zoodad mod - Ford Powerstroke Diesel Forum
 1Likes
post #1 of 11 Old 05-18-2014, 03:39 PM Thread Starter
Zen
zoodad mod
anybody have a working thread or links. All the ones I have found go to dead links including the tech files one.
Thanks
Zen is offline
post #2 of 11 Old 05-18-2014, 07:31 PM
blue99stroker's Avatar
Quoted: 283 Post(s)
google it.
pictures will pop up on there.
or youtube
you just cut some of the bracket out right in front of the snorkel for the intake.
take the grill off to do this.
99.5 f250 7.3 4x4 265k Full Force 160/30, PHP Hydra, S&B CAI, 4" Exhaust, Van Turbo, RR 6/6 Billet Wheel, Autometer Gauges, Transgo Tugger, Non-Ebpv Pedestal, 08 Tow Mirrors, Trucool Max.
Dad-2000 F250 7.3 4x4 114k Autometer Gauges, Superchips 1705 (Tow Safe), Blue 6637, 4" Exhaust, BD Billet Wheel, Trucool Max.
blue99stroker is offline
post #3 of 11 Old 05-22-2014, 08:22 AM
lightning95's Avatar
It's harder to take the grill out then to do the mod. I used a sawzall and cut off wheel.
It's stupid it's not open from the factory. My 95 is open there.
lightning95 is offline
post #4 of 11 Old 05-22-2014, 04:51 PM Thread Starter
Zen
done for better or worse used a hole cutter and sawzall
Zen is offline
post #5 of 11 Old 05-22-2014, 04:56 PM
Koda22's Avatar
Quoted: 5 Post(s)
Yea pretty easy to do just cutting a hole, I went a little farther and added a little screen thing I built so nothing gets in....
Koda22 is offline
post #6 of 11 Old 05-22-2014, 05:23 PM Thread Starter
Zen
I added a screen on as well since I made the hole the same size as the intake. Didn't want birds and bugs getting in there
Zen is offline
post #7 of 11 Old 06-27-2014, 10:27 AM
Ramsmoker's Avatar
I cut the 4in hole and put a tube from the grille
The Ex -box. Total RSD system. See what happens when you let attorneys run your Country!!!! There's nothing wrong with a Democratic society, we just need to get rid of Democrats. 2001 Excursion. 2003 Cobra Terminator all pumped up. Now this is fuuuuuun.
Ramsmoker is offline
post #8 of 11 Old 06-27-2014, 06:27 PM
Googs's Avatar
I've got to much crap in front so I've gone with a snorkle , vents into the side of the engine bay, and no it doesn't restrict you vision well no more than a triple gauge pod , but remember I'm wheelin from the other side, seems to direct plenty of cold air in.
kinnisoj likes this.
2003 F250 4X4 CC 7.3, 4R100HD
4' Turbo back exhaust, Banks Power Elbow, LPG (Gas over Diesel), DP Tuner F6, RR 6637 intake, RiffRaff Frx, Hpx, filter, Custom made transmission cooler with twin thermo fans, water to oil cooler, ScanGuage 2, Auto Meter, trans, EGT, Fuel pressure, Water to oil temp, Boost, Longrange fuel tank, 15000 Lbs winch, ARB winch bar, ARB lockers Fr & Rr, lightforce spot lights, HID's.
Googs is offline
post #9 of 11 Old 06-27-2014, 07:07 PM
kinnisoj's Avatar
Quoted: 2 Post(s)
GOOGS that is BAD AZZ!!!
,edge turbo timer
5" TB DIAMOND EYE EXH
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #10 of 11 Old 06-28-2014, 08:27 AM
heykw's Avatar
Googs tell up more about your setup.
Excursion 02 4x4 Silverline exaust superchip tuner
Excursion 2000 4x4 300K miles 238/100 P.I.S. Injectors 38RW/ billet wheel dyno proven tunes
99 F350 7.3 4x4 body build date 02/98 motor build date 12/97 19.5 ricksons (Sold)
heykw is offline
