Gtp38r what's the most made with one? - Ford Powerstroke Diesel Forum
post #1 of 19 Old 05-24-2014, 08:29 AM Thread Starter
heykw's Avatar
Excursion 02 4x4 Silverline exaust superchip tuner
Excursion 2000 4x4 300K miles 238/100 P.I.S. Injectors 38RW/ billet wheel dyno proven tunes
99 F350 7.3 4x4 body build date 02/98 motor build date 12/97 19.5 ricksons (Sold)
heykw is offline
post #2 of 19 Old 05-24-2014, 11:26 AM
Quoted: 3 Post(s)
Pretty sure its in the 600 range, but HOT egt's from what i remember reading. If i could do it over again i would have apent the money upfront and got a better turbo setup.
1350 gtp38r
500 DI uppipes
250 Intercooler boots
250 WW2 for 38R
= 2350, coulda dropped a little more coin and had a much better setup that is rebuidable. Whats your plans?
2000 DRW CC 7.3
Exterior: 08 Exterior Clone, 22.5's
Engine Mods: GTP38R WW2, 5 inch exhaust,T500, 6637, TW tunes,DI Up pipes, 6.7 fuel pump fuel system.
Trans Mods: 6.0 trans cooler, JW Valve body,Billet triple disc converter.
Sound Mods: 7" flip out tv, 3-way speakers all around, 12" sub, 500 watt amp.
Misc:dieselsite coolant filter, max ac assist, BRV, IHD,gauges, CCV
Next up power rear window
campbellflage is offline
post #3 of 19 Old 05-24-2014, 01:23 PM
Joel's Avatar
Quoted: 10 Post(s)
Better is a relative term. A 38r might be a great turbo for whatever he has in mind.
Not ideal for 600hp though
PIS 230/80's, Van Turbo with EBPV, BD Billet Wheel
Lots of money spent at RiffRaff
Dual SD fuel pumps, in tank mods, CNC Fab bowl retain kit. SDK Tunes. Isspro.
Still pretty slow, just less slow now.
Originally Posted by peixinho View Post
I love finally having my truck back... that 7.3 dog that I was driving was just not cutting it.
Joel is offline
post #4 of 19 Old 05-24-2014, 01:26 PM
Quoted: 3 Post(s)
I agree, thats why I asked what his plans were. Its not a bad turbo, just not the best if your planning on big injectors.
2000 DRW CC 7.3
post #5 of 19 Old 05-25-2014, 04:02 AM Thread Starter
heykw's Avatar
500hp - 550hp range is what I'm looking for.
230/100, 38r with riffraff billet wheel, head studs, no limit tunes F8, CTS for gauges to include fuel pressure and egt, 4" exhaust stainless, built trans, 6637 air filter.
I'm also thinking about replacing the bellowed up pipes when I install the turbo, should I?
I have a brand new stock fuel pump if needed I'm thinking about doing the twin stock fuel pump setup. I'm sure I left a couple of things out.
Thanks for all the great info thus far.
heykw is offline
post #6 of 19 Old 05-25-2014, 04:23 AM
schlutzer's Avatar
Quoted: 18 Post(s)
You are at the limit for a 38r really.
A better setup would be an H2e or an S467 turbo with those injectors.... Even a gated S366 would be fine or Swamp's 6674 which is a s300 chassis.
If you want longevitity you don't want the turbo to be the cork in the system without a wastegate
That said... The 38r with the wheel will do that power level. Yes you should do bellowed up pipes while you're there
Please check out my 7.3 Enthusiast Facebook group! All are welcome!
schlutzer is offline
post #7 of 19 Old 05-25-2014, 05:12 AM
Quoted: 3 Post(s)
I would seriously be thinking about a different setup for the money your going to spend. Back to my previous post, your looking at roughly 2400ish in a 38r setup and being right at the top of its capabilities. I plan on a similar route but was thinking 250/200's and a gated 468 from irate when funds allow
2000 DRW CC 7.3
post #8 of 19 Old 05-25-2014, 05:57 AM Thread Starter
heykw's Avatar
Schlutzer what brand up pipes?
Do they make a stainless set?
Are there performance up pipes?
heykw is offline
post #9 of 19 Old 05-25-2014, 06:07 AM
Quoted: 3 Post(s)
7.3l Stainless Up-Pipes
2000 DRW CC 7.3
The Following User Says Thank You to campbellflage For This Useful Post:
heykw (05-25-2014)
post #10 of 19 Old 05-25-2014, 06:22 PM Thread Starter
heykw's Avatar
So is it a worth while upgrade for the money?
heykw is offline
