Stage 2's and 66mm turbo - Ford Powerstroke Diesel Forum
post #1 of 58 Old 05-10-2014, 03:41 PM Thread Starter
r_marczak_83's Avatar
I just put in Full Force 160/100 injectors and a 66mm turbo. I had the chip reburned by DP.
Now the truck sounds like its got a cam at idle and on tunes greater than 80e, it really smokes like crazy. Once the turbo gets up, it is fast and takes off.
Is this normal?
E99 F250 ex-cab 7.3
Barder 66mm/1.15 a/r turbo, EBPV delete, 4" turbo back w/ 6" SS tip, Full Force 160/100's, 17* HPOP, 140v IDM, Rebuilt 4R100, DP-Tuner, boost fooler, aFe Pro Dry S filter,CCV Mod, HID's, 20" Fuel Hostage w/ 33" Nito MT's
r_marczak_83 is offline
post #2 of 58 Old 05-10-2014, 04:11 PM
I've heard that DP sets up their tunes to go heavy throttle down low and that will make it smoke a lot as opposed to a more linear throttle input.
My PHP Hydra makes my truck sound like it cams out at idle sometimes
E99 F250 XLT SuperCab 4x4 3.73 gears, 213k and climbing, ZF6 trans w/ 1944-60K SB Clutch/Flywheel, 6637 filter, muffler/cat delete w/ 5 inch tip, PHP Hydra, 4 gauge pod(EGT, EOT, FUEL PSI, BOOST), 12000 lb Warn Winch, 07 headlights/grill, 6k HID kit, Bushwhacker pocket style fender flares, Pioneer 7" touchscreen, 2.5 inch leveling kit with 315/75/16 General AT2s on stock 16 bullets, HPX
Next up: Rebuild Kit and Billet Wheel, Fixing E-brake so I can park on hills!
Tow51Stang is offline
post #3 of 58 Old 05-10-2014, 04:20 PM Thread Starter
It must be normal then. I dont mind the low down fuel as long as my turbo would kick in faster to take advantage of it.
E99 F250 ex-cab 7.3
post #4 of 58 Old 05-11-2014, 06:13 AM
schlutzer's Avatar
Quoted: 18 Post(s)
What EGT'S are you seeing? 160's shouldn't be smoking like that there's no reason for it
Please check out my 7.3 Enthusiast Facebook group! All are welcome!
schlutzer is offline
post #5 of 58 Old 05-11-2014, 09:36 AM
blue99stroker's Avatar
Quoted: 247 Post(s)
the dp tunes my friend has for 165/30's and stock turbo dont smoke.
dp tunes used to smoke like crazy i thought they went away from that and the touchy pedal tuning.
i would call and ask about different tunes.
99.5 f250 7.3 4x4 260k FF 160/30, PHP Hydra, S&B CAI, 4" Exhaust, RR Billet Wheel, Autometer Gauges, Transgo, Non-Ebpv Pedestal, High Flow Outlet, 08 Tow Mirrors.
Dad-2000 7.3 4x4 110k miles, Autometer Gauges, Superchips 1705, 6637, 4" Exhaust, BD Billet Wheel, TruCool Max
blue99stroker is offline
post #6 of 58 Old 05-11-2014, 09:50 AM
Joel's Avatar
Quoted: 10 Post(s)
My truck needed a little more ICP at idle to smooth it out. I had Jody bump it up from 480psi to 600 and it's been great.
My race tune smokes more than it should, but I believe that's just because my hpop has trouble holing 1600psi in that tune
What exhaust housing do you have? If you have a 1.15 housing with a 66mm compressor wheel you have the slowest spooling turbo possible.
When I talked to James at Barder, he told me that going to a 66mm on my turbo will push more air at high rpm, but it will take at least another couple hundred RPM to get there.
See if Jody will pull some low boost fuel levels, and let me know how it works out. Because I'm still on the fence about having Barder send me the 66mm kit
PIS 230/80's, Van Turbo with EBPV, BD Billet Wheel
Lots of money spent at RiffRaff
Dual SD fuel pumps, in tank mods, CNC Fab bowl retain kit. SDK Tunes. Isspro.
Still pretty slow, just less slow now.
Originally Posted by peixinho View Post
I love finally having my truck back... that 7.3 dog that I was driving was just not cutting it.
Joel is offline
post #7 of 58 Old 05-11-2014, 10:54 AM Thread Starter
I asked Barder about the 1.00 and the 1.15 and he said the larger would keep egt's down plus better drive pressure.
What do you mean about pulling some low boost fuel levels?
E99 F250 ex-cab 7.3
post #8 of 58 Old 05-11-2014, 10:55 AM Thread Starter
I dont have any guages hooked up yet. I bought some used and they were missing parts, so I'm on the look out for more.
E99 F250 ex-cab 7.3
post #9 of 58 Old 05-12-2014, 08:11 AM Thread Starter
Should I look into going to a 1.0 housing and get rid of the 1.15 with adapter?
I'm getting used to it off the line, but while cruising I feel like I have no instant "go" when I want to pass, ect.
E99 F250 ex-cab 7.3
post #10 of 58 Old 05-12-2014, 09:52 AM
Joel's Avatar
Quoted: 10 Post(s)
Keep the 1.15, just have the tunes adjusted and/or learn how to peddle to keep it out of the smoke
Joel is offline
