HPOP spacer - Ford Powerstroke Diesel Forum
post #1 of 10 Old 06-08-2014, 02:57 PM Thread Starter
Joel's Avatar
Quoted: 10 Post(s)
HPOP spacer
I see RiffRaff has an HPOP reservoir spacer to increase the capacity of a stock or modded hpop.
Does anyone have any experience with this, and is it a worthwhile upgrade to a stock hpop?
Is it a possible substitute for a T500 with an injector in the 160/80 to 180/100 range?
PIS 230/80's, Van Turbo with EBPV, BD Billet Wheel
Lots of money spent at RiffRaff
Dual SD fuel pumps, in tank mods, CNC Fab bowl retain kit. SDK Tunes. Isspro.
Still pretty slow, just less slow now.
Originally Posted by peixinho View Post
I love finally having my truck back... that 7.3 dog that I was driving was just not cutting it.
Joel is offline
post #2 of 10 Old 06-09-2014, 10:33 AM
CSIPSD's Avatar
I've had one for quite some time. It does not help maintain pressure as much as it makes sure the HPOP has all the oil it needs...
01 F-250 SC PSD,320k,16 Isspro Gauges, AFE-2,CCV Mod,IAH delete,map reg,Modded H2e, 6.0 IC, 230/100 from P.I.S, Studs, 910 springs, Forged rods, Water injection,Hydra chip-No Limit/Gearhead tuning, Swamps HVHF IDM, MBRP 4" dual's, Aero, 6" tip's, 4" Revtek lift, 37/12.5/16.5 MT's
Joe
DYNOPROVEN.COM, PERFORMANCEINJECTIONSYSTEMS.COM and RIFFRAFFDIESEL.COM
CSIPSD is offline
post #3 of 10 Old 06-09-2014, 11:22 AM Thread Starter
Joel's Avatar
Quoted: 10 Post(s)
How do I know if my hpop has all the oil I need? It seems to keep up ok in all but the hot tune I have.
For $200 I don't want to throw it on there just to see, when that money could be going towards a honey badger or something down the road.
Cummon guys, I'm trying to get some interesting conversation going over here. The org has been a snooze fest lately
Joel is offline
post #4 of 10 Old 06-09-2014, 01:47 PM
r_marczak_83's Avatar
I would like to know also.
E99 F250 ex-cab 7.3
Barder 66mm/1.15 a/r turbo, EBPV delete, 4" turbo back w/ 6" SS tip, Full Force 160/100's, 17* HPOP, 140v IDM, Rebuilt 4R100, DP-Tuner, boost fooler, aFe Pro Dry S filter,CCV Mod, HID's, 20" Fuel Hostage w/ 33" Nito MT's
r_marczak_83 is offline
post #5 of 10 Old 06-09-2014, 02:07 PM
layson's Avatar
Quoted: 82 Post(s)
It is mainly setup for the twin pump setup that way both pumps get what they need. It relocates where the rear pump sucks oil from. Right now without the spacer it pulls it from the top of the reservoir.
Either way even for a stock/modded pump it isn't going to hurt anything running it. But I doubt you would notice a difference. You would have to watch to see if your LPOP is actually keeping up. Pressure gauge or if you can actually see your needle on your dummy gage dropping when you step on it.
2001 - 14" OUO 525 - 38x15.5x20 Toyo & 20x12 Weld Cheyenne's. Hybrids, 38R, BTS, Spearco, Terminators..
Quote of the Day:
Originally Posted by Mannysouza View Post
You will get some axle wrap with a heavy trailer, I can feel it when towing my gooseneck with some heavy equipment. My Deavers will wrap enough to make the tires rub the front of the rear fender well if I give it too much throttle on aceleration.
layson is offline
post #6 of 10 Old 06-09-2014, 05:09 PM Thread Starter
Joel's Avatar
Quoted: 10 Post(s)
I can't imagine the dummy gauge dropping at all when you step on it due to the raise in RPM.
I guess this part is reserved for the big boys or posers with too much money. Haha
Joel is offline
post #7 of 10 Old 06-10-2014, 08:27 AM
CSIPSD's Avatar
LOL... Its a nice piece, but without having dual pumps or wanting an easy place to get oil for a twin turbo set up I dont see it being needed.
Joe
CSIPSD is offline
post #8 of 10 Old 06-10-2014, 08:27 AM
CSIPSD's Avatar
It also allows the guys without filters to run the filters (OBS and E99 guys do not have a HPO filter, its just a screen but its still a filter)...
This includes me with my OBS motor...
Joe
CSIPSD is offline
post #9 of 10 Old 06-10-2014, 09:50 AM
layson's Avatar
Quoted: 82 Post(s)
Well, if you are running dual pumps and you do see the gage move then you got a problem...LOL
It is a nice piece and like Joe says it is great upgrade for the OBS guys so they can add a filter. Plus there are also ports to add things for gages and such.
I do think you may have to get rid of the stock fuel bowl to run it.
Quote of the Day:
layson is offline
post #10 of 10 Old 06-11-2014, 08:07 PM
Quoted: 770 Post(s)
Money better spent would be a Melling M208 lpop. Its high volume to keep the reservoir full.
Corey@CNCFAB is offline
