Question for PHP Hydra users. - Ford Powerstroke Diesel Forum
 5Likes
post #1 of 14 Old 06-15-2014, 12:58 PM Thread Starter
Quoted: 3 Post(s)
Got it installed on my truck this morning. Playing with the tunes, how long does it take for the tunes to "change" do you need to turn truck off than back on? It appears sitting in my driveway there is no difference at idle in "lope tune" and "Whisper" but I just toggled back and forth without starting it again.
Thank you!
r33pwrd is offline
post #2 of 14 Old 06-15-2014, 01:06 PM
McKinneyMike's Avatar
Following. My PHP Hydra is scheduled to arrive non Tuesday.
r33pwrd likes this.
2000 F250 SD 2WD 7.3L
RiffRaff billet compressor wheel
PHP Hydra
4" Diamond Eye, turbo back w/5" tip
ISSPRO EV2 Pyro, Trans Temp, Boost and Fuel Press
Kenwood Exelon/Focal/Image Dynamics/PPI
McKinneyMike is offline
post #3 of 14 Old 06-15-2014, 01:13 PM Thread Starter
Quoted: 3 Post(s)
I will say install was super easy. Once I figured out the whole hex code thing it took all of 20 minutes to install. Once thing I will say is remove the ECU bolt and harness with your right hand... will make life much easier
r33pwrd is offline
post #4 of 14 Old 06-15-2014, 01:20 PM
It only takes a couple seconds for the tunes to change. Mine slightly flashes or dims between tunes. You can switch between all of php tunes with the truck running.
If you get tunes from someone else, you will have to shut the truck off and restart in that tune. If You change from php tune to another tune, ( like beans, tony wildman) without shutting the truck off, it will stumble or die. At least that's what mine does.
r33pwrd likes this.
Redstroke188 is offline
post #5 of 14 Old 06-15-2014, 01:20 PM
schlutzer's Avatar
Quoted: 18 Post(s)
Takes about 1 second for the tunes to change. There has to be a delay so it doesn't try and change tunes while your are cycling through.
And no its on the fly, you just change the tune whenever you want. Just not a good idea while accelerating.
r33pwrd likes this.
Please check out my 7.3 Enthusiast Facebook group! All are welcome!
schlutzer is offline
post #6 of 14 Old 06-15-2014, 02:04 PM
sbluke55's Avatar
Quoted: 548 Post(s)
Garage
The instructions on the hex code or lack there of. Was the hardest part.
r33pwrd likes this.
01 f-250, Standard
Rev tech 4" lift,37" military wrangler Mt tires
KC diy 66, Full force 160/100 and custom tunes from PHP
Banks inner cooler and full 4" exhaust, Diy S&B intake
Diy quad feed, Hydra, Isspro boost, pyro, and fuel pressure
3/0 battery cables with military style terminals
sbluke55 is offline
post #7 of 14 Old 06-15-2014, 02:30 PM Thread Starter
Quoted: 3 Post(s)
Thanks Guys. I am using the Php stock tunes. Just drove truck and WOW was that the best $375 I have ever spent or what! The lope idle tune simple does not appear to do anything but ow well... the 80hp tune make the truck feel like a whole new machine!!
Cant wait to try out the towing tunes on Friday
2001 F-350 4x4 7.3
2015 AXIS A24 surf boat
2012 Keystone Outback Travel trailer
r33pwrd is offline
post #8 of 14 Old 06-17-2014, 01:36 PM
Jerrybizzle's Avatar
Quoted: 23 Post(s)
You'll be impressed. 65 tow tune is the one I use most with similar weights to what you'll be towing.
r33pwrd likes this.
2012 f250CCLB, 35x12.5/17 Kanati mud hogs on race line assault wheels, 2 inch lift
Mini maxx
Jerrybizzle is offline
post #9 of 14 Old 06-19-2014, 07:35 PM
I also just installed my Hydra chip. Love the power output. Huge difference.
Having some torque converter problems though. It also seems like my idle is higher than normal when in drive. Also sometimes wont come out of the high idle tune without shutting the truck off.
99' F-350 CCLB 92,100 miles ▬ 05 headlights 4" exhaust 6637 Gauges F650 dash blue LED interior HID Headlights & offroad lights 20" LED lightbar PHP Hydra 08 Taillights
97' F-450 Powerstroke 4x4
03' Peterbilt 379 650+ CAT
02' Cummins 3500 flatbed
peter379 is offline
post #10 of 14 Old 06-19-2014, 08:33 PM
Quoted: 780 Post(s)
Anyone else following, I have these in stock for $375.
Corey@CNCFAB is offline
