Spider Boots Popping Off - Ford Powerstroke Diesel Forum
post #1 of 12 Old 06-19-2014, 01:33 PM Thread Starter
Ok, so I did a lot of work to my truck over Memorial Day including a turbo rebuild. One issue i am having is that I am having a heck of a time keeping my clamp on the Intercooler tube where it connects to the spider on the output side of the compressor wheel. It is almost as though the turbo is making more boost than can be pushed through the Intercooler and the pressure is making the boot slide off. This is where the boot connects to the Intercooler tube and is held in place with a t bolt clamp. Thoughts?
2002 F250 CC SB 4x4 7.3L
186K Miles
CCV Mod
Fluidampr
PHP Hydra
RiffRaff FRx
AFE Stage 2
Wicked Wheel 2
Adrenaline HPOP
Evans NPG Coolant
Aeroforce Interceptor
Mishimoto Intercooler
6.0 Transmission Cooler
Red Head Steering Gear
4" Turbo Back Magnaflow
International Bellowed Up-Pipes
Dieselsite Legendary Transmission
2 Corinthians 5:15 - "and He died for all, so that they who live might no longer live for themselves, but for Him who died and rose again on their behalf"
PreciousMetals is offline
post #2 of 12 Old 06-19-2014, 01:35 PM
schlutzer's Avatar
Quoted: 18 Post(s)
Clean the boot and piping better, people are going to tell you to replace the boots but if they are in good shape that's a waste of money.
You very likely just haven't cleaned it all well enough, and not tightening it enough (do not crank the clamp super tight)
Please check out my 7.3 Enthusiast Facebook group! All are welcome!
schlutzer is offline
The Following User Says Thank You to schlutzer For This Useful Post:
PreciousMetals (06-19-2014)
post #3 of 12 Old 06-19-2014, 01:40 PM
sbluke55's Avatar
Quoted: 545 Post(s)
Garage
Spray a little hair spray on the spider and install the boot.
01 f-250, Standard
Rev tech 4" lift,37" military wrangler Mt tires
KC diy 66, Full force 160/100 and custom tunes from PHP
Banks inner cooler and full 4" exhaust, Diy S&B intake
Diy quad feed, Hydra, Isspro boost, pyro, and fuel pressure
3/0 battery cables with military style terminals
sbluke55 is offline
The Following 2 Users Say Thank You to sbluke55 For This Useful Post:
BryceB (06-21-2014), PreciousMetals (06-19-2014)
post #4 of 12 Old 06-19-2014, 01:41 PM
blue99stroker's Avatar
Quoted: 258 Post(s)
soak the boots in soapy water, that will help get some of the oil out that has saturated the boots.
if the clamps are extremely greasy/dirty clean them as well.
then when you put everything together spray the tube and boot with hair spray then tighten down.
extra boost is making the boot pop off. mine did this after i fixed my leaky up pipes
99.5 f250 7.3 4x4 261k FF 160/30, PHP Hydra, S&B CAI, 4" TBE, Van Turbo with Turbo Blanket, RR Billet Wheel, Autometer Gauges, Transgo Tugger, Non-Ebpv Pedestal, 08 Tow Mirrors, Trucool.
Dad-2000 F250 7.3 4x4 111k Autometer Gauges, Superchips 1705 (Tow Safe), 6637, 4" TBE, BD Billet Wheel, Trucool.
blue99stroker is offline
The Following User Says Thank You to blue99stroker For This Useful Post:
post #5 of 12 Old 06-19-2014, 01:45 PM Thread Starter
Thanks to all. These are brand new boots and clamps. I had heard about the hair spray trick but forgot about it. I replaced my up pipes at the same time and am seeing much more boost. I will give all a good cleaning and cover with hair spray.
186K Miles
CCV Mod
Fluidampr
PHP Hydra
RiffRaff FRx
AFE Stage 2
Wicked Wheel 2
Adrenaline HPOP
Evans NPG Coolant
post #6 of 12 Old 06-21-2014, 07:42 AM
BrodieBiking's Avatar
Brake cleaner also does a great job.
Sent from AutoGuide.com App
2002 F350 CCLB DRW
ZF6 SWAPPED!
--Southbend 1944-6OFEK
12.5in lift on 24.5's----------3" Body Lift
MBRP Dual 4"--------------Muffler Delete
K&N Intake----------------AFE Spider
Garret GTP38R BB--------- P.I.S. billet wheel
TS 6pos chip--------------NLTD tunes
P.I.S. 200cc/80%--------- P.I.S. IDM
Parrot Asteroid-------Boston Accoustic SR80's
NVX VCW 10”s------------ McIntosh MC431
Warn Manual hubs---------Bed Rails/Air tank
BrodieBiking is offline
post #7 of 12 Old 06-21-2014, 09:27 AM
Joel's Avatar
Quoted: 10 Post(s)
Brake cleaner is great for making sure everything is 100% clean.
The hair spray helps it all stick together.
PIS 230/80's, Van Turbo with EBPV, BD Billet Wheel
Lots of money spent at RiffRaff
Dual SD fuel pumps, in tank mods, CNC Fab bowl retain kit. SDK Tunes. Isspro.
Still pretty slow, just less slow now.
Originally Posted by peixinho View Post
I love finally having my truck back... that 7.3 dog that I was driving was just not cutting it.
Joel is offline
post #8 of 12 Old 06-21-2014, 08:01 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
CCV mod, go ahead and stop letting the oil saturate
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #9 of 12 Old 08-09-2014, 03:45 AM Thread Starter
Yeah, I did the CCV mod at the same time I did all the other stuff. Thinking about this more, if the boot keeps sliding off at higher boost pressures, would that not mean that the pressure is being restricted at some point?
186K Miles
CCV Mod
Fluidampr
PHP Hydra
RiffRaff FRx
AFE Stage 2
Wicked Wheel 2
Adrenaline HPOP
Evans NPG Coolant
post #10 of 12 Old 08-09-2014, 04:21 AM
schlutzer's Avatar
Quoted: 18 Post(s)
Nope... just means the boot can't hold the pressure...
