guesstimating HP to pick the right clutch? - Ford Powerstroke Diesel Forum
 1Likes
post #1 of 16 Old 07-10-2014, 06:16 AM Thread Starter
chpprguy's Avatar
I recently put in new 160/30 injectors with appropriate tunes.
under hard acceleration in my higher gears, the clutch will slip.
Is there a way to estimate my HP, so that I can pick the correct clutch?
Any brand recommendations or brands to steer clear of?
Late 99 7.3, ZF6 manual F250 4x4
~280,000 miles......only a handful of mods...
160/30 single shots (powerstruck tunes)
PHP HYDRA
WW2 wheel on the stock turbo
boost fooler
4" turbo back exhaust
bellowed up pipes
HP oil crossover
Riff Raff FRX
Air Raid cold air intake
CCV mod
T500 HPOP
Boost/EGT/Fuel Pressure gauges
chpprguy is offline
post #2 of 16 Old 07-10-2014, 06:53 AM
scagle1's Avatar
350-400 range
Sold 01 350 6" on 37's and mild mods, 00 X 4" on 35's, 02 f350 4" 35's modded from fan to drive shaft, ridin the 03 with nose conversion with 125k and counting upwards slowly.
Never had CNC's poo on any of it, never will.
scagle1 is offline
post #3 of 16 Old 07-10-2014, 07:03 AM
Quoted: 27 Post(s)
I like my South Bend. I got one rated up to 450 and it shifts nice and the clutch pedal feels great.
Upgrade your clutch fork when your in there. If you have the stock one it will break eventually due to a stronger clutch.
2000 F-250 XCLB 4x4 6 Speed, PIS 175/80's, ARP's, 910's, Irate Fuel, 6637, GTP38R, 4" turbo back, Hydra PHP tuned, International Up-pipes, ISSPRO Boost, EGT, HPOP and Fuel Pressure gauges. SB Clutch. MB Diesel HPOP stage 2.
CarportMechanic is offline
post #4 of 16 Old 07-10-2014, 07:20 AM
sbluke55's Avatar
Quoted: 553 Post(s)
Garage
Do your research before you finally decide what clutch you want. I can't remember which clutch I have but it's so stiff that my leg gets worn out in traffic and it's very grabby. It has hardly any slip to it and trying to back a trailer is very difficult. Go with valiar or south bend. I recommend calling and talking with either company and ask questions and tell them what you use your truck for and what you want out of the clutch.
01 f-250, Standard
Rev tech 4" lift,37" military wrangler Mt tires
KC diy 66, Full force 160/100 and custom tunes from PHP
Banks inner cooler and full 4" exhaust, Diy S&B intake
Diy quad feed, Hydra, Isspro boost, pyro, and fuel pressure
3/0 battery cables with military style terminals
sbluke55 is offline
post #5 of 16 Old 07-10-2014, 02:27 PM Thread Starter
chpprguy's Avatar
Thank you for the feedback,
Seems like some more research and a few phone calls are in order.
Sent from AutoGuide.com App
L99 250 ext cab flat bed , six speed, 275K , Airraid intake , 160/30 sticks , WW2 , 4" back exhaust , EBPV delete , CCV , FRX , southbend clutch, 05 headlights.
Future.... Turbo mods....
chpprguy is offline
post #6 of 16 Old 07-11-2014, 10:02 AM Thread Starter
chpprguy's Avatar
Any opinions/feedback on the southbend 1939-DF kit?
I have a lathe, so I can turn my flywheel, I do know I need a new ring gear.
(I have a "bad spot" on it somewhere, occasionally the Stratford grinds, if I rock the truck in gear, it fires right up)
chpprguy is offline
post #7 of 16 Old 07-11-2014, 11:45 AM
Quoted: 27 Post(s)
If you have a stock clutch in it now it has a dual mass flywheel and you should replace with a single mass flywheel. South Bend will sell kits with everything you need.
Not sure the South Bend would even bolt up to a stock flywheel but i have never tried...
post #8 of 16 Old 07-11-2014, 11:49 AM Thread Starter
chpprguy's Avatar
Previous owner had the clutch replaced, but I have no idea what they put in,and I'm guessing there is no way to tell without pulling it.
chpprguy is offline
post #9 of 16 Old 07-11-2014, 01:49 PM
Quoted: 27 Post(s)
No not really, pulling the inspection plate is almost worthless, you cant hardly see anything but might be able to feel what is in there but i cant describe to you what the differences would be.
Id be willing to bet that if the previous owner had it replaced he had it replaced with a stock clutch. Stock ones will last a good 200K if not abused so id assume yours isnt weak it just cant handle the new power. But ive been wrong before.
Real hard to tell whats goin on in there without pullin the tranny.
dannanw likes this.
post #10 of 16 Old 07-11-2014, 01:52 PM
dannanw's Avatar
Quoted: 65 Post(s)
Garage
What this nation needs is cleaner thoughts and dirtier fingernails...
dannanw is offline
