? was possibly looking at no limit tuning but havent seen a ton of reviews but the ones I have seen are all pretty good
15 F350 CCLB 6.7 Many mods to come.....
01 F350 CCLB 7.3 6 Speed SOLD
Prew32 is offline
post #2 of 47 Old 07-26-2014, 08:11 AM
Vannnce's Avatar
Quoted: 13 Post(s)
Im in the same boat as you. Im going to get a PHP hydra. that way i can try a bunch of different tuners tuning. I know jay at PHP is a good guy
-Vance-
.2002 f350 Lariat 4" lift w/ 35's. Hydra w/PHP. Swamps 175/146 injectors. gauges. banks power elbow, 4" dp 5"out,RiffRaffs FRX ww, ccv, AIH delete riff raff boost port, '10 tailgate mod amongst a bunch of other goods
.B&W turnover/ companion to haul my 2001 Prowler 5'ver. Home away from home
I.B.E.W. Local 1002
Vannnce is offline
post #3 of 47 Old 07-26-2014, 09:00 AM
schlutzer's Avatar
Quoted: 18 Post(s)
No limit/dynoproven will never get any of my business, they work with DP.
Get the Hydra Hucorey sells it for 375 like most other dealers, but he has Power-struck tunes which are quickly becoming one of the most reccomended tuners
Please check out my 7.3 Enthusiast Facebook group! All are welcome!
schlutzer is offline
post #4 of 47 Old 07-26-2014, 01:16 PM
scagle1's Avatar
Gearhead or Powerstruck either one will do you right
Sold 01 350 6" on 37's and mild mods, 00 X 4" on 35's, 02 f350 4" 35's modded from fan to drive shaft, ridin the 03 with nose conversion with 125k and counting upwards slowly.
Never had CNC's poo on any of it, never will.
scagle1 is offline
post #5 of 47 Old 07-26-2014, 02:21 PM
Quoted: 818 Post(s)
Op, I've got 2 Hydra's left if you interested. I've had a few TS chips, to be unbiased as possible it really is the best chip on the market for the 7.3. I also carry Powerstruck Tuning.
http://www.cncfabricationllc.com/tes...-position-chip
Corey@CNCFAB is offline
post #6 of 47 Old 07-26-2014, 02:46 PM Thread Starter
Prew32's Avatar
Quoted: 11 Post(s)
PHP HYDRA 17 POSITION CHIP
Which one is the best, the hydra or the TS?
Prew32 is offline
post #7 of 47 Old 07-26-2014, 03:06 PM
Quoted: 818 Post(s)
The TS will get you by OK if you never plan on doing any mods. Once you start mods then your truck will be down since you have to send you chip out for reburns. So, not only do you have to wait for snail mail, $10-20 shipping fees, hoping the chip took the burn. I've had to send my old TS chips in multiple times for tuners burning incorrectly or the chip not taking the tune. So you end up with more shipping fees. So I eventually bought 2 TS chips, but that was before the Hydra came out.
The Hydra. Well, its $75 more for PHP's custom basic tuning, but when you start the mods, just call your tuner and they email them. You upload them yourself. Very easy to do.
post #8 of 47 Old 07-26-2014, 03:08 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
The hydra installs once, change tuning when ever, the ts has to be removed and sent off for a reburn, I've had great luck with ts chips, and I get them with tuning already on them for what ever I've done, so I just install them and run them, the hydra would be a great investment tho
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #9 of 47 Old 07-26-2014, 05:51 PM
emev0l's Avatar
You sure you don't have a boost leak?
99.5 Crew Cab 7.3
S468/T4 mount
238/200's
BTS Transmission
Regulated Return Fuel Bowl Delete
ARP Head Studs
910 Valve Springs
Twin Terminator HPOPs
Walbro Fuel Pump
6637, Autometer Gauges
4" turbo back exhaust
Hydra with Gearhead and PHP tunes
Overboost Annihilator
Pre Pump Kit
Post Pump Kit
6.0 Trans Cooler
True-Trac
285/75/16 BFG AT's
Air Bags
Pioneer F930BT in dash GPS
573rwhp 1021.5ft-lbs
emev0l is offline
post #10 of 47 Old 07-26-2014, 07:09 PM Thread Starter
Prew32's Avatar
Quoted: 11 Post(s)
I just had the turbo off yesterday to install new up pipes and a few other things and on my test drive after my truck hit 31 lbs of boost so I'm guessing no leaks right?
Prew32 is offline
