Boost gauge - Ford Powerstroke Diesel Forum
post #1 of 5 Old 05-18-2014, 04:43 PM Thread Starter
Boost gauge
2000 f350 installed my boost sensor in my intake and can't get a reading. My egt and trans temp work fine. It's for an edge insight
bberry09 is offline
post #2 of 5 Old 05-27-2014, 07:45 PM
CSIPSD's Avatar
Where did you install it?
01 F-250 SC PSD,320k,16 Isspro Gauges, AFE-2,CCV Mod,IAH delete,map reg,Modded H2e, 6.0 IC, 230/100 from P.I.S, Studs, 910 springs, Forged rods, Water injection,Hydra chip-No Limit/Gearhead tuning, Swamps HVHF IDM, MBRP 4" dual's, Aero, 6" tip's, 4" Revtek lift, 37/12.5/16.5 MT's
Joe
DYNOPROVEN.COM, PERFORMANCEINJECTIONSYSTEMS.COM and RIFFRAFFDIESEL.COM
CSIPSD is offline
post #3 of 5 Old 05-28-2014, 02:19 AM Thread Starter
I drilled and tapped my intake I can only get it to read up to 10psi. Just not sure where my leak is yet
bberry09 is offline
post #4 of 5 Old 05-28-2014, 06:28 AM
heykw's Avatar
Is the truck down on power?
Excursion 02 4x4 Silverline exaust superchip tuner
Excursion 2000 4x4 300K miles 238/100 P.I.S. Injectors 38RW/ billet wheel dyno proven tunes
99 F350 7.3 4x4 body build date 02/98 motor build date 12/97 19.5 ricksons (Sold)
heykw is offline
post #5 of 5 Old 05-28-2014, 07:15 AM
sbluke55's Avatar
Quoted: 502 Post(s)
Garage
You can build a boost pressure tester for cheap and hook it up to an air compressor. Check your map sensor line for cracks. What brand of gauge did you get?
01 f-250, Standard
Rev tech 4" lift,37" military wrangler Mt tires
KC diy 66, Full force 160/100 and custom tunes from PHP
Banks inner cooler and full 4" exhaust, Diy S&B intake
Diy quad feed, Hydra, Isspro boost, pyro, and fuel pressure
3/0 battery cables with military style terminals
sbluke55 is online now
