7.3 Advice - Ford Powerstroke Diesel Forum
 2Likes
post #1 of 88 Old 05-06-2014, 02:39 AM Thread Starter
7.3 Advice
I have a few questions on the 7.3 I am new to a diesel truck and really don't know where to start.
I have a 99 F350 (non dully) 4x4 crew cab long bed auto.
I have done some of the maintenance things to keep the truck running longer, but my biggest question would be
What can i do to get more low end power. More acceleration and more power to drive the truck on the beach.
It did decent on the beach the last time i took it out there, but it seemed like it struggled when it became softer sand (i know that all diesels will because its a lot heavier)
Things i have done.
I did the intake mod (built my own intake/filter) and bypassed the blow thing that goes into your intake (Crank Case Vent Mod)
new filters (oil and fuel)
straight pipes (4in) dumps in front of my rear tire
Planed upgrades so far are;
Gages for everything (egt, volts, trans temp, boost)
6.0 Trans cooler
valve cover gaskets
glow plugs
Please let me know what you would do on a semi limited budget, that might increase power/torque but i also want to make sure my truck will last a very long time.
e99 7.3 Crew Cab 4x4
6.0 Trans Cooler
06 Mirrors (wired all but heat) 06 step bars
36" Tires/factory 06 18" rims
PHP Chip/Glow Shift Gauges
Crank Case Vent Mod
600k miles and still running strong.
AdamCap is offline
post #2 of 88 Old 05-06-2014, 04:45 PM Thread Starter
Things i have done.
Crank Case Vent Mod
6.0 Trans cooler
valve cover gaskets
glow plugs
I bolded the Mod that i wasn't sure of what it was called. Again I apologize for my ignorance.
AdamCap is offline
post #3 of 88 Old 05-06-2014, 05:02 PM
RPM Tim's Avatar
This would not be my vehicle of choice for the beach, but...
Gauges/ EGT, trans temp, boost
6.0 cooler
Chip
?Lockers
All you need,, Have Fun!
2002
250 CCSB 4x4 7.3
stock~ diy B085011 / DEP 5" Turbo Back w/muffler / Phoenix chip
RPM Tim is offline
post #4 of 88 Old 05-06-2014, 05:07 PM
Quoted: 28 Post(s)
I don't know how many gauges you're getting but if it's just the four you listed I would drop the volt gauge and get fuel pressure hands down. Since you've already done intake and exhaust I'd get a chip next. No experience driving on sand but if it's anything like mud than I'd drop your tire pressures to widen your footprint
-Kris
01 cclb f-350 srw-463hp/1025ftlbs PHP Dyno (extreme tune)
leveled with 285's on 17'' XD Spy's
Autometer gauges (boost, trans, egt, fuel)
4'' straight pipe
DIY 6637
Powerstruck 160/30's
Hydra-Powerstruck and Dan K tunes
38r
CNCFab fuel & hpop lines
Sam Wyse stage 2 trans.
Originally Posted by Dave View Post
Why delete something thats truthful? Paid vendor status isnt like the mafia youre not paying for protection from negative feedback here
strokin-7.3 is offline
post #5 of 88 Old 05-06-2014, 06:03 PM Thread Starter
It wasn't my first choice for the beach either but for the overall power and towing capabilities and the price i couldn't walk away honestly.
And thanks and I have manual lockers with 4x4 on the floor.
The reason I was going to go voltage was because the glow plugs honestly that way I knew 100% when they were ready. Any reason behind going with fuel pressure? I'm asking because I honestly don't know.
6.0 Trans Cooler
Crank Case Vent Mod
AdamCap is offline
post #6 of 88 Old 05-06-2014, 06:10 PM
sbluke55's Avatar
Quoted: 626 Post(s)
Garage
7.3 Advice
If you want to know what your glow plugs are doing, you need to do the glow plug led mod. Then go with the fuel pressure gauge because running low pressure can seriously damage your injectors. And your looking at $1400 minimum for injectors.
01 f-250, Standard
Rev tech 4" lift,37" military wrangler Mt tires
KC diy 66, Full force 160/100 and custom tunes from PHP
Banks inner cooler and full 4" exhaust, Diy S&B intake
Diy quad feed, Hydra, Isspro boost, pyro, and fuel pressure
3/0 battery cables with military style terminals
sbluke55 is online now
post #7 of 88 Old 05-06-2014, 07:15 PM
Im_Strokin_ur_Cummins's Avatar
Location: Lowville, New York. Studying Mechanical Eng. @ Suny Canton
I have no experance on sand but id say a wider tire to help float over it instead of a skinny tire that sinks and cuts into it
FUELED BY HATERS
Jack'em up high.Fat chicks cant jump!
E99 7.3 F-250XLT
304,345 miles and still running strong
ext cab
DIY 6637 Intake
5in straight pipe to Aussie stacks
PHP 6pos
Boost,tran,and EGT Gauges
4in lift
Some body rust and oil leaks
CB radio
Pretty Girl sittin next to me
Im_Strokin_ur_Cummins is offline
post #8 of 88 Old 05-06-2014, 07:51 PM
blue99stroker's Avatar
Quoted: 289 Post(s)
good tires ....
when its really cold just leave the ignition on for atleast a minute then start it.
still running the stock glow plug relay? its a POS, upgrade to a stancor or western plow relay.
there is plenty of info on here about chips, compressor wheels, cheap mods.
99.5 f250 7.3 4x4 265k Full Force 160/30, PHP Hydra, S&B CAI, 4" Exhaust, Van Turbo, RR 6/6 Billet Wheel, Autometer Gauges, Transgo Tugger/sonnax shift kits, Non-Ebpv Pedestal, 08 Tow Mirrors, Trucool Max.
Dad-2000 F250 7.3 4x4 114k Autometer Gauges, Superchips 1705 (Tow Safe), Blue 6637, 4" Exhaust, BD Billet Wheel, Trucool Max.
blue99stroker is offline
post #9 of 88 Old 05-06-2014, 07:56 PM
Doesn't Even Care
HVAC SuperTech's Avatar
Quoted: 69 Post(s)
Not talking about those Lockers...talking about diff lockers(tru track, eaton, ect).
More low end power? Get a custom tuned chip. Php hydra chip g available from many retailers out there. Alligator diesel, power struck.com, php, diesel site ect) or get a ts style chip with GOOD tunes on it. Gear head, php, Tony Wildman, power struck are all good ones.
Look into a billet compressor wheel. Either from riff raff or diesel site.
Sent from AutoGuide.com App
Nick
E99/CC/Lariat/Factory Wide Body Kit
"The Mistress"
Power Hungry Performance HYDRA Chip
Custom Tuned by Bill@PHP, Tony Wildman@Total Diesel Performance and Lars@Gearhead
D66 w/Dieselsite WW2, Full Force 250/100s, Adrenalin HPOP, Built Trans, Walbro Fuel Pump, S&B Intake, 6" Stacks, Leveling Kit, Eagle Alloy Wheels, 315/75/16 Grabber AT2s & Much More
HVAC SuperTech is offline
post #10 of 88 Old 05-07-2014, 03:57 AM Thread Starter
Thank you all so much please keep the advice coming. And thank you for elaborating on the lockers lol. Also anyone have a guess on a good tire? Besides wide
6.0 Trans Cooler
Crank Case Vent Mod
AdamCap is offline
