Early 99 edge - Ford Powerstroke Diesel Forum
 1Likes
post #1 of 18 Old 06-04-2014, 10:54 AM Thread Starter
usramc's Avatar
Quoted: 2 Post(s)
Early 99 edge
Hey guys, just got an early 99 with a 6 speed, all stock minus cold air and straight pipe. It the only psd I've owned other than my obs. I know a custom tuned chip is preferred but I found an edge juice with attitude for 250. My only future planned mod is appearance. How will the edge do? Plus I believe it'll read my boost and egts.
Early 99, 6 speed, ccsb, leveling kit on 35's, 6634, straight pipe, diablo chip.
usramc is offline
post #2 of 18 Old 06-04-2014, 01:24 PM
Im_Strokin_ur_Cummins's Avatar
Location: Lowville, New York. Studying Mechanical Eng. @ Suny Canton
Being your a 6 speed and not a auto you should be fine but i have also heard plenty of bad about the edge juice. Defantly good for gauges none the less. Id play it safe and save another 200 and buy the hydra.
FUELED BY HATERS
Jack'em up high.Fat chicks cant jump!
E99 7.3 F-250XLT
304,345 miles and still running strong
ext cab
DIY 6637 Intake
5in straight pipe to Aussie stacks
PHP 6pos
Boost,tran,and EGT Gauges
4in lift
Some body rust and oil leaks
CB radio
Pretty Girl sittin next to me
Im_Strokin_ur_Cummins is offline
post #3 of 18 Old 06-04-2014, 04:42 PM Thread Starter
usramc's Avatar
Quoted: 2 Post(s)
Thanks for the input. What about a superchips?
usramc is offline
post #4 of 18 Old 06-05-2014, 10:28 AM
blue99stroker's Avatar
Quoted: 262 Post(s)
since your a manual your better off.
edge trans tuning sucks, superchips has better trans tuning but once again your a 6 speed.
i would just wait and get a custom tuned chip. ive ran edge and superchips, php tunes are so much more powerful with lower egts.
99.5 f250 7.3 4x4 261k FF 160/30, PHP Hydra, S&B CAI, 4" TBE, Van Turbo with Turbo Blanket, RR Billet Wheel, Autometer Gauges, Transgo Tugger, Non-Ebpv Pedestal, 08 Tow Mirrors, Trucool.
Dad-2000 F250 7.3 4x4 111k Autometer Gauges, Superchips 1705 (Tow Safe), 6637, 4" TBE, BD Billet Wheel, Trucool.
blue99stroker is online now
post #5 of 18 Old 06-05-2014, 10:44 AM Thread Starter
usramc's Avatar
Quoted: 2 Post(s)
Only thing I've ever run was canned ts tunes in an obs. Since my trucks all stock would custom tunes be worth the extra $ over canned?
usramc is offline
post #6 of 18 Old 06-05-2014, 11:56 AM
Quoted: 27 Post(s)
I had a Superchips in my truck when i bought it.
With my experience when i switched over to a PHP chip i did not notice "more" power. I noticed a smoother throttle, beter MPG and lower EGT's all the wile still producing as much power as the superchips.
With our Injectors a tuner can only produce X amount of power. No company out there can build more power then our injectors will allow. With that said, if you were to dyno PHP vs Swamps vs Gearhead vs edge vs superchips, they MAY all produce the exact same amount of power but how the power is delivered will be different between each company. Fuel curve, timing, air ratio will all be different between each tuner along with other things.
My superchips throttle was touchy and had high EGT's but good power.
PHP tunes ease into the power nice and smooth and my EGT's are 200 degrees lower.
I think your question of "is it worth it" is really up to how you are going to use your truck. If your going to tow a lot i would get custom tunes for the sole purpose of lower EGT's. If its a grocery getter and dump runner then you wont see much benefit to custom tunes.
Just my opinion. Good luck though with whatever you decide.
2000 F-250 XCLB 4x4 6 Speed, PIS 175/80's, ARP's, 910's, Irate Fuel, 6637, GTP38R, 4" turbo back, Hydra PHP tuned, International Up-pipes, ISSPRO Boost, EGT, HPOP and Fuel Pressure gauges. SB Clutch. MB Diesel HPOP stage 2.
CarportMechanic is offline
post #7 of 18 Old 06-06-2014, 07:51 AM Thread Starter
usramc's Avatar
Quoted: 2 Post(s)
I tow maybe once a month. But I work 4 hours from home so it's a commuter truck. Just make the trip 1 time a week. I'm thinking a tuner will give me what I'm wanting at least for a while. Once I decide(if I do) to go bigger o b performance I'll do a custom chip.
usramc is offline
post #8 of 18 Old 06-06-2014, 07:52 AM Thread Starter
usramc's Avatar
Quoted: 2 Post(s)
Thanks for the info and pointers.
usramc is offline
post #9 of 18 Old 06-06-2014, 11:11 AM
Quoted: 262 Post(s)
bill the owner of php wrote the superchips files a looooong time ago, same with edge.
power-struck has an 8 pos chip for 350. he has excellent tunes also. hucorey is a dealer for him also.
post #10 of 18 Old 06-09-2014, 05:31 PM
Sorry don't mean to thread jack but i have an 2001 auto with a single position tow chip installed into the ecm, and I got a free edge evolution given to me and I'm wondering what id have to do to install it like would i need to remove the tow chip to use the edge?
2001 Power Stroker is offline
