Motor Rebuild Internal Parts Suggestions/Recommendations - Ford Powerstroke Diesel Forum
post #1 of 2 Old 04-11-2014, 10:01 AM Thread Starter
Hey guys, well I've been limping my 99 7.3 around for too long now and I finally found a good deal on a rebuildable engine.
I have been lurking around the site for a few years trying to get ideas for my build, but have been holding off since the current engine does have some blowby issues.
So anyway getting past the small talk, I am looking to rebuild this new engine to hold up if/when I start going with a bigger turbo, injectors, etc.
The new motor is also a 99 so hopefully it should have the forged connecting rods, I plan on using ARP head and main studs, new valve springs, new bearings, pistons and rings. Is there any pistons you guys recommend and is there any other performance parts I am overlooking that I should consider in the long block build.
Should I do injectors while the motor is out or is it easy enough to replace these with the engine in the pickup.
My current goal is just to have a good strong pickup to pull trailers with again on a budget, but once I save up enough for a strong tranny I wouldn't mind trying to push the engine up to 450-500hp so that's the point I'm trying to build the internals to hold up to.
Thanks for your help. BTW I will be rebuilding the engine myself, is there anything else I should keep in mind when doing this since although I have a lot of experience building gas engines, this will be my first rodeo on a diesel.
RC22 is offline
post #2 of 2 Old 04-14-2014, 05:19 PM
Joel's Avatar
Quoted: 10 Post(s)
It's a lot more cost effective to buy a running motor or long block.
A stock forged bottom end is fine with the 500-550 hp goal that you have in mind.
I got my spare 2000 motor totally complete, with ECM and IDM and a tranny for $1000
After I sold all the stuff I didn't need I'm into the motor for practically nothing.
PIS 230/80's, Van Turbo with EBPV, BD Billet Wheel
Lots of money spent at RiffRaff
Dual SD fuel pumps, in tank mods, CNC Fab bowl retain kit. SDK Tunes. Isspro.
Still pretty slow, just less slow now.
Originally Posted by peixinho View Post
I love finally having my truck back... that 7.3 dog that I was driving was just not cutting it.
Joel is offline
