Banks Six Gun questions... - Ford Powerstroke Diesel Forum
 2Likes
post #1 of 12 Old 07-12-2014, 05:42 PM Thread Starter
Quoted: 2 Post(s)
Ok, let's see...'99, 7.3, 2wd...it has a Banks Six Gun (flame away) installed by a previous owner. I have no additional gauges or any way to monitor anything other than the stock ones.
On the six gun, is there a best setting for mpg? My first tank averaged 13mpg in town driving. Is there a happy medium for performance and mpg?
Not racing, not towing...are gauges and/or monitor necessary? Any recommendations? Replacing the Banks isn't an option right now.
Anyone know the specs of each setting? I know... high idle, stock (I think), more, more, max....again, I think.
7point3 noob is offline
post #2 of 12 Old 07-12-2014, 06:00 PM
sbluke55's Avatar
Quoted: 525 Post(s)
Garage
The six gun tuner has built in gauges for boost, egt and trans temp. The egt and trans temp needs senders for them to work, also egt was a option so it might not have it. So how does it work. What the tuner does is it takes the output from the icp and changes it and then sends it to the computer. What that does is make the computer think the icp pressure is low and and closes down the ipr and boosts oil pressure. It's really just a adjustable 10k mod with gauges. When I had mine it didn't have high idle, so I'm not sure about that. For best fuel mileage use the lowest setting.
01 f-250, Standard
Rev tech 4" lift,37" military wrangler Mt tires
KC diy 66, Full force 160/100 and custom tunes from PHP
Banks inner cooler and full 4" exhaust, Diy S&B intake
Diy quad feed, Hydra, Isspro boost, pyro, and fuel pressure
3/0 battery cables with military style terminals
sbluke55 is offline
post #3 of 12 Old 07-12-2014, 06:04 PM Thread Starter
Quoted: 2 Post(s)
It doesn't have gauges. I have a knob, that's it. Are the gauges a separate purchase?
post #4 of 12 Old 07-12-2014, 06:40 PM
sbluke55's Avatar
Quoted: 525 Post(s)
Garage
It doesn't sound like you have the six gun. Take some pics. Also look down at the PCM and see if you have a chip.
01 f-250, Standard
sbluke55 is offline
post #5 of 12 Old 07-12-2014, 06:54 PM Thread Starter
Quoted: 2 Post(s)
Hmmm...then I wonder what I have there. Pics will have to wait til tomorrow. Car is in the garage, raining and not feeling up to jockeying everything around.
post #6 of 12 Old 07-12-2014, 07:01 PM
sbluke55's Avatar
Quoted: 525 Post(s)
Garage
Here is a pick of the six gun. Attachment 310602
Here is a pick of a ts 6 position chip. Attachment 310610
This is the one I think you have.
7point3 noob likes this.
01 f-250, Standard
sbluke55 is offline
The Following User Says Thank You to sbluke55 For This Useful Post:
7point3 noob (07-12-2014)
post #7 of 12 Old 07-12-2014, 07:08 PM Thread Starter
Quoted: 2 Post(s)
Knob is a little different, but yes....just that knob.
post #8 of 12 Old 07-12-2014, 07:17 PM
joebuck's Avatar
Quoted: 35 Post(s)
if its the TS 6 position chip with the canned tunes there typically
1-stock
2-high idle
3-50hp
4-75hp
5-100hp
6-extreme
setting 3 will net ya the best mpgs if thats what ya have(which 95% of the time people have) WHEN its possible send it in for some better tunes from PHP or TW
2001 F250 XLT
EX cab,LB
5" side exit exhaust
AFE stage 2 intake
Banks 1.0 exh. housing
Riff Raff billet wheel
PHP tuned
6" lift on 37's
joebuck is offline
The Following User Says Thank You to joebuck For This Useful Post:
post #9 of 12 Old 07-12-2014, 07:25 PM Thread Starter
Quoted: 2 Post(s)
And it's just as simple as removing it? No issues with it running afterwards? It just reverts back to stock?
post #10 of 12 Old 07-12-2014, 07:27 PM
joebuck's Avatar
Quoted: 35 Post(s)
when you pull the chip out/or put in DO NOT have the keys in the ignition or it will fry your ecu,yes it will slide right out and should just be back to stock
2001 F250 XLT
EX cab,LB
AFE stage 2 intake
PHP tuned
6" lift on 37's
joebuck is offline
