What psi for boost fooler? - Ford Powerstroke Diesel Forum
post #1 of 8 Old 07-21-2014, 08:23 AM Thread Starter
lightning95's Avatar
What psi of boost would I need a boost fooler?
I am seeing 32# at wot. I also keep blowing off the red vacuum line and super glued it in place.
02 F-250 ccsb 7.3 auto, 8" fabtech, 37" toyo, 4.30, 4" straight pipe, AFE intake, hydra chip, riff raff wheel, tugger kit and powerstruck tunes.
95 Lightning fast by NX nitrous
07 Yamaha R1
lightning95 is offline
post #2 of 8 Old 07-21-2014, 08:59 AM
sbluke55's Avatar
Quoted: 545 Post(s)
Garage
You don't need a boost fooler with your tunes( if your running php). All the boost fooler does is limit pressure seen by the MAP so the PCM does not defuel. The php tunes don't defuel but they do set a soft code for over boost at 28.
01 f-250, Standard
Rev tech 4" lift,37" military wrangler Mt tires
KC diy 66, Full force 160/100 and custom tunes from PHP
Banks inner cooler and full 4" exhaust, Diy S&B intake
Diy quad feed, Hydra, Isspro boost, pyro, and fuel pressure
3/0 battery cables with military style terminals
sbluke55 is offline
post #3 of 8 Old 07-21-2014, 10:17 AM Thread Starter
That must be the code I'm getting. It was fine till I ran it hard and the light came on.
If I do the diode boost fooler will it keep the light off?
07 Yamaha R1
post #4 of 8 Old 07-21-2014, 10:40 AM
sbluke55's Avatar
Quoted: 545 Post(s)
Garage
It will but tuners use the map reading to get accurate tuning at high boost levels. Using it would only hinder your performance. I get the light every once in a while and I just cycle the key real quick and it goes off.
01 f-250, Standard
sbluke55 is offline
post #5 of 8 Old 07-21-2014, 02:36 PM Thread Starter
Ok good to know. I'll cycle the key. The wife is pissed cause the lights on in her truck again. Last time it was from the ebpv delete.
07 Yamaha R1
post #6 of 8 Old 07-21-2014, 04:44 PM
Vannnce's Avatar
Quoted: 13 Post(s)
When i "overboost" and get a CEL, it goes away after several minutes, and throws no codes. do your guys not do that? The PO put a boost fooler on mine as well, but i dont think i need it... Im not sure what its accomplishing haha
-Vance-
.2002 f350 Lariat 4" lift w/ 35's. Hydra w/PHP. Swamps 175/146 injectors. gauges. banks power elbow, 4" dp 5"out,RiffRaffs FRX ww, ccv, AIH delete riff raff boost port, '10 tailgate mod amongst a bunch of other goods
.B&W turnover/ companion to haul my 2001 Prowler 5'ver. Home away from home
I.B.E.W. Local 1002
Vannnce is offline
post #7 of 8 Old 07-21-2014, 04:47 PM
sbluke55's Avatar
Quoted: 545 Post(s)
Garage
Mine does the same. If your light stays on after you cycle the key it may be another problem. Check your codes
01 f-250, Standard
sbluke55 is offline
post #8 of 8 Old 07-21-2014, 09:56 PM
Joel's Avatar
Quoted: 10 Post(s)
The diode fooler works great. A regulator boost fooler will have that same limitations as the diode as far as the tuner using the map readings.
I'm might be a little bit crazy, but I just can't stand seeing the light come on every time I get into the throttle.
PIS 230/80's, Van Turbo with EBPV, BD Billet Wheel
Lots of money spent at RiffRaff
Dual SD fuel pumps, in tank mods, CNC Fab bowl retain kit. SDK Tunes. Isspro.
Still pretty slow, just less slow now.
Originally Posted by peixinho View Post
I love finally having my truck back... that 7.3 dog that I was driving was just not cutting it.
Joel is offline
