Turbo or programmer - Ford Powerstroke Diesel Forum
 1Likes
  • 1 Post By blue99stroker
post #1 of 9 Old 04-15-2014, 06:04 PM Thread Starter
Turbo or programmer
I have a 00 f350 dually 6 Speed manual 2wd. It's a slow build and I'm doing multiple projects. It was suggested i do a turbo upgrade, 6-stage programmer, cold air. I need new tires (35/12.5/17) and also doing a level kit in the front. So I cannot afford to do all at once. So either the upgraded turbo or programmer will have to wait. Which makes more sense to do first and if possible...why. Also, I was told the cold air upgrade is more of a waste than asset.
JJ357 is offline
post #2 of 9 Old 04-15-2014, 06:45 PM
scagle1's Avatar
If money is budgeted....
Straight pipe the exhaust , a bit easier breathing and $75'ish tops
6637 intake setup , not good looking , but works and under $75 with 4" pipe piece and filter
At a Minimum get an EGT and Boost gauge
Chip - settings - get a stock , tow , high idle , econo and all out tune. $400'ish
You have no need for a turbo right now unless the current one is bad or failing.
Sold 01 350 6" on 37's and mild mods, 00 X 4" on 35's, 02 f350 4" 35's modded from fan to drive shaft, ridin the 03 with nose conversion with 125k and counting upwards slowly.
Never had CNC's poo on any of it, never will.
scagle1 is offline
The Following User Says Thank You to scagle1 For This Useful Post:
JJ357 (04-15-2014)
post #3 of 9 Old 04-15-2014, 06:50 PM
Joel's Avatar
Quoted: 10 Post(s)
Don't bother with a new turbo for now.
Don't get a chip if you can't afford gauges.
Get exhaust, intake and gauges first. Then the next step is tunes.
PIS 230/80's, Van Turbo with EBPV, BD Billet Wheel
Lots of money spent at RiffRaff
Dual SD fuel pumps, in tank mods, CNC Fab bowl retain kit. SDK Tunes. Isspro.
Still pretty slow, just less slow now.
Originally Posted by peixinho View Post
I love finally having my truck back... that 7.3 dog that I was driving was just not cutting it.
Joel is offline
post #4 of 9 Old 04-15-2014, 06:58 PM Thread Starter
I did the straight pipe. Well I have the stock pipe straight piped back to a 4" tip. Thought about doing a 4" pipe to a 5" tip...not sure it would matter. The programmer I was looking at has a 6 stage change on the fly with all the gauges. I've had no issues with the current turbo. And I'm not 100% sure the cost of the cold air is worth it. Performance shops will sell you a dream. Right now I am after best bang for buck, then I'll go into the extras not needed.
JJ357 is offline
post #5 of 9 Old 04-15-2014, 07:06 PM
Joel's Avatar
Quoted: 10 Post(s)
The intake is like $50 and definitely worth it
DIY 6637 intake
Google it
Joel is offline
post #6 of 9 Old 04-15-2014, 07:10 PM Thread Starter
Already looking it up. Thanks for the help. Looks like programmer and air it is
JJ357 is offline
post #7 of 9 Old 04-15-2014, 08:37 PM
blue99stroker's Avatar
Quoted: 258 Post(s)
get good tunes dont buy a crappy generic programmer like bully dog, edge etc.
php, powerstruck, dp, gearhead, no limit tuning etc.
Joel likes this.
blue99stroker is offline
post #8 of 9 Old 04-16-2014, 12:15 PM
duck fan's Avatar
And again, as others have mentioned here, when tuning your truck, regardless of whose tuning you use, make sure gauges are in your budget too. Its best when adding power, to make sure you can monitor the health of your engine as well.
2005 F250 CCSB FX4 6.0
2003 Excursion 6.0 4WD
1997 F350 CCLB 4WD 7.3
1996 F250 SCLB 4WD 7.3
duck fan is offline
post #9 of 9 Old 04-16-2014, 12:44 PM
Quoted: 258 Post(s)
if you do the above mods and feel the need for more, or experience turbo surge
look into adding a billet compressor wheel from either bd, riffraff, or dieselsite.
they are a great upgrade especially if you eventually get stage 1's.
Tags
help with the beast
