Anyone with a PHP chip - Transmission question - Ford Powerstroke Diesel Forum
post #1 of 22 Old 06-05-2014, 07:39 PM Thread Starter
Programmer/Transmission question
I hate to start another thread about programmers/chips because theyre everywhere, but I did a search and couldnt find exactly what im looking for. I have a 2000 F350 with an automatic transmission. From what ive heard its best to run custom tunes with trucks with an AT so it doesnt slam gears - is this true? Ive heard good things about PHP chips, but are they custom tunes? Any other suggestions of what direction I should head in?
Thanks
Penreuder is offline
post #2 of 22 Old 06-05-2014, 08:15 PM
Im_Strokin_ur_Cummins's Avatar
Location: Lowville, New York. Studying Mechanical Eng. @ Suny Canton
Aparently you didnt search hard enough because there are multiple threads that answer both questions. Yes running custom tunes is better compaired to "canned" tunes, Php is does make custom tunes for your truck you tell them the mods,pcm code, year, tire size etc.. and they write the tunes, all they currently have is the hydra since they discontinued the 6pos phionex chip but there are a few place that might still have them. The hydra is defantly worth looking into, if i had the extra cash id bought that instead being you can put 17 tunes from who ever you want onto it from your computer and not have to send it back to have them burn it.
FUELED BY HATERS
Jack'em up high.Fat chicks cant jump!
E99 7.3 F-250XLT
304,345 miles and still running strong
ext cab
DIY 6637 Intake
5in straight pipe to Aussie stacks
PHP 6pos
Boost,tran,and EGT Gauges
4in lift
Some body rust and oil leaks
CB radio
Pretty Girl sittin next to me
Im_Strokin_ur_Cummins is offline
post #3 of 22 Old 06-05-2014, 08:56 PM Thread Starter
I guess I didnt use the right keywords? Anyway, thats besides the point. I appreciate the help, just looking for a little wake up call for my bone stock motor, Ive only had the truck less than a month so I know little to none about the PSD. $375 for the hydra seems like a good deal. Does the $375 include the 17 tunes? Do they just send you files to your computer and you flash them? Is this an on-the-go type deal where you push a button and it instantly changes tunes? Will this sacrifice any longevity on a stock motor?
Thanks
post #4 of 22 Old 06-06-2014, 02:13 AM
Quoted: 725 Post(s)
Does not come with any tunes. It comes with access to all the stock custom files on php's server. You download them.
Corey@CNCFAB is online now
post #5 of 22 Old 06-06-2014, 04:20 AM
scagle1's Avatar
Go with any of the big name tuners and then order a John Wood valve body , transmission issues will be solved with it.
Sold 01 350 6" on 37's and mild mods, 00 X 4" on 35's, 02 f350 4" 35's modded from fan to drive shaft, ridin the 03 with nose conversion with 125k and counting upwards slowly.
Never had CNC's poo on any of it, never will.
scagle1 is offline
post #6 of 22 Old 06-06-2014, 09:12 AM
Jerrybizzle's Avatar
Quoted: 21 Post(s)
The "stock" php files are much better than the ts canned tunes. With just basic intake, exhaust and chip all you need is the stock tunes. That's what I have on my php Phoenix chip, which is now discontinued and they work great.
2012 f250CCLB, 35x12.5/17 Kanati mud hogs on race line assault wheels, 2 inch lift
Mini maxx
Jerrybizzle is offline
post #7 of 22 Old 06-06-2014, 01:48 PM
You're gonna love the PHP hydra once you get it, it's like the truck finally woke up hahaha. Stock mode is a joke when I put it back now hahaha
E99 F250 XLT SuperCab 4x4 3.73 gears, 213k and climbing, ZF6 trans w/ 1944-60K SB Clutch/Flywheel, 6637 filter, muffler/cat delete w/ 5 inch tip, PHP Hydra, 4 gauge pod(EGT, EOT, FUEL PSI, BOOST), 12000 lb Warn Winch, 07 headlights/grill, 6k HID kit, Bushwhacker pocket style fender flares, Pioneer 7" touchscreen, 2.5 inch leveling kit with 315/75/16 General AT2s on stock 16 bullets, HPX
Next up: Rebuild Kit and Billet Wheel, Fixing E-brake so I can park on hills!
Tow51Stang is offline
post #8 of 22 Old 06-06-2014, 04:37 PM
Quoted: 3 Post(s)
Thanks
where did you find I for $375??
2001 F-350 4x4 7.3
2015 AXIS A24 surf boat
2012 Keystone Outback Travel trailer
r33pwrd is offline
post #9 of 22 Old 06-06-2014, 04:42 PM
Alligator performance
post #10 of 22 Old 06-06-2014, 04:55 PM
Quoted: 3 Post(s)
awesome thank you! I almost ordered it direct for 425...
2001 F-350 4x4 7.3
r33pwrd is offline
