Installed 6 pos chip and some odd things - Ford Powerstroke Diesel Forum
post #1 of 14 Old 06-11-2014, 08:23 PM Thread Starter
700xxmaniac's Avatar
Soo I just finally got my truck back together, bts 4r100, walbro fuel pump and a 6pos chip got the bts and a chip together from a friend of a friend. Anyhow all runs amazing but when I put the chip in my water in fuel light came on, the idle seamed to change, There seams to be no rev limiter in park, and stock setting on the chip has less power then "stock".. My first thought is the chips burnt for a obs or singal shots.. Anyone got any input?
Sent from AutoGuide.com App
99 ford f-250 crew cab powerstroke
-skyjacker 6'' lift
- 395-70r-16 mickey tomson baja mtz
-sct tune
-stright pipe (vrrrooom)
-cops are in love with the thing
08 TRX700XX
-uni
-primary drive 13t
-pclll
-cp 11:1
01 recon es 250
-kenda 22'' bear claw
-53mph top speed
700xxmaniac is offline
post #2 of 14 Old 06-11-2014, 08:47 PM
ADMIN AND TECH
SCUFFY828's Avatar
The chip doesn't match ur calibration would be my guess
ITS STOCK
SCUFFY828 is offline
post #3 of 14 Old 06-11-2014, 08:55 PM Thread Starter
What ya mean by that?
-skyjacker 6'' lift
-sct tune
08 TRX700XX
-uni
-primary drive 13t
-pclll
-cp 11:1
01 recon es 250
-53mph top speed
post #4 of 14 Old 06-11-2014, 08:56 PM
79 toy's Avatar
No rev limiter in park?
79 toy is offline
post #5 of 14 Old 06-11-2014, 09:07 PM
ADMIN AND TECH
SCUFFY828's Avatar
The chip from a friend of a friend doesn't match the calibration in you're truck Software issue
ITS STOCK
post #6 of 14 Old 06-11-2014, 09:19 PM Thread Starter
Well it rev to 4k scared the **** outa me didn't see if I would go higher.. In drive it'll shift at 3,100ish..
-skyjacker 6'' lift
-sct tune
08 TRX700XX
-uni
-primary drive 13t
-pclll
-cp 11:1
01 recon es 250
-53mph top speed
post #7 of 14 Old 06-11-2014, 09:20 PM Thread Starter
Only difference in the trucks is his is a 01 mines a late 99 never asked about his injectors tho..
-skyjacker 6'' lift
-sct tune
08 TRX700XX
-uni
-primary drive 13t
-pclll
-cp 11:1
01 recon es 250
-53mph top speed
post #8 of 14 Old 06-11-2014, 09:25 PM
Jerrybizzle's Avatar
Quoted: 21 Post(s)
PCM codes need to match or be compatible. Otherwise won't run right.
2012 f250CCLB, 35x12.5/17 Kanati mud hogs on race line assault wheels, 2 inch lift
Mini maxx
Jerrybizzle is offline
post #9 of 14 Old 06-11-2014, 09:28 PM
ADMIN AND TECH
SCUFFY828's Avatar
What he said. Your calibration isn't correct
ITS STOCK
post #10 of 14 Old 06-11-2014, 09:41 PM Thread Starter
I got another PCM, it's my old one but it has a flash tune on it and I got no way to remove it. that's why I didn't use it and got this out out of roll over. I think it was a early 99.. If I put the chip in the old PCM would it override the flash tune? I don't wana be "staking chips" I've seen that take out a cummins bottom end!
-skyjacker 6'' lift
-sct tune
08 TRX700XX
-uni
-primary drive 13t
-pclll
-cp 11:1
01 recon es 250
-53mph top speed
