Auto engenuity code scanner tool - Ford Powerstroke Diesel Forum
post #1 of 11 Old 04-07-2014, 04:28 PM Thread Starter
jakethesnake1990's Avatar
What is everyone opinion on the AE? what i hear this is the best code tool you can get. Does anyone know if Its possible to fix the speedometer since my truck has an 8 inch lift in
37s. I also heard that it can tell how much HP I have and can do speed times like 0 to 60.
2001 F250 7.3
8 inch lift on 37s
6 Pos ts tony wildman tunes
Pillar gauges
4.56 gears
jasper rear
Stage 1 injectors
Silverline exhaust
Violant intake
Viper keyless start
jakethesnake1990 is offline
post #2 of 11 Old 04-07-2014, 04:39 PM
ZMANN's Avatar
Quoted: 1788 Post(s)
best code tool is Fords IDS
A/E is affordable and does access a lot of stuff a cheap reader can not
it has a tire setting option in the ABS module but you may or may not get results
in my opinion real HP and torque isn't something this can do like a Dyno but through calculations and user values it can do the math I guess I never really play with that portion of the software myself
We Miss you Ronnie
ZMANN is offline
post #3 of 11 Old 04-09-2014, 11:16 AM Thread Starter
For the ae do you just leave it plugged in the truck and let it collect data and then connect it to a laptop to read it?
2001 F250 7.3
8 inch lift on 37s
Pillar gauges
4.56 gears
jasper rear
Stage 1 injectors
Silverline exhaust
Violant intake
Viper keyless start
post #4 of 11 Old 04-09-2014, 11:21 AM
schlutzer's Avatar
Quoted: 18 Post(s)
No its runs off the laptop via USB. Or certain windows 8 tablets
You can set it for 37's no problem people say that's the limit but I set it for 40's and it was correct
Please check out my 7.3 Enthusiast Facebook group! All are welcome!
schlutzer is offline
post #5 of 11 Old 04-09-2014, 11:22 AM Thread Starter
So I have to have a laptop in the truck at all times?
2001 F250 7.3
8 inch lift on 37s
Pillar gauges
4.56 gears
jasper rear
Stage 1 injectors
Silverline exhaust
Violant intake
Viper keyless start
post #6 of 11 Old 04-09-2014, 11:25 AM
Powerstroke Techie
Clay Henry's Avatar
Quoted: 30 Post(s)
You dont leave it plugged in I'm not aware of it reading HP or any performance stuff. I have AE and never seen this - maybe because I didnt look for it.
AE is an awesome scan tool though.
2003 6.0 F350 dually on high cholesterol fuel (WVO)
2000 7.3 Excursion also on a high cholesterol fuel
Clay Henry is offline
post #7 of 11 Old 04-09-2014, 11:26 AM
dannanw's Avatar
Quoted: 66 Post(s)
Garage
yes...and also cant be plugged into the cig lighter, I've seen it do weird things but it'd still work just more of a pain. but yes the best (in this order) is Ford I/S tool, snap-on modus/similar, then A/E but the first two are over $1,000 or more so AE at about 400 & whatever laptop.
What this nation needs is cleaner thoughts and dirtier fingernails...
dannanw is offline
post #8 of 11 Old 04-09-2014, 11:31 AM
schlutzer's Avatar
Quoted: 18 Post(s)
Anytime you want to be reading data from the truck it must be plugged into the laptop yes.
And absolutely never ever have the laptop plugged into the cigarette lighter for power and the OBDII port at the same time. This causes a grounded loop and worse case scenario fries youR PCM
post #9 of 11 Old 04-09-2014, 12:16 PM
Powerstroke Techie
Clay Henry's Avatar
Quoted: 30 Post(s)
Where did you get your information?
post #10 of 11 Old 04-09-2014, 12:23 PM
Quoted: 176 Post(s)
Feedback Score: 3 reviews
AE says not to...
From their Forum;
Important AutoEnginuity USB Hardware Note
Unlike devices connected via Serial cables, USB devices are "Powered" by the PC they are connected to. Connecting an AutoEnginuity USB ScanTool cable to a laptop computer that is being powered through the Cigarette Lighter/Power Port of the vehicle can cause ground loops through the laptop. At the very least this will lead to problems establishing communications with the vehicle, in some cases this can even damage the AutoEnginuity USB ScanTool hardware. This problem will occur whether using an inverter or powering directly off of 12v.
If you are using the AutoEnginuity USB ScanTool on a vehicle where the OBDII port and the Cigarette Lighter/Power Port share the same fused circuit (Ford Super Duty for example), do NOT power the laptop from the power ports.
NoRalPh is offline
The Following User Says Thank You to NoRalPh For This Useful Post:
schlutzer (04-09-2014)
