ppe 6 positon chip from sinister diesel? - Ford Powerstroke Diesel Forum
post #1 of 10 Old 06-25-2014, 05:56 PM Thread Starter
SUPERDUALLY350's Avatar
so i am currently running the ts 6 position chip and im starting to hate it the first 6 months i had no problem but use my truck on the farm and some times the chip works great other times it doesn't communicate right away there is a lag when your taking off from a stop but if i unplug it a replug it in it will work fine for a day or so. so i have been looking online for a different chip and came across the ppe 6 position chip from sinster diesel. instead of plugging into the back of the computer it plugs into the port that you hook up a scan tool on so im thinking ill get a way better connections. I guess i am just wondering if it a good chip and whos running one.
or the edge juice? i like the safety features they have
SUPERDUALLY350 is offline
post #2 of 10 Old 06-25-2014, 06:13 PM
scagle1's Avatar
First i've heard of anything PPE on a powerstroke. Doesnt mean much tho......
I know PPE hardware is pretty nasty on the duramaxes but have not heard of anyone running it on ours. Buddy has on 08 bowtie and runs level 2 on his and its quick , he had level 3 for awhile and dropped it back down. One of the car shows on TV took a duramax motor , stuffed it into an old 65 impala ( i use the term old lightly ) , loaded PPE on it , filled it with Vegi oil and went to the track and blew the doors off some overpriced Lambo or some high dollar snazzy italian car of the sorts.
Anyway , subscribed as ive never heard of it on a Ford and am curious to boot if its the same PPE hardware.
Might wanna check into a reburn with a good company or possibility of retinning if the contacts are worn out. The tinning however doesn't really explain why it works for a few days and then quits again.
Sold 01 350 6" on 37's and mild mods, 00 X 4" on 35's, 02 f350 4" 35's modded from fan to drive shaft, ridin the 03 with nose conversion with 125k and counting upwards slowly.
Never had CNC's poo on any of it, never will.
scagle1 is offline
post #3 of 10 Old 06-25-2014, 06:27 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
Seems as though the PCM wasn't properly cleaned
The show is pimp my ride from about 6 years ago
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #4 of 10 Old 06-25-2014, 06:32 PM Thread Starter
thats why i was asking because i havent seen it either and there is just no good way to secure it to the computer and if it moves a little it dosent wanna make contact and it just moves to much when im out in the fields so i wanna maybe get a programmer being they plug into either the wiring harness or the scan tool port.
post #5 of 10 Old 06-25-2014, 06:40 PM
sbluke55's Avatar
Quoted: 575 Post(s)
Garage
I just use duct tape to hold my chip in. I think you need to check your connection at the PCM. Make sure it's clean and it's sanded down to the copper on the contacts.
01 f-250, Standard
Rev tech 4" lift,37" military wrangler Mt tires
KC diy 66, Full force 160/100 and custom tunes from PHP
Banks inner cooler and full 4" exhaust, Diy S&B intake
Diy quad feed, Hydra, Isspro boost, pyro, and fuel pressure
3/0 battery cables with military style terminals
sbluke55 is online now
post #6 of 10 Old 06-25-2014, 06:41 PM
sbluke55's Avatar
Quoted: 575 Post(s)
Garage
Also pull the keys out of the ignition when messing with the chip or you will have to find a new PCM.
01 f-250, Standard
post #7 of 10 Old 06-25-2014, 06:42 PM Thread Starter
the pcm is cleaned properly. if it had not been cleaned properly it would have done this the last 8 months. im thinking because i use it in the fields it bounces around to much and has warn the connections out this is why i would rather have one that plugs into the scan tool plug or the harness.
post #8 of 10 Old 06-26-2014, 12:38 AM
Quoted: 822 Post(s)
Bouncing around should not effect the connection. My old TS chip was actually rather difficult to remove as the semi conductor tangs were quite tight.
Corey@CNCFAB is offline
post #9 of 10 Old 06-26-2014, 04:28 AM Thread Starter
mines pretty easy to remove and can wiggle around easily
post #10 of 10 Old 06-26-2014, 05:06 AM
scagle1's Avatar
I have two chips I swap out regularly and run oilfield roads all the time without problems. I'd think if it was that loose you'd fry the PCM. Like already stated , did you tape it in good ? Mine is cut open so I don't have to remove the PCM to swap and lacking tape due to switching weekly , again without wiggle issue. Maybe you can try pinching the contacts on the chip back together some.
Pimp my ride , that may be it on the 65 Impala??? More of an Overhaulin' kinda guy , not much use for the Pimp , west coast customs, and the likes. Amost shocked that car came from the Pump show , did they bring in some real builders on that one ?
scagle1 is offline
