PHP Hydra programming cable - Ford Powerstroke Diesel Forum
 5Likes
post #1 of 23 Old 06-07-2014, 06:12 AM Thread Starter
McKinneyMike's Avatar
Is this a special cable of some sort? $25.00 just seems a bit rich for what could possibly be a standard type cable. From the photos it looks to be a printer cable with a Type D connector on one end and a USB connector on the other end. Does anyone know?
2000 F250 SD 2WD 7.3L
RiffRaff billet compressor wheel
PHP Hydra
4" Diamond Eye, turbo back w/5" tip
ISSPRO EV2 Pyro, Trans Temp, Boost and Fuel Press
Kenwood Exelon/Focal/Image Dynamics/PPI
McKinneyMike is offline
post #2 of 23 Old 06-07-2014, 07:36 AM
Your Analysis is correct. They are standard USB cables. I purchased the extra cable from PHP to mount permanently under the steering wheel. After mounting it, I realized... the kit didn't have the now required male version of the cable to connect from the one I purchased from PHP and mounted to the bottom of the steering wheel to the computer. I believe what you call USB printer is a type A cable. I didn't have one, so I had to buy one. The kit should have come with all the cables.
In summary, you're correct, it's all standard USB.
McKinneyMike likes this.
00 F350 Lariat CC, DRW, 2wd, 7.3 , Auto, Tru-Cool MAX tCooler, Delrale Deep Cooling Pan, JW Valve Body, aFe Stage II Intake, aFe 4 Turbo Back, Pillar Mount Gshift Gauges (Pyro, Boost, Trans), GTP38R, Barder Billet Wheel, Bellowed Pipes, EBPV pedestal, PHP Hydra, Riff Raff FRX, HPX, EBP, Swamps HV/HF IDM, Dieselsite Max AC. 2014 Lance 1191 Camper, Supersprings, HD Timbrens, Sumosprings, Front+Rear 1.5 Sway Bars, Monroe Gas Magnum Shocks, 19.5" Vision Rims, Centramatics, Sumitomo 16 Ply.
ZRX-Steve is offline
The Following User Says Thank You to ZRX-Steve For This Useful Post:
McKinneyMike (06-07-2014)
post #3 of 23 Old 06-07-2014, 07:42 AM Thread Starter
Thank you. After looking closer you are correct it is not a Type D printer on one end it is a dual USB connector. I am cheap what can I say
PHP Hydra
post #4 of 23 Old 08-20-2014, 07:19 AM
a_thiel24's Avatar
After a little research I believe it is a Mini USB 5 pin Male to USB B Female. I'm not a cable expert by any means. I just started searching based on pictures.
-Alex
Early 1999 F-350 7.3
6 speed ZF-6
4" MBRP turbo back
S&B CAI
PHP Hydra
Insight CTS
305/70/15 BFG AT
2" leveling kit
a_thiel24 is offline
post #5 of 23 Old 08-20-2014, 07:43 AM
CSIPSD's Avatar
It is not just the cable your getting. Your getting the mount so you can hard mount it as well. The cable is also not available right off the shelf anywhere I have looked. It has a hard 90* at the chip side so once connected it can be slid into the J3 port of the PCM. You wont get a standard plug in there.
IMHO with the cost of fuel these days, $25 for the cable, and mount is cheap...
01 F-250 SC PSD,320k,16 Isspro Gauges, AFE-2,CCV Mod,IAH delete,map reg,Modded H2e, 6.0 IC, 230/100 from P.I.S, Studs, 910 springs, Forged rods, Water injection,Hydra chip-No Limit/Gearhead tuning, Swamps HVHF IDM, MBRP 4" dual's, Aero, 6" tip's, 4" Revtek lift, 37/12.5/16.5 MT's
Joe
DYNOPROVEN.COM, PERFORMANCEINJECTIONSYSTEMS.COM and RIFFRAFFDIESEL.COM
CSIPSD is offline
post #6 of 23 Old 08-20-2014, 08:23 AM
lightning95's Avatar
I used a regular 3 foot cable I had laying around and tied it up under the dash. I can not slide the chip out of the computer with the cable hooked up but never plan to either.
a_thiel24 likes this.
02 F-250 ccsb 7.3 auto, 8" fabtech, 37" toyo, 4.30, 4" straight pipe, AFE intake, hydra chip, riff raff wheel, tugger kit and powerstruck tunes.
95 Lightning fast by NX nitrous
07 Yamaha R1
lightning95 is offline
post #7 of 23 Old 08-20-2014, 02:32 PM
Chatham036's Avatar
Quoted: 136 Post(s)
When we first brought the extension cable option out, we didnt include the cable to attach to the computer from the extension due to the thought that with the present day acceptance of technology, everyone would have a printer in home. This cable needed is just simply a printer cable.
Due to the feedback that we have been getting about our customers inquiring about the cable and why it is not included, we have started to include the cable
If anyone has any feedback on something that they think would be a beneficial feature to the hydra chip / hydra system.. please shoot me a PM! I am always looking for ways to make our product more user friendly
Comments or opinions expressed by me do not necessarily represent the views of PHP, its management, nor its employees. PHP is not responsible for, and disclaims any and all liability for the content of comments written by me.
Chatham036 is offline
post #8 of 23 Old 08-20-2014, 03:21 PM Thread Starter
They are readily available and less than $10.00. Not hard to find at all.
StarTech USB2HABM6RA 6 ft. Black Mini USB Cable - A to Right Angle Mini B - Newegg.com
PHP Hydra
post #9 of 23 Old 08-20-2014, 06:45 PM
hansel's Avatar
Quoted: 99 Post(s)
That's not the exact same cable you get from PHP but it will work by plugging right into your laptop.
2001 7.3L CCSRW 4X4
Airiad Intake 4" Flo-Pro Exhaust
ISSPRO EGT/Transmission
PHP Hydra
2015 Heartland Prowler
hansel is offline
post #10 of 23 Old 08-20-2014, 10:43 PM
Quoted: 818 Post(s)
Jay, when are the cables getting put with the Hydra. I just ordered more to restock. So I'm assuming they won't be in this batch???
Thx.
Corey@CNCFAB is offline
