PHP hydra or re-burn my current 6pos chip??? - Ford Powerstroke Diesel Forum
post #1 of 21 Old 07-03-2014, 08:51 AM Thread Starter
joebuck's Avatar
Quoted: 35 Post(s)
Ok so done a lot of searching and reading on the hydra 17pos chip and also have done research on reburning my current chip with TW tunes or PHP,can't find any posts from members who have switched from one to the other saying what they liked/disliked,so if anyone has some first hand knowledge I'm all ears!!!! I'm leaning towards the hydra for the price/easability of reprogramming/and 17pos,but currently have a TS 6pos chip with canned tunes but want something a little more "custom" than the average,stock,high idle,50,75,100,140.Truck is a 01 excab LB,mods are 5"exh,and AFE stage 2 intake,nothing fancy it's my weekend warrior hauling at the most 6-7k or just running around town,what's everyone's thoughts?????? And thanks in advance for any input,it's greatly appreciated!
joebuck is offline
post #2 of 21 Old 07-03-2014, 08:58 AM
sbluke55's Avatar
Quoted: 500 Post(s)
Garage
I only really use 3-4 tunes on my hydra. I really like it but if I where you I would just reburn your chip you have. If you where going to be changing injectors and turbo and trying to fine tune everything then the hydra is great.
01 f-250, Standard
Rev tech 4" lift,37" military wrangler Mt tires
KC diy 66, Full force 160/100 and custom tunes from PHP
Banks inner cooler and full 4" exhaust, Diy S&B intake
Diy quad feed, Hydra, Isspro boost, pyro, and fuel pressure
3/0 battery cables with military style terminals
sbluke55 is online now
post #3 of 21 Old 07-03-2014, 10:06 AM
scagle1's Avatar
REBURN.
Did i say Reburn ?
Just in case , IMO Reburn.
Reburn and then spend the couple of other hundred on something else. Never ran TS canned tunes but someones reburn custom tunes are that much better is what the general consensus says over and over again. A few good tunes is really all you need as stated above , not very many people really using 17 positions and i'm not trying to say not to use PHP. If your going to buy tunes from lots of people then by all means get a hydra , but most folks are fine with one good chip with a few tunes. I have one with 8 and 99.9% of it is spent in two tunes , on another 6 position i have 99.9% is spent in 2 as well.
Sold 01 350 6" on 37's and mild mods, 00 X 4" on 35's, 02 f350 4" 35's modded from fan to drive shaft, ridin the 03 with nose conversion with 125k and counting upwards slowly.
Never had CNC's poo on any of it, never will.
scagle1 is offline
post #4 of 21 Old 07-03-2014, 10:09 AM
BryceB's Avatar
I got the PHP FU chip.. it was fun to play with and test out tuns at first, but then I settled into a few tunes I like and haven't had a need to reburn it since.
I'd suggest to just reburn if you have a chip and save the money. if you didn't already have a chip, then maybe the Hydra would be fun, but the fun would wear off.
2001 Ford F-250 SD CCSB 7.3 PSD - AIS Intake, Zoodad,
MBRP 4" XP Series Exhaust w/ Muffler, HD4R100, 26 row Trans Cooler, Fumoto Valve,
285/75R16E BFG AT KO, Pioneer AVIC-Z130BT Nav, BOYO VLT-422C Back Up Camera,
Scangauge II, Glowshift 3 Gauge Pod (EGT,TFT,Boost), PHP FU Chip, Huskyliners, Huskyliner Mud Flaps, Warn Premium Hubs, Riffraff Boots/Clamps/inserts
Dyno'd at Mo's Speed Shop 11/3/12 - 307rwhp / 651rw ft-lbs <<<--- On PHP 120Race tune
BryceB is offline
post #5 of 21 Old 07-03-2014, 10:10 AM Thread Starter
joebuck's Avatar
Quoted: 35 Post(s)
Thnx sbluke55/scagle1,great info!
joebuck is offline
post #6 of 21 Old 07-03-2014, 11:06 AM
Quoted: 27 Post(s)
I agree, just reburn. I use 2 positions on my truck no matter what im doing, either DD or towing 8K lbs.
I use stock to start and warm my truck up
I use my 100 HP tune for everything else. I never have issues with my EGT's even pulling grades. I can feather the throttle if its getting hot or simply drop a gear and im good to go. I recommend PHP based on the low EGT's but i am biased and have never tried anything else other than a superchip.
2000 F-250 XCLB 4x4 6 Speed, PIS 175/80's, ARP's, 910's, Irate Fuel, 6637, GTP38R, 4" turbo back, Hydra PHP tuned, International Up-pipes, ISSPRO Boost, EGT, HPOP and Fuel Pressure gauges. SB Clutch. MB Diesel HPOP stage 2.
CarportMechanic is offline
post #7 of 21 Old 07-03-2014, 11:30 AM
Joel's Avatar
Quoted: 10 Post(s)
Add me to the reburn list. For all the reasons already stated
PIS 230/80's, Van Turbo with EBPV, BD Billet Wheel
Lots of money spent at RiffRaff
Dual SD fuel pumps, in tank mods, CNC Fab bowl retain kit. SDK Tunes. Isspro.
Still pretty slow, just less slow now.
Originally Posted by peixinho View Post
I love finally having my truck back... that 7.3 dog that I was driving was just not cutting it.
Joel is offline
post #8 of 21 Old 07-03-2014, 12:41 PM
Mikey's250's Avatar
I vote reburn. I could get away with one tune and that would be the 100 hp. I dd, haul or whatever in that tune.
Michael- Georgia Powerstroke Diesel Association
2002 F-250 ECSB 4X4 Lariat
Mikey's250 is offline
post #9 of 21 Old 07-03-2014, 01:11 PM
Macon's Avatar
Reburn. I use 3 slots though. Whisper, high-idle, and 120hp. I used to swap tunes around all of the time, and if I ever haul something heavy I might flip it to my tow tune, but now that I'm accustomed to it, it just stays in one spot 95% of the time.
2002 F250 CCSB 4x4
PHP Phoenix, John Woods VB, NUC bypass, 6637
"No country can be called free which is governed by an absolute power;
and it matters not whether it be an absolute royal power or an absolute
legislative power, as the consequences will be the same to the people."
--Thomas Paine, Four Letters on Interesting Subjects, 1776
Macon is offline
post #10 of 21 Old 07-03-2014, 05:29 PM Thread Starter
joebuck's Avatar
Quoted: 35 Post(s)
thank you EVERYONE for the insight and opinions,i am gonna go with a re-burn with PHP tunes,i think im gonna go with
-high idle 1k
-65hp moderate tow(7,500-10k)
-80hp light tow(up to 7,500)
-80hp DD
-100hp performance
-120hp race
joebuck is offline
