Digital gauges - Ford Powerstroke Diesel Forum
 1Likes
  • 1 Post By Joel
post #1 of 10 Old 05-08-2014, 04:07 PM Thread Starter
heykw's Avatar
Digital gauges
I'm thinking about doing some upgrades to my 7.3 and I'm considering going with digital gauges I've been looking at the CTS insight. I've had numerous gauge setups on different vehicles before. I have a preference for the digital gages, let me know your thoughts on what set up I should go with. Thanks
heykw is offline
post #2 of 10 Old 05-08-2014, 04:51 PM
Joel's Avatar
Quoted: 10 Post(s)
The insights are good units, but very expensive to add Pyro, boost and fuel pressure to.
You should look into the torque app and get a proper boost, Pyro and Fuel pressure gauge setup
RPM Tim likes this.
PIS 230/80's, Van Turbo with EBPV, BD Billet Wheel
Lots of money spent at RiffRaff
Dual SD fuel pumps, in tank mods, CNC Fab bowl retain kit. SDK Tunes. Isspro.
Still pretty slow, just less slow now.
Originally Posted by peixinho View Post
I love finally having my truck back... that 7.3 dog that I was driving was just not cutting it.
Joel is offline
post #3 of 10 Old 05-08-2014, 05:22 PM Thread Starter
heykw's Avatar
I run an iPhone how does it work with one?
Can I monitor EGT's and Fuel pressure?
Excursion 02 4x4 Silverline exaust superchip tuner
Excursion 2000 4x4 300K miles 238/100 P.I.S. Injectors 38RW/ billet wheel dyno proven tunes
99 F350 7.3 4x4 body build date 02/98 motor build date 12/97 19.5 ricksons (Sold)
heykw is offline
post #4 of 10 Old 05-08-2014, 06:19 PM
Joel's Avatar
Quoted: 10 Post(s)
If you're really against gauges, just get the CTS and add the egt probe. That'll work just fine too.
Joel is offline
post #5 of 10 Old 05-08-2014, 06:53 PM
Im_Strokin_ur_Cummins's Avatar
Location: Lowville, New York. Studying Mechanical Eng. @ Suny Canton
The Torque Pro app doesnt work on IPhones its Android devices only.
FUELED BY HATERS
Jack'em up high.Fat chicks cant jump!
E99 7.3 F-250XLT
304,345 miles and still running strong
ext cab
DIY 6637 Intake
5in straight pipe to Aussie stacks
PHP 6pos
Boost,tran,and EGT Gauges
4in lift
Some body rust and oil leaks
CB radio
Pretty Girl sittin next to me
Im_Strokin_ur_Cummins is offline
post #6 of 10 Old 05-08-2014, 06:58 PM Thread Starter
heykw's Avatar
So if I had to buy an android phone would the set up still be cheaper than the CTS? Can the program monitor boost pressure and monitor exhaust gas temperature?
heykw is offline
post #7 of 10 Old 05-08-2014, 07:02 PM
Yes alot cheaper, the app is around 5 bucks and the blue tooth connector is around 25 bucks. But if you have to buy a Android phone for X amount it maynot be cheaper but if you already have it then yes defantly cheaper
FUELED BY HATERS
E99 7.3 F-250XLT
ext cab
DIY 6637 Intake
PHP 6pos
4in lift
CB radio
post #8 of 10 Old 05-08-2014, 07:47 PM
sbluke55's Avatar
Quoted: 588 Post(s)
Garage
Digital gauges
Torque does not have the ability to monitor egt or fuel pressure. I recommend gauges. You might like something like Dakota digital or what was posted above.
01 f-250, Standard
Rev tech 4" lift,37" military wrangler Mt tires
KC diy 66, Full force 160/100 and custom tunes from PHP
Banks inner cooler and full 4" exhaust, Diy S&B intake
Diy quad feed, Hydra, Isspro boost, pyro, and fuel pressure
3/0 battery cables with military style terminals
sbluke55 is offline
post #9 of 10 Old 05-08-2014, 08:02 PM
Jerrybizzle's Avatar
Quoted: 24 Post(s)
Yes. Much cheaper. My phone was 30 bucks on Craigslist, 25 for Bluetooth obd deal and 5 bucks for app. Run with my other gauges but I like the setup. Here's a bad pic of the setup but you get the idea. No EGT gauge through the torque app.
PowerStrokeNation : Ford Powerstroke Diesel Forum
2012 f250CCLB, 35x12.5/17 Kanati mud hogs on race line assault wheels, 2 inch lift
Mini maxx
Jerrybizzle is offline
post #10 of 10 Old 05-08-2014, 08:40 PM Thread Starter
heykw's Avatar
Thanks for all the info guys
heykw is offline
