Boost Fooler - Ford Powerstroke Diesel Forum
post #1 of 16 Old 05-08-2014, 09:22 PM Thread Starter
StrokinAlaska's Avatar
Boost Fooler
So I watched the video in the tech files on the boost fooler. In the end he said he used the wrong piece, so if I'm understanding right he needs a Regulator instead of whathe used? And setup the same way just Tee'd in the map sensor line. Thanks
05-07 Front
GlowShift Gauges
AFE C.A.I
4" d.p
TS-Performance 6 Position Chip
Wicked Wheel 2
Coolingmist Stage 1
14lbs Nitrous Oxide
(2) 52" VisionX Xmitter Led bars
VisionX Cannon 4.7"
VisionX Cannon 6.7"
(2) 42" RaceSport Led bar
(4) VisionX Solo Soltice
(4) RaceSport Duallys
Hids
Alpine INE-S920HD
20 Speaker Rockford Fosgate Stereo System
3 Bulk Packs of Ballistic
Smoked Cab Lights, Fender Lights, SwitchBack Leds
Tint
2.8" Front leveling kit
StrokinAlaska is offline
post #2 of 16 Old 05-08-2014, 09:33 PM
Joel's Avatar
Quoted: 10 Post(s)
I really like the one that RiffRaff sells. It's pre set, looks good, and less likely to bugger up than some cheapo home depot
PIS 230/80's, Van Turbo with EBPV, BD Billet Wheel
Lots of money spent at RiffRaff
Dual SD fuel pumps, in tank mods, CNC Fab bowl retain kit. SDK Tunes. Isspro.
Still pretty slow, just less slow now.
Originally Posted by peixinho View Post
I love finally having my truck back... that 7.3 dog that I was driving was just not cutting it.
Joel is offline
post #3 of 16 Old 05-09-2014, 04:47 AM
PSD POWER007's Avatar
Quoted: 8 Post(s)
Send a message via AIM to PSD POWER007
The Dieselsite one works really well too.
2003 Ford Excursion Eddie Bauer 4x4 7.3L Powerstroke Forged
Irate T4 BASB, DIY Tymar, Full Force 180/80's, Adrenaline HPOP, Driven Diesel RR & banjos, Magnaflow TBE, DP-Tuner F6 Live tuned, 05 Harley's w/ HID conversion, Edge Insight CS, Dieselsite BRV & coolant filter, Factory 20" wheels, RiffRaff boots, JLR valve body, 6.0 trans cooler, ARP's
PSD POWER007 is offline
post #4 of 16 Old 05-09-2014, 09:16 PM Thread Starter
Riffraffs OCR for 60 bucks?
05-07 Front
GlowShift Gauges
AFE C.A.I
4" d.p
Wicked Wheel 2
Coolingmist Stage 1
14lbs Nitrous Oxide
VisionX Cannon 4.7"
VisionX Cannon 6.7"
Hids
Alpine INE-S920HD
Tint
post #5 of 16 Old 05-09-2014, 09:22 PM Thread Starter
I like the riffraf look but the diesel sites is McLean and simple too. Price is 60cent different haha. Got my ww2 through diesellsite so I'll buy there's. If I buy a 38r or any other turbo upgrade I'll still need this correct?
05-07 Front
GlowShift Gauges
AFE C.A.I
4" d.p
Wicked Wheel 2
Coolingmist Stage 1
14lbs Nitrous Oxide
VisionX Cannon 4.7"
VisionX Cannon 6.7"
Hids
Alpine INE-S920HD
Tint
post #6 of 16 Old 05-09-2014, 09:52 PM
Joel's Avatar
Quoted: 10 Post(s)
Yes, you need a boost fooler of some sort regardless of what turbo, that is as long as you'll be making over 22psi of boost
Joel is offline
post #7 of 16 Old 05-09-2014, 11:07 PM
Quoted: 763 Post(s)
Why do you think you need a boost fooler?
Corey@CNCFAB is offline
post #8 of 16 Old 05-10-2014, 06:37 AM
scagle1's Avatar
How about just running tunes that don't require a boost fooler ?
Sold 01 350 6" on 37's and mild mods, 00 X 4" on 35's, 02 f350 4" 35's modded from fan to drive shaft, ridin the 03 with nose conversion with 125k and counting upwards slowly.
Never had CNC's poo on any of it, never will.
scagle1 is offline
post #9 of 16 Old 05-10-2014, 08:10 AM
Joel's Avatar
Quoted: 10 Post(s)
That's all fine and good with stock injectors, but higher boost pressures can supposedly damage the MAP sensor.
Good call though, I wasn't even thinking about that
Joel is offline
post #10 of 16 Old 05-10-2014, 08:16 AM
Quoted: 763 Post(s)
No. You don't NEED a boost fooler unless you run tunes that require it.
