Dp egts - Ford Powerstroke Diesel Forum
post #1 of 6 Old 05-10-2014, 09:12 PM Thread Starter
Dp egts
What are egts running on a 80econ setting towing around 10k? I have a 2wheel 6sp all stock except intake, clutch and programmer, needing to take this truck on a trip pulling 10k and pyro gauge did not show up. Ok I got an infinity on 3 trucks, all setup different. 450 and 550's pulling heavy with no egt problems, just wanting to get an idea if this 80 setting is safe or if it was a drive by gauge tune. Thanks
Sent from AutoGuide.com App
treemover is offline
post #2 of 6 Old 05-11-2014, 01:01 AM
schlutzer's Avatar
Quoted: 18 Post(s)
1250 is the Max safe to run for extended periods
Please check out my 7.3 Enthusiast Facebook group! All are welcome!
schlutzer is offline
post #3 of 6 Old 05-11-2014, 06:29 AM Thread Starter
Yes I know, I was just wondering how hot the tune will run
post #4 of 6 Old 05-11-2014, 10:12 AM
Joel's Avatar
Quoted: 10 Post(s)
If you lug it at all it will get hot. If you keep the RPM's up on the hills it's fine.
I wouldn't use it without a gauge though. I wouldn't use anything without a gauge
PIS 230/80's, Van Turbo with EBPV, BD Billet Wheel
Lots of money spent at RiffRaff
Dual SD fuel pumps, in tank mods, CNC Fab bowl retain kit. SDK Tunes. Isspro.
Still pretty slow, just less slow now.
Originally Posted by peixinho View Post
I love finally having my truck back... that 7.3 dog that I was driving was just not cutting it.
Joel is offline
The Following User Says Thank You to Joel For This Useful Post:
PSD POWER007 (05-11-2014)
post #5 of 6 Old 05-12-2014, 08:54 AM
CSIPSD's Avatar
Without a gauge... I would not risk it... More so with that tuner.
01 F-250 SC PSD,320k,16 Isspro Gauges, AFE-2,CCV Mod,IAH delete,map reg,Modded H2e, 6.0 IC, 230/100 from P.I.S, Studs, 910 springs, Forged rods, Water injection,Hydra chip-No Limit/Gearhead tuning, Swamps HVHF IDM, MBRP 4" dual's, Aero, 6" tip's, 4" Revtek lift, 37/12.5/16.5 MT's
Joe
DYNOPROVEN.COM, PERFORMANCEINJECTIONSYSTEMS.COM and RIFFRAFFDIESEL.COM
CSIPSD is offline
post #6 of 6 Old 05-12-2014, 10:22 AM
SeeYa's Avatar
Our 80 Econo is not designed to Tow 10K. If you are, you are using the wrong tune. You need the 60 Tow per our list of tune descriptions.
You should always tow by your gauges no matter what tow tune your are in. EGT issues can be from many sources. Check for boost leaks. Up pipe leaks are the biggest culprit to having higher then normal EGT's. What are you seeing as for EGT's at cruising and WOT? Anything below 1350* you will be fine according to International. WE err on the side of caution and say 1250* just in case your gauge is not accurate. You just don't want to be over that for a sustained period of time or you will melt something.
Custom Tuning-Computer Chips
Flash Programmers-Aftermarket parts
Ford Power Stroke Engine and Transmission Tuning Specialist since 2004.
828-221-0076
SeeYa is offline
