Parts on the way!! - Ford Powerstroke Diesel Forum
post #1 of 11 Old 06-09-2014, 08:24 PM Thread Starter
Jerrybizzle's Avatar
Quoted: 23 Post(s)
Parts on the way!!
Finally ordered some things I have been needing and some other things I've wanted. Here's the list.
New oem battery cables as mine are badly corroded.
Tru cool transmission cooler. (Plan to put in series with stock)
New belt
Riffraff billet wheel (had a friend who just bought one and used an impact wrench to change his. Have heard this isn't ideal, but please tell me how to otherwise do it or even link a video.)
May also add new glow plug relay if I end up having some leftover money.
Pics to follow in a few days when remaining parts show up and I have time to install. Summers are busy. I will take any tips/advice to help with any of the installs.
Thanks,
Jerry
2012 f250CCLB, 35x12.5/17 Kanati mud hogs on race line assault wheels, 2 inch lift
Mini maxx
Jerrybizzle is offline
post #2 of 11 Old 06-10-2014, 10:49 AM
blue99stroker's Avatar
Quoted: 249 Post(s)
nice! its fun getting new parts.
the "corrrect" way is to hold the exhaust turbine and loosen the compressor wheel with a ratchet, or use an air ratchet whatever to get it loose.
heard of lots of folks just shoving a screwdriver wrapped in a towel or sock in the ex wheel to hold it tight.
or just remove the turbo, which makes it easier.
let me know how the tru cool runs, im going to get one for my dad when i can afford to.
99.5 f250 7.3 4x4 261k FF 160/30, PHP Hydra, S&B CAI, 4" TBE, Van Turbo with Turbo Blanket, RR Billet Wheel, Autometer Gauges, Transgo Tugger, Non-Ebpv Pedestal, 08 Tow Mirrors, Trucool.
Dad-2000 F250 7.3 4x4 111k Autometer Gauges, Superchips 1705 (Tow Safe), 6637, 4" TBE, BD Billet Wheel, Trucool.
blue99stroker is offline
post #3 of 11 Old 06-10-2014, 11:32 AM
sbluke55's Avatar
Quoted: 525 Post(s)
Garage
I just built a set of battery cables for my truck and my step dad's truck. The positive cable came out to around $75. You might want to look into that. It's half price.
01 f-250, Standard
Rev tech 4" lift,37" military wrangler Mt tires
KC diy 66, Full force 160/100 and custom tunes from PHP
Banks inner cooler and full 4" exhaust, Diy S&B intake
Diy quad feed, Hydra, Isspro boost, pyro, and fuel pressure
3/0 battery cables with military style terminals
sbluke55 is offline
post #4 of 11 Old 06-10-2014, 12:38 PM Thread Starter
Quoted: 23 Post(s)
That's not bad. Mine were a total of 130 for both positive and negative.
Mini maxx
post #5 of 11 Old 06-10-2014, 12:39 PM
sbluke55's Avatar
Quoted: 525 Post(s)
Garage
Well that's not bad at all. I got quoted $180 local for just the positive. So I wouldn't worry about it then.
01 f-250, Standard
sbluke55 is offline
post #6 of 11 Old 06-10-2014, 03:26 PM Thread Starter
Quoted: 23 Post(s)
Amazon and rock auto had them about the same price. Any tips on changing them, or just unbolt the top part of the radiator?
Mini maxx
post #7 of 11 Old 06-10-2014, 06:11 PM
heykw's Avatar
Post some pics of the cables
Excursion 02 4x4 Silverline exaust superchip tuner
Excursion 2000 4x4 300K miles 238/100 P.I.S. Injectors 38RW/ billet wheel dyno proven tunes
99 F350 7.3 4x4 body build date 02/98 motor build date 12/97 19.5 ricksons (Sold)
heykw is offline
post #8 of 11 Old 06-10-2014, 06:26 PM
BryceB's Avatar
Be careful on the starter end. The plastic on the lug gets hot down there and causes it to get brittle. When I went to remove the nut, the plastic just crumbled. I ended up having to replace the starter too.
Ya, just pull the stuff off the top of the radiator and replace.
2001 Ford F-250 SD CCSB 7.3 PSD - AIS Intake, Zoodad,
MBRP 4" XP Series Exhaust w/ Muffler, HD4R100, 26 row Trans Cooler, Fumoto Valve,
285/75R16E BFG AT KO, Pioneer AVIC-Z130BT Nav, BOYO VLT-422C Back Up Camera,
Scangauge II, Glowshift 3 Gauge Pod (EGT,TFT,Boost), PHP FU Chip, Huskyliners, Huskyliner Mud Flaps, Warn Premium Hubs, Riffraff Boots/Clamps/inserts
Dyno'd at Mo's Speed Shop 11/3/12 - 307rwhp / 651rw ft-lbs <<<--- On PHP 120Race tune
BryceB is offline
post #9 of 11 Old 06-11-2014, 10:29 AM Thread Starter
Quoted: 23 Post(s)
http://www.amazon.com/gp/aw/d/B000C5FWYC/ref=mp_s_a_1_1?qid=1402507651&sr=8-1http://www.amazon.com/gp/aw/d/B000C5FW4W/ref=mp_s_a_1_1?qid=1402507723&sr=8-1Kind of a pain to load pics off my iPhone so if you want pics quick just pm your cell number and I can send it your way.
Mini maxx
post #10 of 11 Old 06-11-2014, 07:36 PM Thread Starter
Quoted: 23 Post(s)
Well I got the transmission cooler in. Mounting was straight forward. Wasn't sure if the tranny fluid would leak without pressure, it does. There isn't a whole lot of rubber tube available to cut, but got it cut and the cooler plumbed. Will be driving it tomorrow and checking fluid level to see if I need to add a quart or more.
Mini maxx
