turboback question - Ford Powerstroke Diesel Forum
post #1 of 10 Old 07-07-2014, 07:29 PM Thread Starter
turboback question
01 7.3 , do I need to retune after installing a turboback? Im we'll aware it'll optimize the mod if I do, but do I NEED to right away? (Will it run lean or anything?)
Thanks!
amerimuscle is offline
post #2 of 10 Old 07-07-2014, 08:16 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
No you do not need any tuning to run a full exhaust
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #3 of 10 Old 07-07-2014, 08:31 PM
03ranger30's Avatar
^what he said. But a chip with some good tunes will make the truck more fun to drive.
Charlie
2003 F250 CCSB 7.3--Gearhead tuned, MBRP 5", 6637, Diesel Site Coolant Filter, 203* Thermostat, ISSPROs, HPx, 5% tint
03ranger30 is offline
post #4 of 10 Old 07-08-2014, 04:25 AM Thread Starter
Ok that was my impression, thanks a lot guys.
post #5 of 10 Old 07-08-2014, 04:26 AM Thread Starter
Oh and likewise with just a CAI? What about the 2 together?
post #6 of 10 Old 07-08-2014, 06:38 AM
03ranger30's Avatar
They won't add much power just by themselves, but you do not need a tune to run either. Those are the most basic mods that people do to these trucks.
Charlie
post #7 of 10 Old 07-08-2014, 09:14 AM Thread Starter
AFE stage 2 advertise 112 tq (even at the flywheel) that's not shabby?! I keep hearing to stud the heads... at what point is that necessary? im assuming not at the bolt on level? or is there a boost level that its recommended at?
post #8 of 10 Old 07-08-2014, 09:18 AM
03ranger30's Avatar
I have never personally tested that, but I think it's a bunch of bologna. There is no way that just switching out the intake will net you that much.
Whoever is telling you that you need head studs on a stock 7.3 is someone you shouldn't listen to. These aren't 6.0s that need them with just the basic bolt ons, 7.3s are pretty good at holding the headgaskets unless you're making an obscene amount of power and boost, and they are certainly not needed at the intake, tune, exhaust stage.
Charlie
post #9 of 10 Old 07-08-2014, 11:23 AM Thread Starter
I agree with you on multiple accounts, I mean it does have a lot of displacement + boost so I can see how some would believe it but it sounds a little inflated, and I was hoping it wouldn't need studs at that point.
So what boost could I expect with a stage 2 AFE and a full 4 in turbo back (w programmer) ? approximately
post #10 of 10 Old 07-08-2014, 11:37 AM
blue99stroker's Avatar
Quoted: 249 Post(s)
intake and exhaust will add about 20 hp over stock.
the main reason for doing them is as a supporting mod for when you want to chip/program your truck.
usually can't run the stock compressor wheel over 25 psi without some major surge issues.
with a good custom tuned chip and billet compressor 30 psi is pretty easy to hit. as long as you don't have boost leaks/driver pressure leaks.
99.5 f250 7.3 4x4 261k FF 160/30, PHP Hydra, S&B CAI, 4" TBE, Van Turbo with Turbo Blanket, RR Billet Wheel, Autometer Gauges, Transgo Tugger, Non-Ebpv Pedestal, 08 Tow Mirrors, Trucool.
Dad-2000 F250 7.3 4x4 111k Autometer Gauges, Superchips 1705 (Tow Safe), 6637, 4" TBE, BD Billet Wheel, Trucool.
blue99stroker is offline
