High pitched turbo noise - Ford Powerstroke Diesel Forum
post #1 of 10 Old 06-22-2014, 10:28 AM Thread Starter
This weekend I put a new 6637 intake on, did the CCC reroute and put on a 6 blade version of the WW2 on my late 99 and I am hearing a real high pitched turbo whistle that doesn't seem normal. Any thoughts? I also put on a gear head custom tunes chip and didn't see anywhere near the power gains after all this that I thought I would.
99 f350 7.3 4 door auto trans, 6637 intake, 4" exhaust, 6 blade compressor wheel, gearhead custom tunes, adrenaline hpop
Jgtrain4 is offline
post #2 of 10 Old 06-22-2014, 11:27 AM
Quoted: 48 Post(s)
6 blade wheels are LOUD... that combined with an open intake will make a LOT more noise than you're used to.
a tune-only 7.3 isn't going to set the world on fire. custom tunes are more about drivability than raw power
drunk on diesel is offline
post #3 of 10 Old 06-22-2014, 11:43 AM Thread Starter
Well I'm used to having an open filter I just took of the k&n. It's not really to much louder than what I had before it's just super high pitched.
Jgtrain4 is offline
post #4 of 10 Old 06-22-2014, 01:58 PM
Quoted: 27 Post(s)
As for the chip not supplying as much power as you thought, I think I've read multiple times that gear head tunes are a little more conservative but still open up the power a little bit. More of a "on the safe side" tunes but still good.
-Kris
01 cclb f-350 srw-463hp/1025ftlbs PHP Dyno (extreme tune)
leveled with 285's on 17'' XD Spy's
Autometer gauges (boost, trans, egt, fuel)
4'' straight pipe
DIY 6637
Powerstruck 160/30's
Hydra-Powerstruck and Dan K tunes
38r
CNCFab fuel & hpop lines
Sam Wyse stage 2 trans.
Originally Posted by Dave View Post
Why delete something thats truthful? Paid vendor status isnt like the mafia youre not paying for protection from negative feedback here
strokin-7.3 is offline
post #5 of 10 Old 06-22-2014, 08:26 PM
Joel's Avatar
Quoted: 10 Post(s)
It's hard to say without hearing it, but the turbo noise is probably normal, as said above.
As for power output, what are you boost and egt numbers looking like? Have you changed the fuel filter lately?
PIS 230/80's, Van Turbo with EBPV, BD Billet Wheel
Lots of money spent at RiffRaff
Dual SD fuel pumps, in tank mods, CNC Fab bowl retain kit. SDK Tunes. Isspro.
Still pretty slow, just less slow now.
Originally Posted by peixinho View Post
I love finally having my truck back... that 7.3 dog that I was driving was just not cutting it.
Joel is offline
post #6 of 10 Old 06-23-2014, 09:27 AM
scagle1's Avatar
They provide plenty of power, and comparatively are minimally less HP...... maybe....
He does not tune for maximum down low torque or the very maximum in timing he can get from my experience. Tunes run strong and are not embarrassingly Smokey. Even stock TS tunes make a very noticeable difference so if OP is not really noticing much of a difference with a chip installed then it's pretty likely something else is probably going on.
Sold 01 350 6" on 37's and mild mods, 00 X 4" on 35's, 02 f350 4" 35's modded from fan to drive shaft, ridin the 03 with nose conversion with 125k and counting upwards slowly.
Never had CNC's poo on any of it, never will.
scagle1 is offline
post #7 of 10 Old 06-23-2014, 09:42 AM
Quoted: 27 Post(s)
I agree that if he's not seeing much it's not the chip. I read OPs post and thought he got near the power everyone else gets and just expected more. I just read it differently from everyone else lol
-Kris
4'' straight pipe
DIY 6637
38r
post #8 of 10 Old 06-23-2014, 10:46 AM
scagle1's Avatar
Completely different but I know my 38r sings pretty well , never run a ww2 on a stocker so can't really comment but seems General consensus says a ww2 and open intake make for more noise / whistle.
Again OP, if you chipped it and didn't get a big grin with the results then I'd say something's wrong. Stock to chipped is a huge difference. I've run DP,No Limit,DI, and stuck with GH and Powerstruck. GH will hang with any of those mentioned while running quieter and less smokey. You have any boost numbers , or any other parameters to go off of besides it's making a noise and not very impressive driveability wise ?
scagle1 is offline
post #9 of 10 Old 06-23-2014, 02:25 PM
I have a 2000 with a new 38R and a Barder billet WW2. The turbo is much quieter than a typical 38R, and the pitch is a much higher whistle that a non ww2 38R. It sounds like what you are describing. I've heard plenty of 38R's with their distinctive moan and that's what I was expecting with the new turbo and wheel. Instead, it is much quieter, and it's a much higher pitched sound than a stock 38R. Also, I hear it (slightly) on daily driving without seeing any boost on the gauge. As I put accelerator and start seeing boost the sound gets louder and goes higher. So its not what I was expecting, but i think it's normal.
I have an aFe Intake. Power is great and comes on low, EGT's are low, I haul a heavy camper and I'm very pleased with the combo.
00 F350 Lariat CC, DRW, 2wd, 7.3 , Auto, Tru-Cool MAX tCooler, Delrale Deep Cooling Pan, JW Valve Body, aFe Stage II Intake, aFe 4 Turbo Back, Pillar Mount Gshift Gauges (Pyro, Boost, Trans), GTP38R, Barder Billet Wheel, Bellowed Pipes, EBPV pedestal, PHP Hydra, Riff Raff FRX, HPX, EBP, Swamps HV/HF IDM, Dieselsite Max AC. 2014 Lance 1191 Camper, Supersprings, HD Timbrens, Sumosprings, Front+Rear 1.5 Sway Bars, Monroe Gas Magnum Shocks, 19.5" Vision Rims, Centramatics, Sumitomo 16 Ply.
ZRX-Steve is offline
post #10 of 10 Old 06-24-2014, 03:15 PM
blue99stroker's Avatar
Quoted: 249 Post(s)
if you have the 6/6 blade (12 total) wheel its noisy.
especially cruising 5-7 psi.
99.5 f250 7.3 4x4 261k FF 160/30, PHP Hydra, S&B CAI, 4" TBE, Van Turbo with Turbo Blanket, RR Billet Wheel, Autometer Gauges, Transgo Tugger, Non-Ebpv Pedestal, 08 Tow Mirrors, Trucool.
Dad-2000 F250 7.3 4x4 111k Autometer Gauges, Superchips 1705 (Tow Safe), 6637, 4" TBE, BD Billet Wheel, Trucool.
blue99stroker is offline
