Go Back   Ford Powerstroke Diesel Forum > Ford Powerstroke 99-03 7.3L Forums > 99-03 7.3L Performance Parts
Old 01-19-2006, 11:26 AM
02ROB 02ROB is offline
pryo gauge
I have a 02 psd my pyro gauge is mounted after the turbo. I am hearing from people to mount it on the right side manifold does anybody have any good ideas for this.
Old 01-19-2006, 01:35 PM
01SMOKINSD 01SMOKINSD is offline
Send a message via AIM to 01SMOKINSD Send a message via Yahoo to 01SMOKINSD
From all of the reading I have done, I have come to the conclusion that you need to put it where ever makes u most comfortable and know what the limitations are (max temp) according to where you have the probe placed. I need to install one in my truck and am probally going to put mine after the turbo as well. I have a few friends who have PSD's and thats where they have theres and none of them have had any problems. Just remember that max temp is about 400-600 degrees lower than if placed in the manifold. Everyone has their own opinon, and thats just my 2 cent worth.
Old 01-19-2006, 04:01 PM
Worm Drowner Worm Drowner is offline
Mine is after-turbo and I'm fine with it. As my dad, retired after 50+ years as a diesel mechanic, pointed out, most all the engines he worked on had pyros post-turbo. Also, if you go pre-turbo, you only pick up on bank of cylinders, so if you have a bum injector on the other side, you'll never know by the pyro.
Old 01-19-2006, 07:41 PM
99Smokin73Stroker 99Smokin73Stroker is offline
Grammar Police Chief
Send a message via AIM to 99Smokin73Stroker Send a message via Yahoo to 99Smokin73Stroker
Okay even if you put a pyro in one bank and not the other, or if you put it behind the turbo, by the time the exhaust from all they cylinders goes through the turbo it'll be all mixed up and combined so you're still not going to know which bank it is! If it's a newer electronic motor you should get an SES light tripped alerting you of it anyway.
Old 01-20-2006, 03:10 AM
AYP Tires AYP Tires is offline
From what I understand the pyro guage is put in place to monitor the EGT's going into the turbo to make sure you don't burn it up. If you're gonna put a guage in I would go pre turbo for the most accurate reading.
Old 01-20-2006, 08:32 AM
with that being said who knows the temp. in which you start to do damage to the turbo. I was told about 1200 degrees but is that going into the turbo or comming out of the turbo.
Old 01-20-2006, 08:35 AM
the pyro is to make sure you dont burn anything up. As long as you understand the max temp according to where its placed you'll be ok. I am a diesel truck mechanic and almost every truck ive worked on has the pryo probe located after turbo from the factory. If it was really that "bad" of a plce to put it I dont think the manufactureer would put it there.
Old 01-20-2006, 08:36 AM
the 1200 degree max temp is AFTER the turbo.
Old 01-20-2006, 09:09 AM
thanks for all the help. I feel much mo betah hearing from other guys like yourself.
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
