Hydra installation - Ford Powerstroke Diesel Forum
 1Likes
post #1 of 14 Old 05-17-2014, 04:19 AM Thread Starter
Quoted: 21 Post(s)
Hydra installation
Hello,
I have a hydra install to do... I was researching on the web for installation instructions. (watching videos ect)
Any helpful advice for the install. I just don't want to screw anything up.
Thanks
The Next Level is offline
post #2 of 14 Old 05-17-2014, 06:07 AM
sbluke55's Avatar
Quoted: 523 Post(s)
Garage
Hydra installation
This is from a post I did a couple months ago.
Originally Posted by Chatham036 View Post
I know you figured out what was going on already but in case someone else comes across this same issue, here is how to go about finding your proper files.
When establishing the set of files to download for your specific truck, you will need to locate the PCM code that is located on the PCM itself.
In this case, APX1 is the code listed.
Next when the hydra flash software is open on your computer, you will need to go to the tool menu and select box / hex conversion on the drop down menu.
At the top left you will enter in your PCM code... ( APX1 in this example ) then to the right you will have the direct hex conversion appear. ( VSAA4Q9 )
DON'T STOP AT THIS STEP
Now look towards the bottom and you will see a recommended preferred calibrations section. If a code appears in the section, you will want to use this code. If nothing appears, you are good to use the direct conversion
If you come up with any questions about this process, please feel free to email me at Jay@PHPtune.com
Thank you
Read threw this.
http://www.gopowerhungry.com/_install_phoenix_sd.shtml
01 f-250, Standard
Rev tech 4" lift,37" military wrangler Mt tires
KC diy 66, Full force 160/100 and custom tunes from PHP
Banks inner cooler and full 4" exhaust, Diy S&B intake
Diy quad feed, Hydra, Isspro boost, pyro, and fuel pressure
3/0 battery cables with military style terminals
sbluke55 is online now
post #3 of 14 Old 05-17-2014, 06:14 AM
sbluke55's Avatar
Quoted: 523 Post(s)
Garage
Then I did thisAttachment 287562
It makes it easier to pull the chip out and install when needed.
01 f-250, Standard
post #4 of 14 Old 05-17-2014, 10:30 AM Thread Starter
Quoted: 21 Post(s)
Tried to click on my program, won't open? It has before, then redirects me to php website which appears to be down?
post #5 of 14 Old 05-17-2014, 11:26 AM
what gauges are you trying to install? I did my trans temp gauge, egt, voltage, and boost. The Trans temp is very simple, and its on youtube, takes about 20min (running wires is the hardest part) and egt is where its more complex. I took my air filter off and taped in right by my 8th cylinder (closest cylinder to the cab on drivers side) just ran the cord up to the firewall and ran it threw. then went straight up.
e99 7.3 Crew Cab 4x4
6.0 Trans Cooler
06 Mirrors (wired all but heat) 06 step bars
36" Tires/factory 06 18" rims
PHP Chip/Glow Shift Gauges
Crank Case Vent Mod
600k miles and still running strong.
AdamCap is offline
post #6 of 14 Old 05-17-2014, 12:48 PM
sbluke55's Avatar
Quoted: 523 Post(s)
Garage
He is trying to get his chip programmed. No gauges. Your trying to open hydra flash? If you opened it before it should be there.
01 f-250, Standard
post #7 of 14 Old 05-17-2014, 05:12 PM Thread Starter
Quoted: 21 Post(s)
Got it! I like. First time I took it for a spin with guages installed and hydra.
Only concern tranny temp! Ugh!
post #8 of 14 Old 05-17-2014, 08:50 PM
Is the php site down? I can't get it to come up.
Redstroke188 is offline
post #9 of 14 Old 05-18-2014, 05:29 AM Thread Starter
Quoted: 21 Post(s)
It was yesterday
post #10 of 14 Old 05-20-2014, 04:01 PM
Quoted: 2 Post(s)
Finally got my Hydra installed
Finally got around to installing my Hydra today. Installation was easy, programming simple. Seems to be working fine. Only problem - can't driving it as I am in the middle of replacing a brake caliper. Original replacement was defective and now it is raining and I don't feel like getting wet. When I installed the chip, I disconnected the batteries before pulling the PCM and left them disconnected until finished with the install. My question is do I need to disconnect the batteries if I ever need to remove the Hydra or is just shutting off the ignition enough. I want to make sure that I don't damage the PCM or the Hydra.
inspectorCSS is offline
The Following User Says Thank You to inspectorCSS For This Useful Post:
sonofahunter (05-20-2014)
