TS Chip Install -Edge Problem or Not? - Ford Powerstroke Diesel Forum
post #1 of 7 Old 07-03-2014, 07:32 PM Thread Starter
Question TS Chip Install -Edge Problem or Not?
OK just got my new TS Performance chip and want to install this weekend. I currently have a Edge Evolution turner program installed and can't get the programmer to set my PCM back to stock. Keep getting a message " timed out waiting for key on". Do I have to get the PCM back to stock before I install the chip? Any ideas on getting the PCM back to stock setting with my Edge Programmer? Thanks
jjohnsonlta is offline
post #2 of 7 Old 07-04-2014, 07:47 AM
PSD POWER007's Avatar
Quoted: 8 Post(s)
Send a message via AIM to PSD POWER007
The chip will over ride any programming on the PCM.
2003 Ford Excursion Eddie Bauer 4x4 7.3L Powerstroke Forged
Irate T4 BASB, DIY Tymar, Full Force 180/80's, Adrenaline HPOP, Driven Diesel RR & banjos, Magnaflow TBE, DP-Tuner F6 Live tuned, 05 Harley's w/ HID conversion, Edge Insight CS, Dieselsite BRV & coolant filter, Factory 20" wheels, RiffRaff boots, JLR valve body, 6.0 trans cooler, ARP's
PSD POWER007 is offline
post #3 of 7 Old 07-04-2014, 08:06 AM Thread Starter
Thanks glad to hear that. I am not sure what's wrong with my edge programmer but did a google search and other people have had the same code come back ( timed out waiting for key on ). Of course I had the key on when directed and tried it a dozen times or more with the same results. I am going to install this chip and never look back on this edge programmer again.
post #4 of 7 Old 07-07-2014, 01:14 PM
DieselManor's Avatar
Sometimes disconnecting both batteries for 15 min will reset certain errors like that. Otherwise, as said, you should be fine.
David Murphy
DieselManor is offline
post #5 of 7 Old 07-07-2014, 01:47 PM
SeeYa's Avatar
Before returning to stock I'd remove the chip. This could be why the edge won't perform this function. It's detecting a foreign device and won't proceed with returning it to stock. The Edge is trying to write the Stock program back to the PCM so this very well may be the case.
Custom Tuning-Computer Chips
Flash Programmers-Aftermarket parts
Ford Power Stroke Engine and Transmission Tuning Specialist since 2004.
828-221-0076
SeeYa is offline
post #6 of 7 Old 07-08-2014, 07:04 AM Thread Starter
update
Ok I went ahead and installed the chip without taking my PCM back to stock with my EDGE programmer. Truck started up but ran like crap. Tried driving in stock setting but seemed like it wasn't running on all cylinders. Didn't shift right either. I figured maybe didn't get terminals clean enough so cleaned again but had pretty much same results. I was a little worried cause I could see I had cleaned terminals down to copper and had read not to do this. I called TS tech line Mon. morn and they confirmed that the chip works off the stock computer setting and you have to clean the terminals to copper. Gave EDGE a call and SUPER HAPPY with their customer support. They are sending a unit to take my PCM back to the stock setting plus a new unit to replace my old programmer. I will be returning my old unit plus there stock setting unit all prepaid by EDGE. They said I would get their stuff in two days. So for now truck up and running with EDGE tune.
post #7 of 7 Old 07-24-2014, 06:16 AM
That's good to hear. I also have a TS chip in my truck, and I cleaned the terminal so copper. Been like that for 10 years now, so hopefully that will put your mind at ease. You definitely want the ECM to be on it's stock setting (not programmed).
David Murphy
