Rebuild turbo when installing ww2 or not - Ford Powerstroke Diesel Forum
post #1 of 6 Old 04-22-2014, 09:56 PM Thread Starter
Eco Taxi's Avatar
Simple question, wondering everyone's thoughts
I'm installing a non-ebpv pedestal n housing with a ww2 soon and am wondering if I should spend another 100 on the rebuild kit with 360 thrust
My truck has over 136k miles and the turbo has no play in it
I've read where some ppl reference the need to balance it after rebuilding so you shouldn't do it yourself whereas I've also seen forum members rebuild it thereself as well
Thoughts... Have any of you all built yours
Kyle
2001 F350 Chassis Cab 4x4 DRW Flatbed 130k miles+
Quad Gauge Pillar - Aeroforce Interceptor & Glowshift Series 7 EGT, Boost, Trans Temp
Foil Delete | Marinco Mod | High Torque 4kw Starter | Door Seal Mod | AIH Delete | Coolant Filter & 203* Thermostat w/ Billet Aluminum Housing | Hutch Mod | RiffRaff Fpx, Hpx, boots | WW2 | Deleted ebpv
“The good thing about science is that it's true whether or not you believe in it.” ― Neil deGrasse Tyson
Eco Taxi is offline
post #2 of 6 Old 04-22-2014, 10:30 PM
kbragg430's Avatar
I did the exact thing not too long ago. I went ahead and rebuilt it with the 360* thrust bearing. Only about 1500 miles after rebuild so far but doing well. Ive heard the 360 thrust will help turbo lifespan, especially since you will see higher boost pressures after the wheel than the stock turbo was designed for.
And it was cool to learn about all the innards of it. Not a bad job at all.
2002 F350 CCSB SRW 4X4 ~110k
4" MBRP, DIY Tymar, PHP hydra, Edge Insight CTS, 360* thrust, RR billet wheel, delete pedestal and outlet,
Napa ELC, melling 208 Lpop, 6.0 trans cooler, diy coolant filter, 203* thermostat, RR IC boots w/ plenum inserts, frx, hpx, hutch&harpoon
331 hp / 620 tq
Dynod by dynoproven 4/19/14
kbragg430 is offline
post #3 of 6 Old 04-22-2014, 10:32 PM
kbragg430's Avatar
And go ahead and gut the butterfly while youre at it.
331 hp / 620 tq
post #4 of 6 Old 04-23-2014, 07:44 AM
I would rebuild it. It only takes an extra hour of time and I had a noticeable difference after installing the 360 kit.
2014 F150 SCREW XLT 4x4 Ecoboost.
blderman is offline
post #5 of 6 Old 04-30-2014, 06:00 PM
What about adding a bigger housing? I'm thinking of a bigger housing, WW2, and deleting the EBPV.
mkfan17 is offline
post #6 of 6 Old 04-30-2014, 06:33 PM Thread Starter
Eco Taxi's Avatar
I'm gonna use this with my blank pedestal and ww2
Garrett GTP38 High Flow Outlet - Riffraff Diesel Performance
Kyle
Eco Taxi is offline
