Newb question about BANKS removal - Ford Powerstroke Diesel Forum
post #1 of 4 Old 07-13-2014, 01:02 AM Thread Starter
Hi , I had no luck in my general post question so thought I'd condense it here.
I have a banks ottomind chip and trans command. If u a DP style chip do I remove both the chip from the Ecu and the trans command?
I bought the truck with them installed so I'm a bit newb as there removal and replacement.
Any help on this and best chip/controller is appreciated.
Matt
F350 7.3 dually 2wd.
spookypt is offline
post #2 of 4 Old 07-13-2014, 08:29 AM
sbluke55's Avatar
Quoted: 525 Post(s)
Garage
You will need to remove them both to install a new chip. I sold my trans command for $150. It was new in box because I have a standard. I sold my banks chip for $125. I'm not sure how to remove the trans command but the chip is easy. First thing you do is take your keys and put them in the house. If you keys are in the ignition when you pull the chip you will fry your PCM. Look down by your ebrake and you will see your PCM. The case should be modified to pull the chip out without pulling the whole PCM. Just grab it and pull it out. Then your done. I suggest the hydra from php for the chip. If funds are not there just pick up a 6 position chip from riff raff.
01 f-250, Standard
Rev tech 4" lift,37" military wrangler Mt tires
KC diy 66, Full force 160/100 and custom tunes from PHP
Banks inner cooler and full 4" exhaust, Diy S&B intake
Diy quad feed, Hydra, Isspro boost, pyro, and fuel pressure
3/0 battery cables with military style terminals
sbluke55 is offline
post #3 of 4 Old 07-14-2014, 03:14 PM
DIMBLEWAMBIE's Avatar
My truck had the banks chip and trans command on it when i bought it, When i switched to my F8 chip I didn't feel like messing with removing all the wiring for the trans command unit so i just installed the bypass plug and left it all there. No issues and is running great with custom tunes from DP and Dyno Proven. I wouldn't give that trans command unit to anyone, let alone try to sell it.
Justin DIMBLEWAMBIE Lamb
2002 F250 7.3l 4x4 CCLB
8in lift Deaver springs, Bilstein 5125s & 5160s
Toyo 37x13.50r17 MTs, Eagle Alloy 185s
F8 Destiny DP-Tuner & Dyno Proven
Banks Boost, EGT, Trans gauges
Banks straight pipe, K&N intake w/ 6637 filter
Banks EBPV-less elbow, Wastegate ON [OFF]
Foil delete mod, Zoodad mod
11" LED bar, 05-07 grill
DIMBLEWAMBIE is offline
post #4 of 4 Old 02-19-2015, 06:13 AM
Rolfsted's Avatar
Quoted: 33 Post(s)
Ts performance told me I could run their chip with the transcommand. I too bought a 2001 F350 with the Banks power setup on it. I guess the previous owner installed it not long after he bought the truck new.
Rolfsted is offline
