Leaky up pipes cause higher EGT??? - Ford Powerstroke Diesel Forum
post #1 of 11 Old 05-12-2014, 10:42 PM Thread Starter
Im_Strokin_ur_Cummins's Avatar
Location: Lowville, New York. Studying Mechanical Eng. @ Suny Canton
Ok so have seen on here a bit rescently that have leaky up pipes or a hole in them causing higher EGT's. My question is how does that work/make sence? Because in my mind its letting the hot air escape faster which is what you want so it should be making things cooler since the hot air is escaping faster in theory.
FUELED BY HATERS
Jack'em up high.Fat chicks cant jump!
E99 7.3 F-250XLT
304,345 miles and still running strong
ext cab
DIY 6637 Intake
5in straight pipe to Aussie stacks
PHP 6pos
Boost,tran,and EGT Gauges
4in lift
Some body rust and oil leaks
CB radio
Pretty Girl sittin next to me
Im_Strokin_ur_Cummins is offline
post #2 of 11 Old 05-12-2014, 11:20 PM
heykw's Avatar
It Won't allow the turbo to spool up or it will cause it to spool slowly.
Excursion 02 4x4 Silverline exaust superchip tuner
Excursion 2000 4x4 300K miles 238/100 P.I.S. Injectors 38RW/ billet wheel dyno proven tunes
99 F350 7.3 4x4 body build date 02/98 motor build date 12/97 19.5 ricksons (Sold)
heykw is offline
post #3 of 11 Old 05-13-2014, 02:49 AM
ja_cain's Avatar
Turbo increases volumetric/pumping efficiency of of the motor. More air in and out if the motor means heat is carried away more effectivly. It self perpetuating (as long as stay within the design parameters of the pump/turbo) meaning that as it pumps more air and more fuel is supplied in the correct proportion/amount there is more kenitic energy created to drive the turbin wich drives the compressor thus increasing the amount of air available to fully combust the fuel available thus increasing the exhaust kenitic energy. Also, air density is closely related to the convective heat transfer. Turbo increases air density thus keeping engine cooler by increasing convective heat transfer. Not sure if this is a linear relationship. If you have an exhaust leak before the turbine the the kenitic energy is lost which means when you increase the fuel charge the air flow doesn't increase sufficiently to remove the heat fast enough to cool the engine. It's similar to the heating element in a blow dryer. If the airflow relative to the amount of heat being generated by the element drops then the element overheats and burns up. This is analogous to increasing the fuel delivery without increasing the amount of airflow in and out of engine. Heat generated by combustion energy stays in the combustion temperature and heats everything up and once the pistons are heat soaked they are prone to failure/breakage. Sorry if I confused you more with that crappy answer.
2002 F-350 SCLB PSD 4X4 6 Speed
ja_cain is offline
post #4 of 11 Old 05-13-2014, 03:01 AM
ja_cain's Avatar
That post was self perpetuating
ja_cain is offline
post #5 of 11 Old 05-13-2014, 03:44 AM
heykw's Avatar
analogous =, or fancy for like.
heykw is offline
post #6 of 11 Old 05-13-2014, 08:18 AM
ja_cain's Avatar
Sorry, last part meant to read heat generated by the combustion process is not adequately removed from the combustion chamber thus heating up the piston, valves, etc more than is favorable.
ja_cain is offline
post #7 of 11 Old 05-13-2014, 09:24 AM
blue99stroker's Avatar
Quoted: 249 Post(s)
^ what they said. the turbo cant work efficiently.
99.5 f250 7.3 4x4 261k FF 160/30, PHP Hydra, S&B CAI, 4" TBE, Van Turbo with Turbo Blanket, RR Billet Wheel, Autometer Gauges, Transgo Tugger, Non-Ebpv Pedestal, 08 Tow Mirrors, Trucool.
Dad-2000 F250 7.3 4x4 111k Autometer Gauges, Superchips 1705 (Tow Safe), 6637, 4" TBE, BD Billet Wheel, Trucool.
blue99stroker is offline
post #8 of 11 Old 05-13-2014, 03:26 PM Thread Starter
Ah ok makes scence to me now, thanks for the information. I guess you do learn something new everyday
FUELED BY HATERS
E99 7.3 F-250XLT
ext cab
DIY 6637 Intake
PHP 6pos
4in lift
CB radio
post #9 of 11 Old 05-13-2014, 04:00 PM
ja_cain's Avatar
Just think of motors as pumps. The turbo just compresses the inlet air so it is at a higher pressure than atmospheric pressure thus increasing the efficiency of the motors pumping action. I will try to pull up some charts of air pressure/density vs heat transfer of air with regards to convective cooling. This should illustrate why it is important to get enough air in and out of the engine. Exhaust scavenging should be important with regards to this. Not sure what kind of overlap a stock 7.3 cam has but this can have an effect on exhaust scavenging too thus decreasing temps. I love thinking about this stuff thanks for asking this question.
ja_cain is offline
post #10 of 11 Old 05-13-2014, 04:29 PM
ja_cain's Avatar
This is also dependent on other things too like boundary layer area% thickness, velocity, humidity, etc. I am oversimplifying it a bit but I will try to find something that replicates similar conditions that a combustion chamber will see.
ja_cain is offline
