Programer questions - Ford Powerstroke Diesel Forum
post #1 of 5 Old 05-10-2014, 08:16 PM Thread Starter
SUPERDUALLY350's Avatar
Programer questions
So i currently have the ts 6 position and looking at getting the php tunes but i seen the dp 16 position chip and i was wondering if any one is running the dp chip and how they like it. also is the hydro chip better than the ts chip with both having the php tunes?
SUPERDUALLY350 is offline
post #2 of 5 Old 05-10-2014, 08:32 PM
emev0l's Avatar
The tunes will run exactly the same no matter what chip there on.
A lot of people like the Hydra because you can download any of there (basic) tunes for no extra cost after you buy the chip.
99.5 Crew Cab 7.3
S468/T4 mount
238/200's
BTS Transmission
Regulated Return Fuel Bowl Delete
ARP Head Studs
910 Valve Springs
Twin Terminator HPOPs
Walbro Fuel Pump
6637, Autometer Gauges
4" turbo back exhaust
Hydra with Gearhead and PHP tunes
Overboost Annihilator
Pre Pump Kit
Post Pump Kit
6.0 Trans Cooler
True-Trac
285/75/16 BFG AT's
Air Bags
Pioneer F930BT in dash GPS
573rwhp 1021.5ft-lbs
emev0l is offline
post #3 of 5 Old 05-10-2014, 10:44 PM
Hydra all the way. Cheaper and easier and you can download tunes from different companies and put them on your chip via your computer and a USB cord.
E99 F250 XLT SuperCab 4x4 3.73 gears, 213k and climbing, ZF6 trans w/ 1944-60K SB Clutch/Flywheel, 6637 filter, muffler/cat delete w/ 5 inch tip, PHP Hydra, 4 gauge pod(EGT, EOT, FUEL PSI, BOOST), 12000 lb Warn Winch, 07 headlights/grill, 6k HID kit, Bushwhacker pocket style fender flares, Pioneer 7" touchscreen, 2.5 inch leveling kit with 315/75/16 General AT2s on stock 16 bullets, HPX
Next up: Rebuild Kit and Billet Wheel, Fixing E-brake so I can park on hills!
Tow51Stang is offline
post #4 of 5 Old 05-11-2014, 07:07 AM Thread Starter
well being there they're the same tunes and i already have the 6 position chip where can i get the php tunes on my ts6 position. I live in minnesota so if there's some where in mn that would be great. i like the idea of the hydra chip but i cant imaging the php tunes are 400 bucks. so if anyone knows where i can get them done and how much it would cost that would be great. Thanks
post #5 of 5 Old 05-11-2014, 07:42 AM
FJuanfiddy mod
Dave's Avatar
Quoted: 10 Post(s)
I dont know of any PHP dealers in MN. So you would either have to buy a burner or send your chip out.
The plus with the hydra is once its in it doesnt have to come out. Just plug in the cord and upload the tune on the chip
Email:
2006 F250 ECSB Lariat 4x4
Edge Insight CTS
Coolant filter
Dave is offline
