sump install questions - Ford Powerstroke Diesel Forum
post #1 of 3 Old 06-10-2014, 11:49 PM Thread Starter
Feedback Score: -1 reviews
So the sump install is pretty straight forward. In going to run 1/2" fuel line to the strickly diesel pre pump filter setup then 3/8" from filter to pump.
Now I'm not sure what to do about the stock line. How do I go about plugging it?
2000 7.3 ccsb BTS 4r100,frx,coolant filter,custom intake,mbrp turbo back,Php FU,walbro 392,hi flow outlet,turbo master
Pro comp 6.5,bilstein 5160 front/rear,pro comp ladder bars,moto metals/37" hankooks.
n54power is offline
post #2 of 3 Old 06-11-2014, 03:30 AM
Quoted: 21 Post(s)
They make a tool to remove the gas line fittings. I believe you can get it at parts store. I used a screw driver to push the tabs back and slip the lines off.
The Next Level is offline
post #3 of 3 Old 06-11-2014, 07:45 AM Thread Starter
Getting the lines off isn't the issue.plugging it is
n54power is offline
