Turbine size and housing - Ford Powerstroke Diesel Forum
post #1 of 8 Old 06-10-2014, 09:13 AM Thread Starter
r_marczak_83's Avatar
I have a 1.15 housing and a 69mm turbine wheel. I ordered a new 1.00housing and its the stock 67.7mm turbine size. Should I try and use the old stock wheel with the new housing, or can the new housing be machined to fit the bigger wheel?
E99 F250 ex-cab 7.3
Barder 66mm/1.15 a/r turbo, EBPV delete, 4" turbo back w/ 6" SS tip, Full Force 160/100's, 17* HPOP, 140v IDM, Rebuilt 4R100, DP-Tuner, boost fooler, aFe Pro Dry S filter,CCV Mod, HID's, 20" Fuel Hostage w/ 33" Nito MT's
r_marczak_83 is offline
post #2 of 8 Old 06-10-2014, 10:38 AM
blue99stroker's Avatar
Quoted: 247 Post(s)
how come you want to switch housings? just curious.
and if you want to use the 1.0 housing get it machined to fit the bigger wheel.
99.5 f250 7.3 4x4 260k FF 160/30, PHP Hydra, S&B CAI, 4" Exhaust, RR Billet Wheel, Autometer Gauges, Transgo, Non-Ebpv Pedestal, High Flow Outlet, 08 Tow Mirrors.
Dad-2000 7.3 4x4 110k miles, Autometer Gauges, Superchips 1705, 6637, 4" Exhaust, BD Billet Wheel, TruCool Max
blue99stroker is offline
post #3 of 8 Old 06-10-2014, 01:08 PM Thread Starter
Stage 2's and 66mm turbo
E99 F250 ex-cab 7.3
post #4 of 8 Old 06-10-2014, 01:18 PM Thread Starter
I forgot you were in on that long thread so no need to read it again.
I want boost to come on a little bit sooner than it does now. The only way I like driving the truck with the 1.15 is on 140 tune
If I pull something, the truck lags up hills and i have to make it downshift or it will continually lose speed, or black smoke if it doesnt downshift.
Even without a load it is doggy at cruising speed if I need to pass or speed up. 1500-1600 is my cruising speed and the 1.15 doesnt lite till around 2000-2200.
E99 F250 ex-cab 7.3
post #5 of 8 Old 06-10-2014, 01:46 PM
The van turbo has different trim on the ex turbine than the truck turbo. The easiest is to find a new or good used ex turbine shaft from a truck turbo.
Turbine shaft
or here:
Turbine shaft
It's a direct swap to the center rotating housing assembly of the van turbo. Do you have the stock GTP38 yet? If so, just pull it apart and use the turbine shaft from that.
Dan V is offline
post #6 of 8 Old 06-10-2014, 02:04 PM Thread Starter
Turbine shaft
or here:
Turbine shaft
Thats what the stock 67.7mm assembly is. When I did the 66mm DIY kit, Barder said my .84 would cause bad drive pressure. He said he'd go with a 1.00 or a 1.15. So I went with 1.15. He then told me he was out of the 67.7mm housings in 1.15 and had a 69mm, in which he'd include a matching balanced rotating assembly.
After putting this all together, I am not satisfied with the spool up time. So now I bought a non wg 1.00 housing from Beans and it would likely be the 67.7mm wheel.
So do I put my old wheel back in, or can I utilize this new bigger wheel with some machine work. Is it even worth the hassle to machine it (is there much performance difference in 67.7mm to 69mm turbine)?
E99 F250 ex-cab 7.3
post #7 of 8 Old 06-10-2014, 02:56 PM
The 1.3mm difference is a tad over .050....almost a 1/16".
I'm having trouble figuring out what is what here. Are you saying that you have a truck turbine (67.7mm) in van housing (1.15 - 69mm)?
If I was you, and I had the 67.7mm turbine and a 67.7m 1.0 ex housing, I'd run that....In fact that's what I have....I like it WAY better than the 1.15 housing...drive pressure is 1:1....and it will make 33psi of boost with my 160/30's. I wouldn't go through the hassle of machining the 67.7mm housing to accept the 69mm turbine.
Dan V is offline
post #8 of 8 Old 06-10-2014, 03:38 PM Thread Starter
I have a truck that has the 69mm turbine and the 1.15 - 69mm housing. I have a 1.00 housing that is 67.7mm I want to put on and also have my stock 67.7 turbine out of my .84 housing.
I'll just put the old turbine back in with the new 1.00 housing.
E99 F250 ex-cab 7.3
