Hydra Problems!! - Ford Powerstroke Diesel Forum
 2Likes
post #1 of 13 Old 07-11-2014, 06:46 AM Thread Starter
Hydra Problems!!
Early 99 F350 4x4
Got my Hydra chip yesturday and put it in last night..Pretty positive i did everything right.
Cleaned the silicone off conectors
Got the right hex code translation code and installed 15 tunes off the Hydra flash program that comes with the chip. Put it all back together and the truck started right up..Time for a Beat run right..
Started out in the 65hp daily..ran fine, switched to 80hp daily..ran ok for about 1 mile and the truck Hickuped and shut right off with the service engine light on..Switched back to stock setting and the truck started right back up..Drove it for a few min in stock and went back to the 65 daily figured my truck wont run the 80 and up cause i know it has limitations with the smaller injectors and Hpop and ICM..ran for a few miles pulled into a parking lot and it started Fluttering up and down..water in fuel light came on..This has never happend before putting the chip in..
Ran it home in stock mode and when i pulled in the driveway and came to a stop, truck shut right off..
Anyone know whats going on here..I just tried calling PHP no answere.
BigWhiteRack is offline
post #2 of 13 Old 07-11-2014, 07:58 AM
Joel's Avatar
Quoted: 10 Post(s)
The PCM probably isn't cleaned good enough.
Try that
Chatham036 likes this.
PIS 230/80's, Van Turbo with EBPV, BD Billet Wheel
Lots of money spent at RiffRaff
Dual SD fuel pumps, in tank mods, CNC Fab bowl retain kit. SDK Tunes. Isspro.
Still pretty slow, just less slow now.
Originally Posted by peixinho View Post
I love finally having my truck back... that 7.3 dog that I was driving was just not cutting it.
Joel is offline
post #3 of 13 Old 07-11-2014, 09:04 AM
Chatham036's Avatar
Quoted: 136 Post(s)
I believe I overheard you talking to Sean earlier. If you need any additional help please let me know
Comments or opinions expressed by me do not necessarily represent the views of PHP, its management, nor its employees. PHP is not responsible for, and disclaims any and all liability for the content of comments written by me.
Chatham036 is offline
post #4 of 13 Old 07-11-2014, 11:31 AM Thread Starter
Yes I was talking to Sean earlier, He was awsome..we went through everything and came up with probably some silicone still left on the connectors in the PCM.
I re cleaned the connectors with some alcohol, plugged the chip back in and set to 65hp daily..Just ran about 20 miles with no issues..Thanks for the help!
Its really hard to tell if you got all the silicone off..rubbing alcohol and a Q tip works great.
Truck runs awesome, I can really feel the difference in the power and shift points. My Millage average really jumped up on the computer..but will wait to see what comes out to on paper to see how much i gained. I will be trying the TOW tunes out very soon..Thanks again!
post #5 of 13 Old 07-11-2014, 12:36 PM
Joel's Avatar
Quoted: 10 Post(s)
Glad it worked out for you.
For the record, 99% of all chip problems come back to improper cleaning of the pcm
Joel is offline
post #6 of 13 Old 07-11-2014, 01:19 PM
Another reason why i will be doing business with you guys at php you are great to your customers! Now of only hydra flash would work on my macbook air! lol
2001 Power Stroker is offline
post #7 of 13 Old 07-11-2014, 01:36 PM
Quoted: 27 Post(s)
PHP is awesome! When i was originally calling around trying to gain info on what chip i wanted i called PHP and there was no answer, i did not leave a message cause i figured id just call back in a bit. 2 min later Jay was calling me back saying he had a missed call from me asking if i needed any help from him. I got all my questions answered and gained even more knowledge that i had originally been looking for.
I will be buying a Hydra when i upgrade my injectors based on my previous experience with PHP. Great customer service and always professional!
Also, it took me 3 tries to get my PCM clean. I got down to the copper and gave it another try hoping i had not taken too much off and then everything worked great!
Glad you like the chip. I tow about 8K lbs and i really like the 80 HP tune. Very little smoke and runs at good temps.
2000 F-250 XCLB 4x4 6 Speed, PIS 175/80's, ARP's, 910's, Irate Fuel, 6637, GTP38R, 4" turbo back, Hydra PHP tuned, International Up-pipes, ISSPRO Boost, EGT, HPOP and Fuel Pressure gauges. SB Clutch. MB Diesel HPOP stage 2.
CarportMechanic is offline
post #8 of 13 Old 07-12-2014, 01:35 PM
McKinneyMike's Avatar
I had my local shop install my Hydra today (along with my Diamond Eye exhaust and RR billet wheel)and when I got in it the keypad was not lighting up. I figure that it is just not clean enough so I have taken it back out and had a look. Someone mentioned using alcohol to clean it. Rubbing alcohol?
When I got home I decided to pull out the computer and have a crack at it myself. I cleaned the edge connector more thoroughly with a scotch brite pad and plugged in the Hydra and reassembled everything. I knew as soon as I reconnected the batteries and hit the key something was amiss. It seemed to turn over super fast and would not begin to start. I pulled the Hydra back out as I was concerned that I might have caused some other damage to the computer. I reinstalled it w/o the Hydra and and everything seemed fine again. I checked the edge connector and it looks like I am getting into the copper below so I reluctant to go any farther with sanding it.
2000 F250 SD 2WD 7.3L
RiffRaff billet compressor wheel
PHP Hydra
4" Diamond Eye, turbo back w/5" tip
ISSPRO EV2 Pyro, Trans Temp, Boost and Fuel Press
Kenwood Exelon/Focal/Image Dynamics/PPI
McKinneyMike is offline
post #9 of 13 Old 07-14-2014, 07:05 AM
Same thing happened to me, just make sure you get all of it off on top and bottom and body solvent is what I used and it wipes it right off and I installed again and it worked so I'm betting that is it. Also PHP is awesome!
E99 F250 XLT SuperCab 4x4 3.73 gears, 213k and climbing, ZF6 trans w/ 1944-60K SB Clutch/Flywheel, 6637 filter, muffler/cat delete w/ 5 inch tip, PHP Hydra, 4 gauge pod(EGT, EOT, FUEL PSI, BOOST), 12000 lb Warn Winch, 07 headlights/grill, 6k HID kit, Bushwhacker pocket style fender flares, Pioneer 7" touchscreen, 2.5 inch leveling kit with 315/75/16 General AT2s on stock 16 bullets, HPX
Next up: Rebuild Kit and Billet Wheel, Fixing E-brake so I can park on hills!
Tow51Stang is offline
post #10 of 13 Old 07-14-2014, 07:07 AM
Thanks for the tip. I am just not comfortable sanding the edge connector any further. I will try a suitable solvent on it and then reinstall.
PHP Hydra
