Compressor Wheel WARNING - Ford Powerstroke Diesel Forum
 9Likes
post #1 of 39 Old 04-21-2014, 06:34 PM Thread Starter
GeorgiaStrokin's Avatar
Quoted: 8 Post(s)
Exclamation Compressor Wheel WARNING
To those thinking of installing aftermarket wheel please take note on installation. All of the websites are now warning not to use an impact to remove the wheel while the turbo is still installed. They recommend removing the entire turbo and simply using an "open end wrench" to remove the wheel while "holding the turbo shaft." Well, THERE'S NO WAY! I removed the turbo, figured out that there is no such way to do so, i even stuffed a sock into the exhaust side trying to bind the shaft enough to break the compressor wheel loose while using rubber mallet and said open end wrench. NOT HAPPENING. Funny story, the vanes on the exhaust side are angled incorrectly if you want to bind them in order to remove the intake wheel, but are the correct angle needed to tighten the replacement wheel- which doesnt need to be anything more than "snug". I ended up very very softly using air impact in the end to get it broken loose. this is a bad situation that needs to be attended to since everyone is threatening that an impact will create stress cracks in the turbo shaft but yet do not have any other way to swap wheel unless you tear the turbo all the way down to a pile of parts. the exhaust side of the turbo wont be easily broken down by harry homeowner.
GeorgiaStrokin is offline
post #2 of 39 Old 04-21-2014, 06:49 PM
schlutzer's Avatar
Quoted: 18 Post(s)
You use a screwdriver or something wrapped in a shop rag to hold the turbine wheel from spinning with the turbo removed.
You didn't follow the instructions and had problems, go figure. They warn not to use impacts for a damn good reason
Please check out my 7.3 Enthusiast Facebook group! All are welcome!
schlutzer is offline
post #3 of 39 Old 04-21-2014, 07:07 PM
blue99stroker's Avatar
Quoted: 247 Post(s)
ya i did my buddies with a screwdriver wrapped in a couple paper towels, worked fine.
i have seen tutorials that said use channel locks to hold the ex wheel, that would be a pain.
99.5 f250 7.3 4x4 260k FF 160/30, PHP Hydra, S&B CAI, 4" Exhaust, RR Billet Wheel, Autometer Gauges, Transgo, Non-Ebpv Pedestal, High Flow Outlet, 08 Tow Mirrors.
Dad-2000 7.3 4x4 110k miles, Autometer Gauges, Superchips 1705, 6637, 4" Exhaust, BD Billet Wheel, TruCool Max
blue99stroker is offline
post #4 of 39 Old 04-21-2014, 07:11 PM
hansel's Avatar
Quoted: 94 Post(s)
I will throw in my 2 cents worth, but back in 1986-87 I worked in a diesel shop rebuilding injector's, injector pumps, turbo's, supercharger's for diesel equipment and truck's. We used air tools for almost all tear down's, and then torque wrench's for reassembly.
Me I would have somehow held the wheel with either a sock covered screw driver or wooden dowel so I could break loose the nut.
2001 7.3L CCSRW 4X4
Airiad Intake 4" Flo-Pro Exhaust
ISSPRO EGT/Transmission
PHP Hydra
2015 Heartland Prowler
hansel is offline
post #5 of 39 Old 04-22-2014, 03:53 AM
Bill Kay's Avatar
Quoted: 2 Post(s)
Just out of curiousity, Has anyone seen a failure (broken shaft) from the use of an airgun to remove the compressor wheel.
Bill Kay is offline
post #6 of 39 Old 04-22-2014, 04:10 AM
schlutzer's Avatar
Quoted: 18 Post(s)
Not in person but there have been a few threads where people have had it happen. I don't think I know anybody who would do something like that.
For the amount of time it takes to do it properly I can't believe people would impact it.
post #7 of 39 Old 04-22-2014, 05:23 AM
hansel's Avatar
Quoted: 94 Post(s)
It's because people watch a video on 'YouTube" of a guy using a impact gun, and because he's a Powerstroke Expert they think's it's OKAY
2001 7.3L CCSRW 4X4
PHP Hydra
hansel is offline
post #8 of 39 Old 04-22-2014, 07:53 AM
CSIPSD's Avatar
LOL... I've removed hundreds of compressor wheels, all with a socket on the end of the exhaust wheel...
You had an issue, so now there needs to be a recall for all compressor wheels on the market...
I bet if you spilled hot coffee on your lap you would file a lawsuit huh?
I gave a guy a stock turbo that broke his shaft installing a WW with an impact...
dfuzz78 likes this.
01 F-250 SC PSD,320k,16 Isspro Gauges, AFE-2,CCV Mod,IAH delete,map reg,Modded H2e, 6.0 IC, 230/100 from P.I.S, Studs, 910 springs, Forged rods, Water injection,Hydra chip-No Limit/Gearhead tuning, Swamps HVHF IDM, MBRP 4" dual's, Aero, 6" tip's, 4" Revtek lift, 37/12.5/16.5 MT's
Joe
DYNOPROVEN.COM, PERFORMANCEINJECTIONSYSTEMS.COM and RIFFRAFFDIESEL.COM
CSIPSD is offline
post #9 of 39 Old 04-22-2014, 09:07 AM
timmyboy76's Avatar
here, here. Bought my 1st w.w., when i lerned about them, when buying my truck. Removed/installed while in the truck. However, not knowing a turbo...installed the wheel thinking all was good. Comressor housing even installed with no binding on fins. No in/out..up/down play. Low and behold, 1 month later, get'n on freeway, she blew sky-high.
Come to find out, the w.w. set on the shaft, was not correct. The shaft needs to protrude from within the w.w. by 3/16-1/4in...MINE WAS FLUSH. So, impact didnt "set" the shaft correctly with wheel being installed...
FWIW...i installed a BDP w.w., glad turbo was off then too, since the threads seemed tapered. If not with turbo apart and socketing the w.w. on first, i'd have a mess on my hands. Had to install that b#tch, then back her off, then re-install again....
99.5 x-cab 7.3l, 6spd, 161k miles.....
timmyboy76 is offline
post #10 of 39 Old 04-22-2014, 10:05 AM
layson's Avatar
Quoted: 80 Post(s)
When I didn't know any better back in the day. I put my old WW on my stock turbo while it was in the truck. I stuck a screwdriver in the exhaust housing wheel and unscrewed the compressor wheel. Then fast forward 10-20k miles I pulled the turbo and removed the exhaust housing. One of the exhaust fins was bent.
This last time, I just pulled the GTP38R. Stuck it in a vice and everything came apart easily. Just used wrenches.
2001 - 14" OUO 525 - 38x15.5x20 Toyo & 20x12 Weld Cheyenne's. Hybrids, 38R, BTS, Spearco, Terminators..
Quote of the Day:
Originally Posted by Mannysouza View Post
You will get some axle wrap with a heavy trailer, I can feel it when towing my gooseneck with some heavy equipment. My Deavers will wrap enough to make the tires rub the front of the rear fender well if I give it too much throttle on aceleration.
layson is offline
