450 hp Build Plan - Ford Powerstroke Diesel Forum
post #1 of 10 Old 07-18-2014, 09:58 PM Thread Starter
Quoted: 101 Post(s)
450 hp Build Plan
I plan on building a 450 hp daily driver. On top of what I have in my signature I plan on adding 238/100 hybrids from Rosewood, d66 turbo, built tranny, prepump kit and fuel rail crossover from riffraff, and custom tunes from TW. Is their anything else I may need.
00 f250 ext. cab, lb, 4x4, 146,000, zf 6 speed, South Bend 1944ofe, 4 in lift, 315/75/16 Duck Commander Mts, php hydra, Riff Raff frx, Riff Raff billet compressor wheel, Dorman up pipes,IAH delete, ccv mod, 6637 filter, auto meter gauges, scan guage 2, 4 in diamod eye straight pipe 6 in tip.
00t444e is offline
post #2 of 10 Old 07-19-2014, 12:30 AM
JSchuricht's Avatar
That will get you there and then some. 238/100's are good for 500-530hp but you can have them tuned for 450. The D66 is just a stock turbo with a larger 38r wheel and machined housing, if you can swing it, go with the 38r or step up to a t4 mount system. The two things you may need to upgrade afterwards are the fuel pump and HPOP. I recommend a fuel pressure gauge in the cab and a scanner to check the HPOP that way you will know if your factory system isn't keeping up before spending the money on upgrades.
JSchuricht is offline
post #3 of 10 Old 07-19-2014, 06:23 AM
heykw's Avatar
I would also check your rods to make sure the motor wasn't replaced along the way.
Excursion 02 4x4 Silverline exaust superchip tuner
Excursion 2000 4x4 300K miles 238/100 P.I.S. Injectors 38RW/ billet wheel dyno proven tunes
99 F350 7.3 4x4 body build date 02/98 motor build date 12/97 19.5 ricksons (Sold)
heykw is offline
post #4 of 10 Old 07-19-2014, 07:38 AM Thread Starter
Quoted: 101 Post(s)
I already have a fuel pressure gauge, and I have a scan gauge that shows icp. The website says the d66 is good for 500+ hp I'd rather be a little over fueled anyway. As far as the motor goes I am pretty sure it is has forged rods being a 2000 model and it only has 120000 on it.
00t444e is offline
post #5 of 10 Old 07-19-2014, 07:55 AM
PSD POWER007's Avatar
Quoted: 8 Post(s)
Send a message via AIM to PSD POWER007
175/80's got me to 475 at Dyno Proven. Still had plenty of fuel, the Adenaline just hit it's stopping point on oil. I run daily at about 450hp with all that's in my sig.
2003 Ford Excursion Eddie Bauer 4x4 7.3L Powerstroke Forged
Irate T4 BASB, DIY Tymar, Full Force 180/80's, Adrenaline HPOP, Driven Diesel RR & banjos, Magnaflow TBE, DP-Tuner F6 Live tuned, 05 Harley's w/ HID conversion, Edge Insight CS, Dieselsite BRV & coolant filter, Factory 20" wheels, RiffRaff boots, JLR valve body, 6.0 trans cooler, ARP's
PSD POWER007 is offline
post #6 of 10 Old 07-19-2014, 08:25 AM
Quoted: 728 Post(s)
160/80's can get you to 400-425.
180/100's will definitely get you 500 but for the same price 238/100 hybrids will get you 500+ easily with less oil consumption. A stock 17* or T500 will handle it easily. An Adrenaline is OK up to 250cc injectors but that's really pushing it. I have 250/200's and run a SRP 1.1.
D66 will be at its very limit with 238's. You can save your money from less expensive HPOP and buy a 38R. Fantastic setup IMO. Op, If your interested I'm straight north of you. Im just 40 min north of Lima.
Corey@CNCFAB is offline
post #7 of 10 Old 07-19-2014, 09:54 AM Thread Starter
Quoted: 101 Post(s)
Would Rosewood 160/100s get me 450 hp? I know that the P.I.S. 175/80s would get me to 450 hp but I would have a hard time spending 1600 on those when I could have 238/100s from rosewood for 50 more.
00t444e is offline
post #8 of 10 Old 07-19-2014, 12:12 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
What's the top power output of a 38r?
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #9 of 10 Old 07-19-2014, 01:04 PM
Quoted: 728 Post(s)
Nobodys 160/100's will get you to 450+. 400-425 is more realistic with a 38R. 375-400 stock turbo.
Fwiw. Injector size is injector size. IF an injector builder pays close attention to quality control there is very little difference except for opinions. Anyone can make a better quality injector than Sniper. Lmao.
Obviously i carry Powerstruck, but Rosewood, PIS, Swamps, FullForce, Unlimited also have good reputations too. But usually are not here much.
Also our injectors come with a free set of tunes, so $$$ wise that puts you at the same price as Rosewood with 238's. Unless you get free reburns from someone else.
post #10 of 10 Old 07-19-2014, 01:08 PM
Quoted: 728 Post(s)
Supposedly a member on PSA made 638hp with one and a WW2. But he had lots of modifications done and i dont think it would last all that long with extended boost pressures. A 38R can last a very long time. Just keep it under 40psi and change your oil when your supposed to.
