is a aftermarket turbo needed? - Ford Powerstroke Diesel Forum
post #1 of 18 Old 05-01-2014, 06:01 AM Thread Starter
Quoted: 6 Post(s)
If I got 165 hp injectors put in my truck would I need to buy a new turbo at the same time? Would it be worthless to do the injectors and run the stock turbo? Will I break my stock turbo? Dont know what bigger injectors entail.
Thank you
LeviD is offline
post #2 of 18 Old 05-01-2014, 12:39 PM
schlutzer's Avatar
Quoted: 18 Post(s)
What are 165 HP injectors?
Injectors are identified by size, for example 200/30
Please check out my 7.3 Enthusiast Facebook group! All are welcome!
schlutzer is offline
post #3 of 18 Old 05-01-2014, 01:02 PM Thread Starter
Quoted: 6 Post(s)
Well I'm not sure. Whatever size adds around that much HP. Will i need to do anything else to go along with it.
LeviD is offline
post #4 of 18 Old 05-01-2014, 01:23 PM
CSIPSD's Avatar
Who sold you 165hp injectors?
That means nothing... You need to know CC and Nozzle size to even get a proper tune to run them.
Without this basic info, no one can even give you a guess on what turbo is needed.
01 F-250 SC PSD,320k,16 Isspro Gauges, AFE-2,CCV Mod,IAH delete,map reg,Modded H2e, 6.0 IC, 230/100 from P.I.S, Studs, 910 springs, Forged rods, Water injection,Hydra chip-No Limit/Gearhead tuning, Swamps HVHF IDM, MBRP 4" dual's, Aero, 6" tip's, 4" Revtek lift, 37/12.5/16.5 MT's
Joe
DYNOPROVEN.COM, PERFORMANCEINJECTIONSYSTEMS.COM and RIFFRAFFDIESEL.COM
CSIPSD is offline
post #5 of 18 Old 05-01-2014, 04:45 PM Thread Starter
Quoted: 6 Post(s)
I have not bought injectors yet. As you can probably tell I have no idea what I'm talking about when it comes to them. I just know mine are getting old. Well instead of replacing stock ones I want more power. I have an edge evolution programmer right now but I know I will be replacing that if I do injectors with a custom tuned one. Any suggestions then on injectors that will give me 150 hp or more whatever those may be?
Thank you
LeviD is offline
post #6 of 18 Old 05-01-2014, 04:49 PM
CSIPSD's Avatar
Stop thinking about "150 more"...
What are your mods now? Intake Exhaust and an Edge... So 290-300RWHP...
150 more hp would put you around 450hp, which is not somewhere you can run the stock turbo for very long, nor the stock fuel system, nor the stock trans... You will more then likely need headstuds, and should do at least valve springs.
450hp injector is a 180/80 or 230/100 (230/100 is closer to 500-but it gives you a buffer).
Anyone selling you injectors talking about 150hp injectors is not someone you should be buying injectors from.
Joe
CSIPSD is offline
post #7 of 18 Old 05-01-2014, 06:02 PM Thread Starter
Quoted: 6 Post(s)
No one is selling me anything just trying to find more out about it so ill know what I need/expect going into it. Current mods are intake, 4 inch turbo back, edge, and a bd billet wheel on the turbo if that counts for anything. My trans is a manual so would it still need beefing?
Thanks
LeviD is offline
post #8 of 18 Old 05-01-2014, 06:03 PM
CSIPSD's Avatar
You will need a clutch for sure.
If your wanting about 450hp...
Then be prepared to drop about $4000 or so.
Joe
CSIPSD is offline
post #9 of 18 Old 05-01-2014, 06:10 PM Thread Starter
Quoted: 6 Post(s)
Alright thank you! Better start saving
Does an aftermarket clutch just help it not slip or something?
LeviD is offline
post #10 of 18 Old 05-01-2014, 06:15 PM
CSIPSD's Avatar
You will burn right thru the factory clutch at 350hp, or less.
Joe
CSIPSD is offline
