7.3 Build - Ford Powerstroke Diesel Forum
post #1 of 9 Old 05-16-2014, 08:00 PM Thread Starter
7.3 Build
I have a 2001 7.3 psd and i was wondering what kinda of build i could do with a budget of $5000 all i have is specter cold air and 3 1/2 exhaust to a 5 in miter stack
sierra258 is offline
post #2 of 9 Old 05-16-2014, 10:20 PM
sbluke55's Avatar
Quoted: 501 Post(s)
Garage
7.3 Build
Automatic? If so get a 6.0 trans cooler, upgraded valve body from john woods and maybe a upgrade torque converter with one with a billet cover. Gauges from autometer or isspro: egt, boost, auto trans, (hpop and fuel pressure are optional). Then 4" down pipe from diamond eye. The hydra from php, it's a 17 position chip. 38r turbo with a billet wheel. Intake plenum inserts, new inner cooler boots and bellowed up-pipes ( if they are leaking, most likely will be) from riff raff. T-500 hpop if yours is weak. Pis injectors: either 175cc/80% or 160cc/30%. You will need custom tuning to run larger injectors. I also recommend the FRX to fix the dead head in the fuel system. That should about use up all your money plus some. Since you have a possibility of having a pmr motor I wouldn't do much more than that. You can always check that to make sure. You can only get this much stuff if you do all the work yourself.
01 f-250, Standard
Rev tech 4" lift,37" military wrangler Mt tires
KC diy 66, Full force 160/100 and custom tunes from PHP
Banks inner cooler and full 4" exhaust, Diy S&B intake
Diy quad feed, Hydra, Isspro boost, pyro, and fuel pressure
3/0 battery cables with military style terminals
sbluke55 is offline
post #3 of 9 Old 05-17-2014, 08:43 AM
scagle1's Avatar
^ pretty much covered it , just add on's for the price range as actual builds tend to get pricey quick. I'd do some research into losing the spectre as well , good possibility of doing more harm than good with lack of filtration and possibility of dusting. Google spectre/diesel and read a few of the forums , doesnt look well......
Sold 01 350 6" on 37's and mild mods, 00 X 4" on 35's, 02 f350 4" 35's modded from fan to drive shaft, ridin the 03 with nose conversion with 125k and counting upwards slowly.
Never had CNC's poo on any of it, never will.
scagle1 is offline
post #4 of 9 Old 05-17-2014, 01:00 PM Thread Starter
What kinda horse power could I expect out of this build
post #5 of 9 Old 05-17-2014, 01:17 PM
Quoted: 27 Post(s)
being a 2001 he could have a diode trans so the extra power could shorten the life. diode trans need a full rebuild if it goes on you, just something to keep in mind.
EDIT: if its not a manual
-Kris
01 cclb f-350 srw-463hp/1025ftlbs PHP Dyno (extreme tune)
leveled with 285's on 17'' XD Spy's
Autometer gauges (boost, trans, egt, fuel)
4'' straight pipe
DIY 6637
Powerstruck 160/30's
Hydra-Powerstruck and Dan K tunes
38r
CNCFab fuel & hpop lines
Sam Wyse stage 2 trans.
Originally Posted by Dave View Post
Why delete something thats truthful? Paid vendor status isnt like the mafia youre not paying for protection from negative feedback here
strokin-7.3 is offline
post #6 of 9 Old 05-17-2014, 01:40 PM
dieselburner21's Avatar
Quoted: 8 Post(s)
Bits is somewhere around 5k end of build
Will
2010 FORD F250 LARIAT CCSB 6.4
-H&S Mini Maxx / Edge Insight CTS / 4" Flo Pro Dump / 20" Fuel Hostages / 33" Toyo AT's / Airdog II 4G
2006 FORD F250 LARIAT CCSB 6.0 - TRADED
2000 FORD F250 LARIAT CCSB 7.3 - SOLD
dieselburner21 is offline
post #7 of 9 Old 05-17-2014, 02:57 PM
scagle1's Avatar
400-450 area depending on injectors and tuning
scagle1 is offline
post #8 of 9 Old 05-17-2014, 08:08 PM
Something that a lot of people kind of overlook, you should do the crank case vent mod. its about a 10$ fix, and it will save your turbo that you have now.
e99 7.3 Crew Cab 4x4
6.0 Trans Cooler
06 Mirrors (wired all but heat) 06 step bars
36" Tires/factory 06 18" rims
PHP Chip/Glow Shift Gauges
Crank Case Vent Mod
600k miles and still running strong.
AdamCap is offline
post #9 of 9 Old 05-18-2014, 07:21 AM
scagle1's Avatar
Actually , it does absolutely nothing to your turbo by venting back in. However , overtime the residue can build up in the boots and cause them to pop off easier under higher boost levels. Common mod ? For some. Beneficial to anything ? opinions vary. Smells like chit ? Totally
scagle1 is offline
