Help me build a monster tow rig - Ford Powerstroke Diesel Forum
 1Likes
post #1 of 20 Old 06-09-2014, 09:17 PM Thread Starter
Unhappy Help me build a monster tow rig
Hey everyone, first post here. Looks like a great place and can't wait to get involved.
I need some advice on a 2001 350 auto build. Truck will be used almost strictly for towing a 8000lb camper, occasionally with a boat behind the camper. Truck has 170k km on it, runs well but is certainly lacking power pulling grade.
Currently, I have the following plans.
Afe or k+n intake
Php tunes
Exhaust- any suggestions?
Gauges- thinking triple pod, auto meter???
What else would everyone suggest? I have 3k to play with here.
Power and reliability are key here.
Thanks everyone!
Dale7637 is offline
post #2 of 20 Old 06-09-2014, 09:28 PM
FJuanfiddy mod
Dave's Avatar
Quoted: 10 Post(s)
Skip the AFE check out the diy intake. 50 bucks and some time. Check out PHPs hydra chip. Exhaust depends on how fancy you wanna get
Sent from AutoGuide.com App
Email:
2006 F250 ECSB Lariat 4x4
Edge Insight CTS
Coolant filter
Dave is offline
post #3 of 20 Old 06-10-2014, 01:10 AM
Jerrybizzle's Avatar
Quoted: 24 Post(s)
Intake-6637 DIY ~50
Exhaust- I would suggest diamond eye and stainless if you live somewhere roads are salted. Aluminum works just fine for me as they don't use salt on the roads where I am. ~230 with no muffler
Php tunes are great, hydra is 375
Gauges- isspro or autometer are good 300-400
Right around a grand and you will notice a significant difference.
I just ordered a billet wheel which may help you as well for $200.
You shouldn't be anywhere near 3k unless the above mods leave you wanting more then you could order injectors but if you go big that opens up a whole new can of worms with necessary supporting mods.
2012 f250CCLB, 35x12.5/17 Kanati mud hogs on race line assault wheels, 2 inch lift
Mini maxx
Jerrybizzle is offline
post #4 of 20 Old 06-10-2014, 04:57 AM
FourthAxis's Avatar
Quoted: 2 Post(s)
Sounds like you're on the right track, but didn't mention trans cooler. This post might be helpful also. Towing over the Northwests mountains?
1999 CCSB, '05 front + axle, Monstalined exterior, shaved, tuned, lifted, 35s on 20s and blah blah blah
Our parts page: facebook.com/PowerstrokeParts
Email: Sebastian.Josh AT gmail.com
FourthAxis is offline
post #5 of 20 Old 06-10-2014, 09:43 AM
blue99stroker's Avatar
Quoted: 283 Post(s)
bigger trans cooler and valve body for the trans. JW or BTS valve body.
diamond eye is 230 from alligator perf like jerry said
if smog laws are an issue AFE or S&B would be my choice, if not a 6637 kit would be fine.
isspro or autometer trans temp, pyrometer, boost, and if you want fuel pressure.
billet compressor wheel from dieselsite, riffraff, or bd.
you could do some 160/0 or 160/30 single shot injectors. everything above would be a supporting mod and make it run the injectors well.
99.5 f250 7.3 4x4 265k Full Force 160/30, PHP Hydra, S&B CAI, 4" Exhaust, Van Turbo, RR 6/6 Billet Wheel, Autometer Gauges, Transgo Tugger, Non-Ebpv Pedestal, 08 Tow Mirrors, Trucool Max.
Dad-2000 F250 7.3 4x4 114k Autometer Gauges, Superchips 1705 (Tow Safe), Blue 6637, 4" Exhaust, BD Billet Wheel, Trucool Max.
blue99stroker is offline
post #6 of 20 Old 06-13-2014, 07:57 AM
Quoted: 862 Post(s)
Feedback Score: 3 reviews
If your interested I can price you out everything. Got plenty of happy Canadian customers.
Heavy_GD likes this.
Corey@CNCFAB is offline
post #7 of 20 Old 06-13-2014, 08:02 AM
dannanw's Avatar
Quoted: 66 Post(s)
Garage
6.0 trans cooler
tymar/6637/similar
4in exh (I'm getting dymond eye one of these days)
isso pro/autometer guages (trans temp, egt/pyro, and boost)
custom tunes/TS chip/sct with some custom tunes (not required but more hp/tq)
that'll get you started...but by the way 8k is nothing and you dont need anything but reg maint to pull that.
just my
What this nation needs is cleaner thoughts and dirtier fingernails...
dannanw is offline
post #8 of 20 Old 06-13-2014, 11:24 AM
heykw's Avatar
4.10 gears with stock size tires?
Excursion 02 4x4 Silverline exaust superchip tuner
Excursion 2000 4x4 300K miles 238/100 P.I.S. Injectors 38RW/ billet wheel dyno proven tunes
99 F350 7.3 4x4 body build date 02/98 motor build date 12/97 19.5 ricksons (Sold)
heykw is offline
post #9 of 20 Old 06-16-2014, 07:35 AM
Quoted: 3 Post(s)
I just added...
-MBRP 4" turbo back
-PHP Hydra (with the php tunes)
-EGT and Boost gauges
I will be towing my trailer on Friday again (last towed the truck was stock on 35s) I can tell you that just driving the truck around if feels way better. My trailer is right at 8K lbs as well. Stock it towed it okay but big hills where a workout for sure.
2001 F-350 4x4 7.3
2015 AXIS A24 surf boat
2012 Keystone Outback Travel trailer
r33pwrd is offline
post #10 of 20 Old 06-16-2014, 07:55 AM
BryceB's Avatar
Quoted: 2 Post(s)
I'll parrot what the others said....
Intake: Tymar/6637 or Ford AIS
Exhaust: 4" turbo back... don't worry about brand
Gauges: EGT, TFT, Boost
Tunes: Get some specific Tow tunes - I like my PHP Tunes
Cooling: 6.0 Trans cooler in place of the stock (26 or 31 row)
Brake Controller: Get a good one, I like my Tekonsha Prodigy
Hitch: Get a quality WDH with sway control for the Travel Trailer.
2001 Ford F-250 SD CCSB 7.3 PSD - AIS Intake, Zoodad,
MBRP 4" XP Series Exhaust w/ Muffler, HD4R100, 26 row Trans Cooler, Fumoto Valve,
285/75R16E BFG AT KO, Pioneer AVIC-Z130BT Nav, BOYO VLT-422C Back Up Camera,
Scangauge II, Glowshift 3 Gauge Pod (EGT,TFT,Boost), PHP FU Chip, Huskyliners, Huskyliner Mud Flaps, Warn Premium Hubs, Riffraff Boots/Clamps/inserts
Dyno'd at Mo's Speed Shop 11/3/12 - 307rwhp / 651rw ft-lbs <<<--- On PHP 120Race tune
BryceB is offline
