Tru cool problem - Ford Powerstroke Diesel Forum
post #1 of 19 Old 07-12-2014, 07:35 PM Thread Starter
Jerrybizzle's Avatar
Quoted: 24 Post(s)
Tru cool problem
So a few weeks ago I put in a tru cool trans cooler in series with the stocker. Heres the problem when towing in the mountains and less than 35 mph the temps will climb to 230 which I then pull over, listen to wife complain, let it cool down then proceed on. This has happened both camping trips when towing 8000 pound combined weight camper and four wheeler trailer. Would I be better off bypassing stock unit as in series the fluid doesn't flow as well. I'm a bit confused and definitely frustrated. Any ideas?? Thanks.
2012 f250CCLB, 35x12.5/17 Kanati mud hogs on race line assault wheels, 2 inch lift
Mini maxx
Jerrybizzle is offline
post #2 of 19 Old 07-12-2014, 08:03 PM
heykw's Avatar
Are the temps the same as prior to installing the tru cooler?
Excursion 02 4x4 Silverline exaust superchip tuner
Excursion 2000 4x4 300K miles 238/100 P.I.S. Injectors 38RW/ billet wheel dyno proven tunes
99 F350 7.3 4x4 body build date 02/98 motor build date 12/97 19.5 ricksons (Sold)
heykw is offline
post #3 of 19 Old 07-12-2014, 10:05 PM Thread Starter
Quoted: 24 Post(s)
Seems almost warmer now. They used to get up to 220, but that was just on the highway and not the slower towing speeds. This is my first year with the torque app versus trans temp gauge, which crapped out. I realize the temp pulled from the PCM will show warmer but 230 is hot. So I pull over and let it cool down if still have mountains to climb.
Mini maxx
post #4 of 19 Old 07-13-2014, 06:55 AM
Vannnce's Avatar
Quoted: 13 Post(s)
my torque app measures cooler than my gauge, but im pretty sure my gauge must be bad... fwiwm, i did away with my stock unit. Jut the true cool there. the other day i pulled from tulsa to houston in 95 degree heat, and my trans temp only hit 215 once with the app. No mountains..., but i dont think it should be getting that hot.
Is your converter locked up at those speeds? Are you in drive or do you manually put it in 2
-Vance-
.2002 f350 Lariat 4" lift w/ 35's. Hydra w/PHP. Swamps 175/146 injectors. gauges. banks power elbow, 4" dp 5"out,RiffRaffs FRX ww, ccv, AIH delete riff raff boost port, '10 tailgate mod amongst a bunch of other goods
.B&W turnover/ companion to haul my 2001 Prowler 5'ver. Home away from home
I.B.E.W. Local 1002
Vannnce is offline
post #5 of 19 Old 07-13-2014, 09:17 AM Thread Starter
Quoted: 24 Post(s)
Both actually. When it hunts I help it. I dropped it to second till I finished the pass and this is in my 65 tow tunes which I assume would keep the tc locked more. It is hot right now, around 100 so I see how without the airflow it would get warm, but I don't think I should be seeing 230. Airflow is key because at 55+ it does just fine.
Mini maxx
post #6 of 19 Old 07-15-2014, 05:41 PM Thread Starter
Quoted: 24 Post(s)
So would it be better to run the new cooler solo or in series with stock unit? What is the absolute highest temp I should be okay with reading from the PCM on my torque app?
Mini maxx
post #7 of 19 Old 07-15-2014, 06:07 PM
heykw's Avatar
I would think the more the better reference the coolers
heykw is offline
post #8 of 19 Old 07-15-2014, 07:02 PM
PSD POWER007's Avatar
Quoted: 8 Post(s)
Send a message via AIM to PSD POWER007
That's way too hot! I have the 26 row 6.0 cooler and my temps never get over 80-85 degrees above ambient temp when I'm towing my 10k LB trailer. That's mountains or flat ground. On the stock cooler my temps would push up to 215-220* but now they never get over 190.
2003 Ford Excursion Eddie Bauer 4x4 7.3L Powerstroke Forged
Irate T4 BASB, DIY Tymar, Full Force 180/80's, Adrenaline HPOP, Driven Diesel RR & banjos, Magnaflow TBE, DP-Tuner F6 Live tuned, 05 Harley's w/ HID conversion, Edge Insight CS, Dieselsite BRV & coolant filter, Factory 20" wheels, RiffRaff boots, JLR valve body, 6.0 trans cooler, ARP's
PSD POWER007 is offline
post #9 of 19 Old 07-15-2014, 07:10 PM
sbluke55's Avatar
Quoted: 570 Post(s)
Garage
If possible at low speeds like that switch into 4low. It will help with heat because you torque converter isn't locked up and is creating heat.
01 f-250, Standard
Rev tech 4" lift,37" military wrangler Mt tires
KC diy 66, Full force 160/100 and custom tunes from PHP
Banks inner cooler and full 4" exhaust, Diy S&B intake
Diy quad feed, Hydra, Isspro boost, pyro, and fuel pressure
3/0 battery cables with military style terminals
sbluke55 is online now
post #10 of 19 Old 07-16-2014, 02:44 AM Thread Starter
Quoted: 24 Post(s)
I'll give that a try if going real slow again on dirt road.
Mini maxx
