New tuner looking for tune help for hydra chip - Ford Powerstroke Diesel Forum
 1Likes
post #1 of 14 Old 06-09-2014, 02:48 PM Thread Starter
I have an 01 350 7.3. I tow a tandem axle 14' trailer filled with several thousand pounds of tools, and since the old girl has 300k miles I decided I'd give her some power upgrades to make things easier. Thus far : cold air intake (not K&N ) 4" straight pipe exhaust, a set of auto meter gauges trans temp, pyrometer and boost, and lastly a hydra chip.
The Hydra chip is my stumbling block. I am new to the tuning thing completely and was hoping some of you educated tuners could point to the better tunes in the hydra library for a stock 7.3
I'm aiming for an economy, towing, heavy towing, performance, high performance and smoke tune mix on the chip.
Now I must clarify I have no intention of smoking with the truck. But I want it just in case some liberal has the nerve to approach me at a Mcdonalds drive through and tell me to turn my truck off because the "fumes" were obnoxious (this is a 100% stock truck btw, clean exhaust no smoke etc). Next time that happens I'm going to be prepared with the smoke setting!!
rfunk1983 is offline
post #2 of 14 Old 06-10-2014, 08:29 AM
CSIPSD's Avatar
Not sure what your asking???
Are you having issues loading tunes from PHP's software library or are you looking for a different tuner to buy tunes from?
01 F-250 SC PSD,320k,16 Isspro Gauges, AFE-2,CCV Mod,IAH delete,map reg,Modded H2e, 6.0 IC, 230/100 from P.I.S, Studs, 910 springs, Forged rods, Water injection,Hydra chip-No Limit/Gearhead tuning, Swamps HVHF IDM, MBRP 4" dual's, Aero, 6" tip's, 4" Revtek lift, 37/12.5/16.5 MT's
Joe
DYNOPROVEN.COM, PERFORMANCEINJECTIONSYSTEMS.COM and RIFFRAFFDIESEL.COM
CSIPSD is offline
post #3 of 14 Old 06-10-2014, 07:12 PM Thread Starter
Well I'm learning about tuning on the fly. I purchased the Hydra based on the amount of positive feedback it had from people on the forums. It was a toss up between a TS, DP or Hydra tuner for me. Tony Wildman has a lot of praise as well and he was selling the Hydra on his site Total Diesel Performance
I understand the Hydra flash program but there are a million tunes in their standard library! I am using the vraaa tunes atm but I don't like the way the transmission shifts with them.
post #4 of 14 Old 06-11-2014, 06:15 AM
If you don't like the PHP tune for your calibration, then try one from Gearhead. He'll write you a tune and email it to you, just as others will. Except DP and Dyno Proven.
Dan V is offline
post #5 of 14 Old 08-06-2014, 04:03 PM
tunes
with the Hydra there are only about 6-8 tunes that go with your hex code, it took me a while to figure that out.
psanfioren is offline
post #6 of 14 Old 08-06-2014, 07:50 PM
sbluke55's Avatar
Quoted: 502 Post(s)
Garage
That's not correct. I only had a few tunes for my hex code and I emailed jay and they corrected it after I brought it to their attention. Make sure you enter in your hex code into the converter and it will tell you the exact code the use but if you look a little farther down the page there is a recommended code to use. Use that one. If it is blank use the top code. If you have any questions just email jay and he will help you. Stand up people.
CSIPSD likes this.
01 f-250, Standard
Rev tech 4" lift,37" military wrangler Mt tires
KC diy 66, Full force 160/100 and custom tunes from PHP
Banks inner cooler and full 4" exhaust, Diy S&B intake
Diy quad feed, Hydra, Isspro boost, pyro, and fuel pressure
3/0 battery cables with military style terminals
sbluke55 is offline
The Following User Says Thank You to sbluke55 For This Useful Post:
Corey@CNCFAB (08-08-2014)
post #7 of 14 Old 08-06-2014, 08:47 PM
tunes
so how many tunes do you have for your hex code?
post #8 of 14 Old 08-06-2014, 08:51 PM
sbluke55's Avatar
Quoted: 502 Post(s)
Garage
Over 20. There is some towing ones, daily driver ones, high idle ones, valet ones, and some others.
01 f-250, Standard
sbluke55 is offline
post #9 of 14 Old 08-06-2014, 08:53 PM
tunes
thanks, i will give them a call tomorrow
post #10 of 14 Old 08-06-2014, 10:44 PM
Quoted: 728 Post(s)
To the Op, you can also run any set of tunes from the PHP library that is associated withe the same PCM code. For example if you have an xle4 on your PCM, which would be a dpc-402. Well you'll then be able to run any box code that also uses the same DPC-402. So you can then run any xle* box code.
The only slight issue from using tunes from different box code updates is that your engine may romp or stall while switching between them.
Corey@CNCFAB is offline
