Hutch mod, now I'm not getting fuel - Ford Powerstroke Diesel Forum
post #1 of 25 Old 04-29-2014, 07:35 AM Thread Starter
Quoted: 21 Post(s)
Hello,
So did the hutch mod with kit and inline fuel filter. First I could only measure to the top of umbrella where its clamped.( pick up foot was broken off). So i matched that measurement. (keep in mind I pulled box to access tank so everything is easily accessible) I also installed a shut off valves to each side of filter head. I double checked my flow directions on filter head (in from tank, out to fuel pump. The valve handles are in line with fuel line.( should be open then)
Cycled the key a few times won't start. Checked fuel pump fuse, I can hear fuel pump cycling when I turn the key. Still no fuel....What am I missing?
The Next Level is offline
post #2 of 25 Old 04-29-2014, 10:47 AM
Did you pull the fuel filter out and see if fuel is coming into the bowl?
2014 F150 SCREW XLT 4x4 Ecoboost.
blderman is offline
post #3 of 25 Old 04-29-2014, 11:38 AM Thread Starter
Quoted: 21 Post(s)
None! did I burn the pump?
post #4 of 25 Old 04-29-2014, 11:47 AM
Winning DUHHH
Young-SC-Owner's Avatar
Quoted: 8 Post(s)
Needs to prime I bet, just bump the starter 6-8 times with fuel bowl drain open
Sent from AutoGuide.com App
99.5 F-350 SRW Short Bed, Ex Cab.
6637
Wicked Wheel'd,
Southbend
Autometer - Boost, Pyro
TW 6 Pos Chip
Water/Meth Inj
Diamond Eye 4" TB
7 year Veteran with SBFD
Airframe and Powerplant Mechanic
Head Marine Technician
Dont Tread on Me
Young-SC-Owner is offline
post #5 of 25 Old 04-29-2014, 11:58 AM
You may have forced the pickup foot into the bottom of the tank too hard and it can't such the fuel in.
blderman is offline
post #6 of 25 Old 04-29-2014, 01:09 PM Thread Starter
Quoted: 21 Post(s)
I flipped the plastic lever behind bowl, cycled the ignition half a dozen times. Is there a overflow tube it should be expelling out of( to the ground or something,I have nothing)
post #7 of 25 Old 04-29-2014, 01:15 PM
Quoted: 28 Post(s)
Did you drain and drop the tank or pull the bed? If you dropped the tank how much fuel did you put back in?
Edit: reread saw you pulled bed. But still how much fuel is in tank?
-Kris
01 cclb f-350 srw-463hp/1025ftlbs PHP Dyno (extreme tune)
leveled with 285's on 17'' XD Spy's
Autometer gauges (boost, trans, egt, fuel)
4'' straight pipe
DIY 6637
Powerstruck 160/30's
Hydra-Powerstruck and Dan K tunes
38r
CNCFab fuel & hpop lines
Sam Wyse stage 2 trans.
Originally Posted by Dave View Post
Why delete something thats truthful? Paid vendor status isnt like the mafia youre not paying for protection from negative feedback here
strokin-7.3 is offline
post #8 of 25 Old 04-29-2014, 01:26 PM Thread Starter
Quoted: 21 Post(s)
2/3 of a tank approximately.
post #9 of 25 Old 04-29-2014, 01:32 PM
Quoted: 28 Post(s)
As mentioned earlier prime and than start truck with fuel drain open. Or pickup is to close to bottom of tank.
-Kris
4'' straight pipe
DIY 6637
38r
post #10 of 25 Old 04-29-2014, 01:36 PM Thread Starter
Quoted: 21 Post(s)
Thanks, will give that a shot
