Hydra Flash install problems - Ford Powerstroke Diesel Forum
post #1 of 8 Old 07-15-2014, 02:32 PM Thread Starter
McKinneyMike's Avatar
I am trying to install the PHP Hydra Flash software so that I can program my Hydra, but I keep getting a popup error message below when I try to install the program.
When I click on the "Details..." radio box I get the following verbiage: Anyone have a clue what is wrong?
PLATFORM VERSION INFO
Windows : 6.1.7601.65536 (Win32NT)
Common Language Runtime : 4.0.30319.18444
System.Deployment.dll : 4.0.30319.18408 built by: FX451RTMGREL
clr.dll : 4.0.30319.18444 built by: FX451RTMGDR
dfdll.dll : 4.0.30319.18408 built by: FX451RTMGREL
dfshim.dll : 4.0.41209.0 (Main.041209-0000)
SOURCES
Deployment url : http://www.gopowerhungry.com/hydrafl...sh.application
Server : Apache
Deployment Provider url : http://www.gopowerhungry.com/hydrafl...sh.application
Application url : http://www.gopowerhungry.com/hydrafl...h.exe.manifest
Server : Apache
IDENTITIES
Deployment Identity : HydraFlash.application, Version=2.0.1.1460, Culture=en-US, PublicKeyToken=0000000000000000, processorArchitecture=x86
Application Identity : HydraFlash.exe, Version=2.0.1.1460, Culture=en-US, PublicKeyToken=0000000000000000, processorArchitecture=x86, type=win32
APPLICATION SUMMARY
* Installable application.
ERROR SUMMARY
Below is a summary of the errors, details of these errors are listed later in the log.
* Activation of http://www.gopowerhungry.com/hydrafl...sh.application resulted in exception. Following failure messages were detected:
+ Downloading http://www.gopowerhungry.com/hydraflash/Application Files/HydraFlash_2_0_1_1460/HydraFlash.exe.config did not succeed.
+ The remote server returned an error: (403) Forbidden.
COMPONENT STORE TRANSACTION FAILURE SUMMARY
No transaction error was detected.
WARNINGS
* The manifest for this application does not have a signature. Signature validation will be ignored.
OPERATION PROGRESS STATUS
* [7/15/2014 5:10:04 PM] : Activation of http://www.gopowerhungry.com/hydrafl...sh.application has started.
* [7/15/2014 5:10:05 PM] : Processing of deployment manifest has successfully completed.
* [7/15/2014 5:10:05 PM] : Installation of the application has started.
* [7/15/2014 5:10:05 PM] : Processing of application manifest has successfully completed.
* [7/15/2014 5:10:08 PM] : Found compatible runtime version 4.0.30319.
* [7/15/2014 5:10:08 PM] : Request of trust and detection of platform is complete.
ERROR DETAILS
Following errors were detected during this operation.
* [7/15/2014 5:10:08 PM] System.Deployment.Application.DeploymentDownloadEx ception (Unknown subtype)
- Downloading http://www.gopowerhungry.com/hydraflash/Application Files/HydraFlash_2_0_1_1460/HydraFlash.exe.config did not succeed.
- Source: System.Deployment
- Stack trace:
at System.Deployment.Application.SystemNetDownloader. DownloadSingleFile(DownloadQueueItem next)
at System.Deployment.Application.SystemNetDownloader. DownloadAllFiles()
at System.Deployment.Application.FileDownloader.Downl oad(SubscriptionState subState)
at System.Deployment.Application.DownloadManager.Down loadDependencies(SubscriptionState subState, AssemblyManifest deployManifest, AssemblyManifest appManifest, Uri sourceUriBase, String targetDirectory, String group, IDownloadNotification notification, DownloadOptions options)
at System.Deployment.Application.ApplicationActivator .DownloadApplication(SubscriptionState subState, ActivationDescription actDesc, Int64 transactionId, TempDirectory& downloadTemp)
at System.Deployment.Application.ApplicationActivator .InstallApplication(SubscriptionState& subState, ActivationDescription actDesc)
at System.Deployment.Application.ApplicationActivator .PerformDeploymentActivation(Uri activationUri, Boolean isShortcut, String textualSubId, String deploymentProviderUrlFromExtension, BrowserSettings browserSettings, String& errorPageUrl)
at System.Deployment.Application.ApplicationActivator .ActivateDeploymentWorker(Object state)
--- Inner Exception ---
System.Net.WebException
- The remote server returned an error: (403) Forbidden.
- Source: System
- Stack trace:
at System.Net.HttpWebRequest.GetResponse()
COMPONENT STORE TRANSACTION DETAILS
No transaction information is available.
2000 F250 SD 2WD 7.3L
RiffRaff billet compressor wheel
PHP Hydra
4" Diamond Eye, turbo back w/5" tip
ISSPRO EV2 Pyro, Trans Temp, Boost and Fuel Press
Kenwood Exelon/Focal/Image Dynamics/PPI
McKinneyMike is offline
post #2 of 8 Old 07-15-2014, 05:48 PM
Doesn't Even Care
HVAC SuperTech's Avatar
Quoted: 69 Post(s)
Seems like you didn't download the application fully....try re downloading it again. If it still doesn't work, contact chatham036 on here. His name is jay and he works for php
Sent from AutoGuide.com App
Nick
E99/CC/Lariat/Factory Wide Body Kit
"The Mistress"
Power Hungry Performance HYDRA Chip
Custom Tuned by Bill@PHP, Tony Wildman@Total Diesel Performance and Lars@Gearhead
D66 w/Dieselsite WW2, Full Force 250/100s, Adrenalin HPOP, Built Trans, Walbro Fuel Pump, S&B Intake, 6" Stacks, Leveling Kit, Eagle Alloy Wheels, 315/75/16 Grabber AT2s & Much More
HVAC SuperTech is offline
post #3 of 8 Old 07-15-2014, 06:06 PM Thread Starter
I didn't download the program. I was trying to load it from the disc that was provided by PHP with the Hydra.
PHP Hydra
post #4 of 8 Old 07-15-2014, 06:37 PM
sbluke55's Avatar
Quoted: 621 Post(s)
Garage
http://www.gopowerhungry.com/hydrafl...draflash.shtml
01 f-250, Standard
Rev tech 4" lift,37" military wrangler Mt tires
KC diy 66, Full force 160/100 and custom tunes from PHP
Banks inner cooler and full 4" exhaust, Diy S&B intake
Diy quad feed, Hydra, Isspro boost, pyro, and fuel pressure
3/0 battery cables with military style terminals
sbluke55 is online now
post #5 of 8 Old 07-16-2014, 02:06 AM Thread Starter
Originally Posted by sbluke55 View Post
Maybe something was wrong with the server? I just tried to load it here at work and i get the same error message as I did at home last night. I have emailed PHP about the problems.
PHP Hydra
post #6 of 8 Old 07-16-2014, 05:17 PM Thread Starter
OK I cleaned the edge connector thoroughly with some mineral spirits and plugged in in one more time. She fired right up! I got it all put back together and had to take a spin. WOW! The powerband is so much nicer than before overall. I started out in the 40HP DD mode. The transmission shift points are much nicer and logical IMO. The crisp shifts are a welcomed addition too!
I wasn't so much thinking about the power difference until I got a bit of road rage. She may not be a race car, but I am seriously happy with the pickup and again the powerband itself. I am really happy with this add-on
PHP Hydra
post #7 of 8 Old 07-16-2014, 06:29 PM
Doesn't Even Care
Quoted: 69 Post(s)
Excellent!! Love to hear happy customers!
Nick
"The Mistress"
post #8 of 8 Old 07-16-2014, 06:58 PM
Go to hydrahelp.com to download the latest software. The software on the CD has been superseded
Power-Struck dot com
POWER-STRUCK is offline
The Following 2 Users Say Thank You to POWER-STRUCK For This Useful Post:
HVAC SuperTech (07-17-2014), McKinneyMike (07-18-2014)
