Troubleshooting Gauges - Ford Powerstroke Diesel Forum
post #1 of 16 Old 07-10-2014, 11:17 AM Thread Starter
USMC2001PSD7.3's Avatar
Quoted: 14 Post(s)
Garage
I tried searching but couldn't find anything similar to my issue. I have ISSPRO EGT Boost and Trans temp gauges on my 2001 7.3 and have a few problems.
The EGT gauge quit on me bit for a while after it would react extremely slowly and I have no idea as to the accuracy. I did pull the probe and clean it and it reacted slowly for awhile then quit again.
The Trans Temp gauge likes to freak out and the needle does all kinds of weird motions. I verified through my monitor that that the trans didn't blow up when it did it the first time.
Can anybody point me in the right direction as to where to start? I'm mot an electrical guru so I don't know if I should look at the gauge, probe, wiring, etc........
USMC2001PSD7.3 is offline
post #2 of 16 Old 07-10-2014, 02:26 PM
CSIPSD's Avatar
What version of gauges do you have? Are they EV, EV2 or Performax?
01 F-250 SC PSD,320k,16 Isspro Gauges, AFE-2,CCV Mod,IAH delete,map reg,Modded H2e, 6.0 IC, 230/100 from P.I.S, Studs, 910 springs, Forged rods, Water injection,Hydra chip-No Limit/Gearhead tuning, Swamps HVHF IDM, MBRP 4" dual's, Aero, 6" tip's, 4" Revtek lift, 37/12.5/16.5 MT's
Joe
DYNOPROVEN.COM, PERFORMANCEINJECTIONSYSTEMS.COM and RIFFRAFFDIESEL.COM
CSIPSD is offline
post #3 of 16 Old 07-10-2014, 03:25 PM Thread Starter
Quoted: 14 Post(s)
Garage
Performax. Had a pic somewhere but cant find it.
post #4 of 16 Old 07-10-2014, 07:02 PM
Joel's Avatar
Quoted: 10 Post(s)
I'm sure Joe will provide better insight, but I would start by making sure you have clean, solid grounds.
PIS 230/80's, Van Turbo with EBPV, BD Billet Wheel
Lots of money spent at RiffRaff
Dual SD fuel pumps, in tank mods, CNC Fab bowl retain kit. SDK Tunes. Isspro.
Still pretty slow, just less slow now.
Originally Posted by peixinho View Post
I love finally having my truck back... that 7.3 dog that I was driving was just not cutting it.
Joel is offline
post #5 of 16 Old 07-10-2014, 07:04 PM Thread Starter
Quoted: 14 Post(s)
Garage
Good to go thanks guys. Sometimes the trans temp works fine other times it freaks. I definitely want them working again soon. Ill start digging when I get home and give you guys more info
post #6 of 16 Old 07-10-2014, 07:14 PM
hansel's Avatar
Quoted: 99 Post(s)
Do you have the right gauges hooked up?? I had mine reversed the first time after that they worked fine.
Just an idea
2001 7.3L CCSRW 4X4
Airiad Intake 4" Flo-Pro Exhaust
ISSPRO EGT/Transmission
PHP Hydra
2015 Heartland Prowler
hansel is offline
post #7 of 16 Old 07-10-2014, 08:17 PM Thread Starter
Quoted: 14 Post(s)
Garage
Hahaha yea I do they worked great for a long time somethin has just gone wacko. What exactly did they do when you had them hooked up wrong?
post #8 of 16 Old 07-11-2014, 05:51 PM
hansel's Avatar
Quoted: 99 Post(s)
The EGT moved really slow and the transmission never moved
2001 7.3L CCSRW 4X4
PHP Hydra
hansel is offline
post #9 of 16 Old 07-11-2014, 06:09 PM Thread Starter
Quoted: 14 Post(s)
Garage
Haha thats funny. Thankfully my trans temp moves and is accurate sometimes but other times it goes ballistic.
post #10 of 16 Old 07-14-2014, 03:09 PM
CSIPSD's Avatar
To confirm you have PERFORMAX gauges, with a computer box mounted under the hood?
Joe
CSIPSD is offline
