A chip? Will this help improve my fuel mileage? - Ford Powerstroke Diesel Forum
post #1 of 7 Old 07-07-2014, 03:54 PM Thread Starter
Hey Everyone, This is my first post here. I have owned my '01 7.3L for 5 years and pulls very well. I used to help my (late) Dad service the 7.3's and there were no decisions when it came to what I wanted in a towing truck. When I bought my truck, the owner had installed a chip a couple of years earlier. He swore it increased his fuel mileage. When I first started towing right after I bought it, I was getting approximately 11-12 MPG towing.
I have noticed over the past year or so, that my fuel mileage isn't as good anymore. I went on a round trip of 250 miles pulling my loaded 24' inclosed and got only 9.3-9.7 MPG !!!
My truck has been serviced on a regular basis and has 180K miles on it.
I can't remember the name of the chip he said he had installed. Seems like it started with a "P". Maybe it was a Prowler??? I can't remember. If someone mentioned it, I'd probably hit me then and jog my memory.
Could someone recommend how I could increase my fuel mileage either with a chip or other means?
Thanks in advance, Rich
rpmracing18 is offline
post #2 of 7 Old 07-07-2014, 04:46 PM
scagle1's Avatar
Might wanna give some more details on your truck.
The chip / a chip won't net MPG. Don't expect one to and you'll be better off - then if you possibly see a 1-2 MPG difference you'll be happy. Don't expect to gain via one though.
Fuel filter clean ? No brakes hanging ? Go to smaller tires ? Keep rpm's under 2k , no Jack rabbit starts. Try cleaning the ebp tube. Run some type of fuel additive for lubrication. Coast when possible and drive like you have an egg under the fuel pedal.
Welcome aboard the .org
Sold 01 350 6" on 37's and mild mods, 00 X 4" on 35's, 02 f350 4" 35's modded from fan to drive shaft, ridin the 03 with nose conversion with 125k and counting upwards slowly.
Never had CNC's poo on any of it, never will.
scagle1 is offline
post #3 of 7 Old 07-07-2014, 05:06 PM Thread Starter
-Serviced on a regular basis, fuel filter changed once a year.
-Tires; Cooper Discoverer. 285-75-16 mounted on the original rims.
-No brakes hanging. (I would smell it).
-Hardly ever drive it over 2000 RPM, unless when towing and pulling up a grade.
-Never jack rabbit starts.( I drive it like a truck, not a sports car).
-Use Sea Foam once/month.
Should I just remove the chip? I can't see how I went from 12(avg)MPG towing to 9.5(avg)MPG towing. Like I was saying, I treat my truck very well, Serviced regularly. It's my bread and butter also, I use it for my Landscaping business.
Any help is appreciated.
Rich
post #4 of 7 Old 07-07-2014, 07:15 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
Maybe it's time to service the injectors, but goin to a custom tuned chip would probably help, along with a less restrictive exhaust and intake
Have you experienced exhaust leaks?
Welcome to the addiction
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #5 of 7 Old 07-08-2014, 03:58 AM Thread Starter
No exhaust leaks. I watched some you tube videos of how to clean the ebps and the tube. A few of the videos said it really didn't help their MPG. But, I'm sure it would be a plus to do so after seeing all the carbon buildup.
I'll check in on the servicing of the fuel injectors.
Thanks for any help.
post #6 of 7 Old 07-08-2014, 06:01 AM
any loss of power? boost leak
2006 250 sc, custom tunes from innovative, 4inch turbo back mbrp.
princetontigers is offline
post #7 of 7 Old 07-08-2014, 04:48 PM Thread Starter
No lost power.
No boost leak that I know of......
