Will this chip work - Ford Powerstroke Diesel Forum
post #1 of 4 Old 06-05-2014, 03:11 PM Thread Starter
Will this chip work
I have a 1999 f350 drw and I removed my ts style chip to put a hydra in it. Now I just bought a 1999 f250 and was wandering if the chip would work in the f250?
The f350 has a code of NVK2 and the f250 code is NVK3.
Late 1999 f350 4x4 drw crew cab auto trans, DI 4 position chip, AFE II air filter,ftvb, 4"down pipe into 2 5" stacks, ww, ccv mode, autometer gauges , 135,000 miles. Late 1999 f250 ext cab.4x4 auto FF stage 1 injectors non EBPV pedestal, GTP 38R turbo, hydra with powerstruck tunes, gauges. 213000 miles.
Jdg5147 is offline
post #2 of 4 Old 06-05-2014, 04:11 PM
Quoted: 27 Post(s)
Someone may respond soon but if not PM Jay from PHP. Chatham036 is his user name. He is fast to respond to PM's.
2000 F-250 XCLB 4x4 6 Speed, PIS 175/80's, ARP's, 910's, Irate Fuel, 6637, GTP38R, 4" turbo back, Hydra PHP tuned, International Up-pipes, ISSPRO Boost, EGT, HPOP and Fuel Pressure gauges. SB Clutch. MB Diesel HPOP stage 2.
CarportMechanic is offline
post #3 of 4 Old 06-05-2014, 06:33 PM
Should work fine for any dpc-422 pcm without pats ignition
Power-Struck dot com
POWER-STRUCK is offline
The Following 2 Users Say Thank You to POWER-STRUCK For This Useful Post:
blue99stroker (06-06-2014), Corey@CNCFAB (06-05-2014)
post #4 of 4 Old 06-09-2014, 10:35 AM
CSIPSD's Avatar
Will work fine... NVK or PMT...
01 F-250 SC PSD,320k,16 Isspro Gauges, AFE-2,CCV Mod,IAH delete,map reg,Modded H2e, 6.0 IC, 230/100 from P.I.S, Studs, 910 springs, Forged rods, Water injection,Hydra chip-No Limit/Gearhead tuning, Swamps HVHF IDM, MBRP 4" dual's, Aero, 6" tip's, 4" Revtek lift, 37/12.5/16.5 MT's
Joe
DYNOPROVEN.COM, PERFORMANCEINJECTIONSYSTEMS.COM and RIFFRAFFDIESEL.COM
CSIPSD is offline
